• 12-17-2011
    bullcrew
    FOX DHX 4.0/5.0 SSD custom mod and tuning: AVALANCHE
    Craig at avalanche downhill racing is now doing FOX DHX shocks, the modifications and tuning swap stuff out and custom parts put in making it Speed Sensative damping.
    Talked to him the other day after seeing it on the site I have my dhx 5.0 from my Sunday being done.
    Link
    Fox DHX 5.0Speed sensitive Damper Adjuster Kit
    Fox DHX 5.0/4.0 and VanRC Speed Sensitive DamperAdjuster Kit
    Replaces ProPedal Adjuster with a low speed compression adjuster and custom valved high speed piston system in the existing Fox piggyback housing. This conversion complements the revalved main piston to completely convert the DHX/VanRC to a true speed sensitive damper.
    Technical Discussion Here:
    Includes revalve and setup for rider, frame and conditions.
    Also includes complete rebuild service, new improved seals, oil, nitrogen charge and typical wear parts* included in price
    *(Typical wear parts: shaft seal, dust scraper, shaft bushing, reducer DU bushings, and o-rings)
    Optional:
    Shape factor bottom-out bumper (Available now)
    Reservoir Volume Expansion Kit, standard length or extended length (Available Soon).
    Not available as a self install kit.
    Available soon, DHX 3.0 optimized SSD internal replacement Valve, research being done currently on viability of DHX Air shock conversions to SSD technology
    Why change out Propedal valve in the DHX?....The design of the Propedal creates a great position sensitive shock. As the pressure in the shock goes up the propedal valve gets harder to open, this creates more compression damping. The pressure can be increased 3 ways, first my adding more air pressure to the schrader valve, second as the shaft compresses, the displaced oil compresses the reservoir floating piston down, which drives up the pressure in the reservoir, and lastly the chamber compensation bottom out can be dialed in to decrease the reservoir volume and thus cause the pressure to be driven up even faster as the shaft compresses. The Propedal adjuster allows the rider to compensate for the pressure on the valve by applying opposite spring pressure to the valve reducing the force required to overcome this internal pressure and allowing the valve to blow-off more easily.
    So this all sounds great but in a real world where courses and terrain are not perfectly smooth and void of square edge holes, this is where the Propedal system fails to allow the valve to blow-off. When the shock hits square edge bumps deep in the stroke the valve becomes harder to blow-off and is actually getting firmer the deeper it gets in the travel (Position sensitive damper).
    This is why the Speed Sensitive Damper (SSD) is preferred, as the shaft speed needs to increase the compression adjustment valve needs to blow-off when the bumps become square edged or what we call high speed hits. This creates the need for the conversion and replacement of the propedal system to a shimmed ported valve. Since the shim stiffness is not affected by the build up of pressure in the reservoir, the shims can create damping at low and medium speed compression hits and be valved to blow-off when higher shaft speeds occur thus allowing the damper to smoothly resist the square edged hits. Because the main piston was valved for a very progressive position sensitive Propedal valve we can now revalve the main piston to contribute to the compression circuit and due to the decreased ramp up in the overall spring rate of the damper, the rebound stack can be revalved to be more linear . The main piston can now control it's 70% share of the compression damping giving us many more tuning options for rider set-ups. Rebound can be tuned to be more reactive on small bumps and provide lift where needed while preventing that pogo stick feel.
    Specifications:
    16 mm Speed Sensitive flow controlled 4 port Compression Valve 15 Clicks of Low Speed Compression, uses exiting Propedal knob as new low speed adjuster Revalvable 6 mm ID shims High speed adjustment - Internal Shim Stack Nitrogen charged to 160 psi, fixed (i.e. no need for adjustment now) Retains bottom out system to aid with pressure ramp up needed for regressive linkage frames Installs directly into the DHX housing...which preserves same top housing and adjuster knob for fit compatability of existing frame applications Low friction main shaft Seal Shape Factor Bottom-out Bumper, optional Increased volume Reservoir cap, optional Extended Reservoir cap for maximum volume, optional
  • 12-17-2011
    MonsterD
    Noice!
  • 12-17-2011
    ifouiripilay
    This was on the website forever for preorder, glad to hear its reality now. Do you know if it's the same as Push's mx tune and how it compares?
  • 12-18-2011
    bullcrew
    This has a bunch of stuff removed and a bunch of custom parts craig designed and stuck in. It will be a full race tune or freeride whichever is the riders style it can have more or les valving it can be shimmed and if you have a regressive bike ie like my Sunday the bottom out adjuster can be cranked in to accommodate some progressiveness to help it.
    This actually adds a low speed compression with needle valve on the end of the pro pedal.
    This is actually a really tuneable shock with the bottom out left on to make the shock go from linear to progressive it will and can accommodate a bunch of applications.
    By leaving the bottom out on its like having 2 shocks in one, crank it up and make the bike poppy and swap lines and jumps at will.
    Hit a chatter rocky course back the bottom out back and have a total linear speed sensative shock.
    Like stated above it is like having 2 shocks in 1:thumbsup:
  • 12-18-2011
    Gman086
    How would this compare to the PUSH mod which also removes the platform damping and they've been doing this to that shock for over 7 years now?
    Have FUN!
    G MAN
  • 12-18-2011
    bullcrew
    Have FUN!
    G MAN
    Similar except I don't think they set the propedal up as a low speed compression setting complete with new needle valve assembly and internals for it.
    And its cheaper with that as well.
  • 12-19-2011
    PUSHIND
    Our system offers both High and Low Speed adjustment externally. The avalanche uses preset high speed valving with external Low Speed control. Craig makes really nice stuff so I have no doubt this will be a nice unit.
    By removing the Boost Valve and replacing it with a SSD valve you no longer have the bottom out feature. Turing the bottom out control will cause a slight increase in lifting force at the piston but at the expense of causing the shock to heat more rapidly than running it all of the way out. So basically, you'd decrease small bump sensitivity slightly, not really have any effect on bottoming control, and increase heat.
    We machine our own knobs, but yes our low speed circuit utilizes a needle and valve seat.
    Darren
  • 12-19-2011
    bullcrew
    Darren
    Good point it would be a increase in rate causing more internal pressure and heat vs making the shock ramp up.
    Good to know that you did a needle valve wasn't sure and didn't see it listed on your site under the what's done.
    I assume that's with the whole mx tune new bridge that the low speedneedle and seat is included.
    good to see you chime in.:thumbsup:
  • 12-19-2011
    G-AIR
    Darren
    When will your system be in stock? Why is it difficult to keep in stock?
    Good to see another option with Avy. Craig does awesome work.
  • 12-19-2011
    PUSHIND
    With our Factory Tuning System, we modify the existing system to. With the MX-Tune we use the needle.
    MX-Tune will be available in a few weeks. We just underestimated the demand by a long shot and were having and outside vendor make a few of the pieces. Instead of reordering a couple of the CNC lathe parts, we decided to purchase this:
    <iframe width="420" height="315" src="http://www.youtube.com/embed/D-KVYVvUEf4" frameborder="0" allowfullscreen></iframe>
    Haas was a little late building it, but it's been in house and online making production parts for a couple of weeks now.
    Darren
  • 12-19-2011
    bullcrew
    So aside of the external high speed compression the avalanche tune is the same as your mx tune just cheaper? Plus you get low speed adjustability a custom tuned shim stack and options for larger reservoir capacity, propedal removed completely and cheaper than the your race tune.
    I know high speed internal set ups are controlled by shims and can be made to blow off or fold at different pressure via speed. Are you putting different springs on your high speed to blow off at different pressures for different designs?
  • 12-19-2011
    PUSHIND
    Well, first we feel like the external High Speed compression adjust is a pretty big deal. Second, we also install not only new custom shim stacks, but a new CNC machined PUSH piston (See Below) to go along with the stacks. We also install our proprietary piston bolt with built in asymmetric valve which makes the compression and rebound circuits completely independent from each other (this was a PUSH exclusive up until Trek started offering it this past year in the Session RC4 shocks that FOX is building). Proprietary seals and wipers specifically designed to work with the aluminum shafts, high volume end caps for increased reservoir capacity, the ability to eliminate the Propedal effect, proprietary rod bumpers, etc. So, yes the AVA kit is cheaper, but it's because of the additional machined parts that we install. If we were to just do a revalve without our piston, or piston bolt, etc then we could probably hit that price point as well.
    Yes, we have 4 different High Speed blow-off springs available depending on the application and leverage characteristic.
    Listen, obviously I'm biased towards our products and services. Craig is a really talented guy, and although I haven't seen this product yet I'm sure it is going to work really well and will be a great fit for a lot of riders. We just have a different approach that works for us and our customers.
    Darren
  • 12-19-2011
    meSSican
    Any chance PUSH or Avy will offer tunes for the DHX RC2?
  • 12-19-2011
    PUSHIND
    We definitely are. We had a custom wiper molded for us which we're currently waiting on before releasing our production kit.
    Darren
  • 12-19-2011
    PUSHIND
    At least Craig answers my emails
    I admit....not my strong suit! That's why we have Nick! nickb@pushindustries.com. He's our email guy, and unlike me, really easy to get a hold of. :D
    Shoot, if it wasn't for this CNC programming problem I've been dealing with all day, I wouldn't have been at my desk all this time available to post on emptybeer! :madman:
    Darren
  • 12-19-2011
    tacubaya
    At least Craig answers my emails :rolleyes::p
  • 01-03-2012
    bullcrew
    So went and looked for the dhx tech page and there's really'intresting data on How the fox ramps up as well as internal pressure of the modded and extended resevoirs and new Internal seals dust wiper and bottom out bumper.
    The pressure internally that a stock dhs reaches in the platform (reservoir) at bottom out A dhx 5.0 with 3" stroke Stock PS I 1500+ No bottom out 625 Modified 380 Extended resevoir 225
    The stock is for regressive, no bottom out and modified is for regresive to linear Modified is for linear to progressive And extended reservoir is for progressive to rising rate
  • 01-09-2012
    bullcrew
    Let me first say the stock reservoir was left to make this shock ramp for a progressive setup (ie Sunday).
    Got a late Xmas present in today.
    Had a little time today on it but will update after beating on it.
    The rebound has a very big range that is noticeable between clicks, the comoression (low speed) has a very nice wide range to dial in. It ramps but doesn't pack up or spike. I'll try and grab some pics from the rocks and jumps on wed. I will have a diversified run on it, it feels better than the rock wc did. It has the same deep feel but now I can pop it up and around so definently not dead feeling.
  • 01-09-2012
    SHIVER ME TIMBERS
    but doesn't pack up or spike. I'll try and grab some pics from the rocks and jumps on wed. I wilg]
    man you should have rode.....end of month???
  • 01-09-2012
    bullcrew
    I wanted to but too much stuff going on that I make local stuff which by all account t is golden but my time has been super limited.
  • 01-09-2012
    SHIVER ME TIMBERS
    maybe I will come down....
  • 01-09-2012
    bullcrew
    Yeah if you come down B you can stay here at the house.
  • 01-09-2012
    SHIVER ME TIMBERS
    :thumbsup::thumbsup::thumbsup::thumbsup:
  • 01-10-2012
    1962
    fox dhx air 5.0
    so i have this fox dhx air 5.0 and it has leaked oil since day one. it's on a ventana la bruja bike and needs some lovin. i don't want to send it back to fox and have the seals leak again so who should i have rebuild it (push) or ? ...ralph
  • 01-10-2012
    1962
  • 01-10-2012
    bullcrew
    Call craig I know hes looking to tune the dhx air as well.
  • 01-10-2012
    aenema
    I really like this post and like the input from Darren as well. I have a DHX 4 on my SX trail that I pretty much don't like and am torn by options. Can we break down differences between the two services being talked about (Push and Avalanch) and what, if any, difference that would make on the trail?
    Push = modifies existing propedal configuration but with new pistons, valving, seals
    Avalanche = replaces existing propedal system with what exactly to make it Speed Sensitive? New piston as well or existing but re-valved.
    I have a pretty good understanding of the systems but would be great to see a comparison between them so we can make an informed decision based on price and who we think has the approach that best serves our needs.
  • 01-11-2012
    nobrakes2007
    *Bump*
    Looking at each as a possibility for my DHX 5.0.
  • 01-11-2012
    geolover
    Definitely interested in hearing more feedback. I have been trying to figure out how to make my Sunday a bit more responsive to trail features. Reasonable cost as well...much better than the Vivid Air I was considering.
  • 01-16-2012
    crseekins
    We replace ProPedal Adjuster with a low speed compression adjuster and custom valved high speed piston system in the existing Fox piggyback housing. This conversion complements the revalved main piston to completely convert the DHX/VanRC to a true speed sensitive damper.
    Why do we change out Propedal valve in the DHX?....The design of the Propedal creates a great position sensitive shock...But? So as the air pressure in the shock goes up the propedal valve gets harder to open, this creates more compression damping. The air pressure can be increased 3 ways, first my adding more air pressure to the schrader valve, second as the shaft compresses, the displaced oil compresses the reservoir floating piston down, which drives up the air pressure in the reservoir, and lastly the chamber compensation bottom out can be dialed in to decrease the reservoir volume and thus cause the air pressure to be driven up even faster as the shaft compresses. The Propedal adjuster allows the rider to compensate for the air pressure on the valve by applying opposite spring pressure to the valve reducing the force required to overcome this internal pressure and allowing the valve to blow-off more easily.
    So this all sounds great, but in a real world where courses and terrain are not perfectly smooth and void of square edge holes, this is where the Propedal system fails to allow the valve to blow-off. When the shock hits square edge bumps deep in the stroke the valve becomes harder to blow-off and is actually getting firmer the deeper it gets in the travel (Position sensitive damper).
    This is why the Speed Sensitive Damper (SSD) is preferred, as the shaft speed needs to increase the compression adjustment valve needs to blow-off when the bumps become square edged or what we call high speed hits. This creates the need for the conversion and replacement of the propedal system to a shimmed ported valve. Since the shim stiffness is not affected by the build up of pressure in the reservoir, the shims can create damping at low and medium speed compression hits and be valved to blow-off when higher shaft speeds occur thus allowing the damper to smoothly resist the square edged hits. Because the main piston was valved for a very progressive position sensitive Propedal valve we can now revalve the main piston to contribute to the compression circuit and due to the decreased ramp up in the overall spring rate of the damper, the rebound stack can be revalved to be more linear . The main piston can now control it's 70% share of the compression damping giving us many more tuning options for rider set-ups. Rebound can be tuned to be more reactive on small bumps and provide lift where needed while preventing that pogo stick feel. Increased reservoir volume reduces pressure build up deep in the stroke, reducing heat build-up and increased oil and seal life.
    Modified Reservoir Volume
    1.0 cubic inches
    30% increase
    use with linear to progressive set-ups
    For a 1/2 inch diameter shaft, 1500 psi equals 294 lbs extra spring force
    in other words for a 300 lb/in spring at 3 inches of stroke, the spring rate would increase to 400 lb/in.
    What does all this mean? For regressive set-ups it might be good to add a bit more compressive force at the end of the stroke, but this does not come at no cost, as the shock compresses rapidly the reservoir also heats up and causes the nitrogen pressure to even further increase. Even though the propedal valve that was activated by this pressure increase has been removed, the seals, the o-rings and the oil have to deal with much higher pressures then needed. Typical initial nitrogen charge of 160 psi is enough to prevent internal cavitation and allow the shock to have proper damping. So generally for most shock set-ups it is advantageous to keep the pressure as low as needed and prevent the pressure from ramping up as the shock is compressed.
    Here is some Technical Info on the VanRC Modifications
    The VanRC is Fox's redesigned DHX that has the the Propedal valve removed and replaced it with a high speed regressive blow-off style valve with a very limited external low speed adjuster. This makes the VanRC a speed sensitive damper but with emphasis on pedal performance because of the low speed threshold of the Belleville spring valve set-up in the high speed adjuster valve and limited low speed adjuster range. Since the Propedal has been removed, The reservoir now uses a non adjustable fixed charge system and no longer has the need for the Bottom-out adjuster volume reducer feature. The internal volume is now much larger with these features remove and would be similar to the modified DHX 5.0 reservoir volume. The DHX 4.0 volume does not have the Bottom-out features as well so the volume need not be modified, but will except the extended reservoir cap when available.
    We have developed a modified version of VanRC valve that uses shimmed high speed valving and a wider range low speed adjuster for more sensitive low speed performance and more progressive high speed feel while still allowing blow-off on square edged bumps. This now allows us to revalve the main piston valving to complement redesigned adjuster system as we have done with the DHX. The reservoir is charged with fixed nitrogen pressure, but an optional extended reservoir cap will be available soon to minimize pressure ramp-up as we have done with the DHX.
    Here are some of the production parts hot off the CNC's:
  • 01-17-2012
    bullcrew
    What he said. :D
  • 01-17-2012
    ak pura vida
    so i'm going to have one of these done to my dhx 5.0 (wish i had a better technical knowledge base about shocks so i could understand the differences better... :) ). going to each sight i see the avalanche modifications is $199. push sells their factory tuning system for $205 but i don't see a price listed for the MX tune. how much does that run? i'll have to do some more research on which one i prefer and even though pricing isn't actually my main priority, it is still something to be considered in the equation. thanks and great info, btw. this is exactly what i was looking for/wanting to have done.
    pv
  • 01-18-2012
    SamL3227
    so.....neither ava or push have come to production with a viable(any) dhxAIR.
    i would guess that both of you have speculated/researched revamping/machining the dhx air.
    any chance either of you would like a test subject for said project while its winter?
    already have the dhxAIR. and for what i do most the time is great. but i would love to see some evolution with its internals(if its even monetarily unfeasible)
    really i just kickin myself for not just sending in my 5th element and tossin it. cuz that from what i hear would have been a quick fix.
    been searching and searching for a good tune on the dhxAIR and come up with zilch. no dice.
    i dont dh exclusively enough on main bike to go drop half/g on ccdb/etc. my only other option is to snag an old 00's vanR(C) and have it rebuilt.
    should i just pony up for real coilshock and have it tweaked....or is there ANY chance that somebody needs help testing/etc/blah blah blah. any mods with dhxAIR. because id be all over that....hint hint.
  • 01-18-2012
    bullcrew
    Craig at avalanche is doing dhx air.
    Akapurvida, Craig's SSD mod/tune is not the same as darrens $204 tune , its more on par with his mx tune.
    Darren's base job $204 is a basic rebuild not much else so bang for the buck avalanche is a lot cheaper for a custom job with modifications and parts.
  • 01-18-2012
    ak pura vida
    right, thanks, that is what i was thinking but how much is the push mx tune? it wasn't listed.
  • 01-18-2012
    ifouiripilay
    I think I paid 299 last year.
  • 01-18-2012
    PUSHIND
    This is incorrect. Our Factory Rebuild is our rebuild service. For $204 you get our Factory Tuning System.
    Here's a pic of the components that are in are Tuning System:
    - PUSH Exclusive Asymmetric Valve Piston bolt. This features a one-way valve system which eliminates the cross over of damping circuits. Our kit is the only system that when you change the rebound externally it doesn't change the compression characteristic.
    -PUSH Exclusive VRX piston and valving. This unique piston system allows us near unlimited tuning characteristics and can be built using a digressive, linear, or progressive damping force curve based on the application.
    PUSH Rod bumpers. Our bumpers are not modified pieces designed for a different application. Our rod bumpers are the only bumpers custom designed and molded specifically for this application and are available in 8 different densities depending on the application. One size does not fit all in this case.
    PUSH Exclusive Glyde Rings. We are the only suspension tuner that does not reuse piston glyde rings for our rebuild and tuning services. Our glyde rings are again custom designed and machined for each application.
    We've been tuning and installing this kit for over 5 years into more than a thousand DHX shocks. We're very experienced with this application and also have a complete inventory of replacement parts in stock for any additional damage or wear.
    Obviously, our MX-Tune provides a whole different component package and will be back in stock shortly.
    Another unique point is that we are the only aftermarket suspension tuner that makes all of their machine parts "in house" from prototype to production.
    Darren
  • 01-18-2012
    bullcrew
    Darren
    Were those prototypes parts based on craigs hi/lo adjuster originally :thumbsup:
    Or the fact the original bridges were so big they were hitting peoples frames or too big for some set ups. Just asking.
    So what your saying is your basic tune is the same as Craig's or am I right in assuming yours is less extensive till you get to the mx tune and then the difference is there's a external hi speed adjuster.
    Just asking because special bumpers is kind of like saying I have special muffler bearings, density can be done obviously but that's based on bottom out and tune and if done correctly the need for multiple bumpers is more hype than anything.
    There really is no need for 8 different bumpers that I can think of unless its just overly thought out.
  • 01-18-2012
    PUSHIND
    No, we had been shipping the Factory Tuning System for the DHX for a couple of years before using the AVA hi/low adjuster system in our Gen-1 MX-Tune.
    I'm not aware of any fitment issues with the original bridge....it was just a little bulky. The new design cut the weight down significantly.
    Obviously I'm bias, but yes our Factory Tune would be equivalent to the AVA kit. Our Factory Tuning System is also not limited to shocks that are in good working order which is one of the stipulations with the AVA kit. We have all of the components in stock and available to service the shock completely whether worn or damaged. The MX-Tune does in fact offer more.
    Multiple densities are not hype. Because the bumper offers additional spring rate they must be matched to the main coil spring rate. You wouldn't run a stiff rod bumper with a soft coil spring and vice versa. If rod bumper density is hype why do companies like Showa and KYB offer multiple densities for each rod size with their motocross shocks? As a side note, our bumpers are molded by the same company that makes the Showa and KYB units.
    Listen, obviously you're a supporter of Craig and his program and that's cool. I've mentioned several times that I think Craig is a really smart guy who has legit products. I'm not here to go back and forth with you but rather clear up misinformation when it comes to my companies products or services. I only post when my company is brought into it. It's awkward for me to be involved in a post regarding a competitor and a supportive customer.
    I'm stoked that you like your setup and it makes you want to go shred trails. In the end, that's what matters.
    Darren
  • 01-18-2012
    ak pura vida
    thanks. called and left a message. i'll pick their brain more when the call back.
    pv
  • 01-18-2012
    ak pura vida
    so bullcrew, i'm getting the feeling you are not a push fan? an reason specific or just an avalanche preference?
    pv
  • 01-18-2012
    aenema
    Good responses Darren. I think as a potential customer, I really just wanted to know the details of what your servcie provides and the same with Craig. You definitely provided that well. We are all (hopefully) intelligent and can take the info you are providing and use that to come up with our decision and don't need you to make direct comparisons for us. I think Bullcrew is trying to do us a service with the direct comparisons but he is coming off a little bit direct. I appreciate his efforts but but think your answers are a class act.
    One question I would like addressed. The Ava system replaces the propedal while the push system does not unless you get the MX tune. Besides the debates on how adjustable the setups are as far as external dials, do you feel comfortable providing a opinion/description from your perspective? I feel that Craig has mentioned the benefits from his through his post above and wondered if you could chime in on that specific also.
    thanks to all who have been contributing to this thread.
  • 01-18-2012
    crseekins
    Darren
    Thanks for helping clear things up, Darren. We here at Avalanche just want to offer customers with an alternative way to modify and revalve their Fox shocks. This will help everyone make the best decision possible for choosing the product that fits them best. Just one thing that Bullcrew was trying to point out with the Factory Tune, and I think it shows up in the photo you posted, that the Propedal adjuster is not modified to become a low speed adjuster and the valve is left in. The pressure effect is reduced on the valve by making the reservoir volume less effective on the Propedal valve. We replace the Propedal with a custom tuned shimmed high speed valve to eliminate the pressure effects which makes it speed sensitive as compared to the pressure (position) sensitive Propedal valve.Lets just say it is a step between the Factory tune and your MX tune and leave it at that. Either way everyone has a choice between two very good suspension modifications.:thumbsup:
  • 01-18-2012
    bullcrew
    pv
    No I like push and think Darren does a good job at marketing and makes a good products but having been in and around stuff for as long as I have I want more exact answers without the marketing jargon that's all.
    But I have zero issues with Darren or pushs quality of products I think the choices and the industry needs guys like craig and Darren it benefits us as consumeres I would like a direct comparison more than tech hype.
  • 01-19-2012
    ak pura vida
    oh, ok. i misinterpreted the posts. biggest issue with the internet.
    fwiw, push called me back this afternoon and was quite willing to answer and clarify what i'm sure were all of my very basic questions. very nice, very helpful. imagine that, customer service... sad that seems to be so rare these days. haven't decided which way i'm going to go. need to call and talk to avalanche too. push said they should have the mx tunes ready to go and in stock in a couple few weeks. didn't have a price yet but the previous ones were right around $300 as stated above.
    pv
  • 01-19-2012
    Brother Lu
    I bought a used alu v10.3 last summer.The old owner who worked in a bike store and raced locally,said that he had the propedal removed and tuned by a local suspension shop.So what did this shop do?,or is it BS.
    It's a dhx5.
  • 01-19-2012
    crseekins
    It's a dhx5.
    How does it work? You are welcome to send it in and we can look at it. Not sure how you can remove the propedal without replacing it with something to prevent the oil from leaking out.
  • 01-20-2012
    Brother Lu
    I was wondering the same thing.I will contact the shop and find out what they do.Thanks for the response:thumbsup:
  • 02-17-2012
    ifouiripilay
    Bullcrew- so how's the shock been for you since you've had some ride time?
    I decided to go for the avalanche tune myself. 1 to try avalanche 2 Push has been lagging for months with the mx tune 3 the positive reputation of avalanche shocks including the chubbie and woodie. This my first time as a customer and I was surprise to find that going through the purchase process, that there was no questions about type of bike, wt of rider and riding style. Is this something they ask when they receive the shock? Anyhow, I just have to wait a couple weeks and see.
  • 02-17-2012
    bullcrew
    Craig will call you when the shock is on the bench so its all right there and done so no questions and issues, also he will go over several questions with you to get it dialed exactly where you want.
    As far as mi e LOVE IT, haven't put the avalanche chubbie back on and can't really justify it. I'll have more pics of jump line tomorrow, I got my butt handed to me on a botched jump/step down I came in off thefirst jump screwy and couldn't get a handle on the jump landed flat. Rear handled it fine the fox 40 stuffed and ended up icing my wrists tonight.
    The rear dhx kicks @$$........
  • 11-18-2012
    wfoacman
    MX Tune available in a few weeks.
    Going through some old threads and I came across this.
    Dated 12-19-11
    Darren
    Just wondering if this MX Tune is ever going to happen? Any updates on this?
  • 11-18-2012
    PUSHIND
    From our Facebook page last Wednesday....
    Timeline Photos | Facebook
    Darren
  • 11-18-2012
    wfoacman
    Darren
    OK, well spill the beans, and don't tell us a few more weeks..... Just busting your balls.
    Solid time frame?
  • 11-18-2012
    PUSHIND
    Solid time frame?
    :thumbsup: I'll be updating our Facebook. But, once the parts are off to anodize the kit will be available for order through our site.
    Darren
  • 01-21-2014
    panzer103
    I want the Avalanche ssd mods so freakn bad for fork and shock. Sadly awesome cost money, which l have none of
