Good stuff, I'm stoked to see the final product
Looks awesome! I'd love to have one of those!
I've been following this thread. Great work!
F*ck Cancer
Eat your veggies
DenverDH'er
Wow. MOAR than impressive!!!
Rookie
Oh my.... They look very nice.
Love the paint job.
Ruder than you.
Ska is not dead!
This has been fun to watch. Looking forward to seeing the rest.
 Originally Posted by Full Trucker
Was heat treating after welding needed?
Thanks for including us. I enjoyed watching the progress. Keep it up!!
"walking on water is only knowing where the stones are"
rider of bicycles
Re: Heat treat
The frames are made from 7005, which is an age-hardening alloy, and in general, it is considered not necessary to heat treat. However, an artificial age-hardening heat treat can be done after welding to reach full strength without waiting for it to occur naturally.
In our case, since reliability is a top goal, we do perform an artificial age hardening heat treatment after welding.
And, thanks for the compliments!
Amazing!
Awsome job guys!!! I wonder how much does a DH frame cost without all the marketing?
I'm guessing about $1925-ish
the drugs made me realize it's not about the drugs
This is a cool thread, can't wait to see further progress.
Very aesthetically pleasing. Keep up the good work.
Thanks for all the kind words so far. Here's a quick shot from earlier this week, the rear triangles are finished up on the first 5 and getting ready to get powdercoated. Pretty stoked at this point, it was Wednesday I think? Anyways, another big update to the project is on the horizon, but wanted to get this picture in the mix to tide ya'll over.
BLAMMO!
DenverDH'er
Looks like oval axle holes. Is there a flip chip at the rear axle for 2 chainstay lengths? How does the brake mount accomodate that?
Keep the Country country.
Yep, a "flip chip" indeed that adjusts chainstay length from 17" to 17-1/2". The hangar is a separate piece from the chip and the frame itself. The through-axle goes through both the drop out and the derailer hangar and keeps it all nice and snug-like. As for brake mount accommodating it... to be honest I'm not sure. There is no adjustment for the brake that I remember, I'll have to take a look later this evening. And I'll make sure to get pictures of all this real soon...
rider of bicycles
I decided to try a fixed brake caliper mount on the alpha prototypes to see if it would work vs moving the brake caliper when you swap chainstay settings. For that experiment, I put the brake caliper in a location as if the long chainstay setting didn't exist, and it still worked in the long chainstay setting.
For the Betas, I moved the brake caliper mount to be centered between the short and long settings. With this batch, we'll have tested the following brakes: Shimano SLX & Saint, Avid Code, & Hayes Prime. Based on the experience with the alphas, I doubt we'll have an issue. If we do, I can add a second set of holes, but I wanted to minimize the PITA of changing geometry. The goal was to make it easy enough where people actually use the adjustments.
- You may not post replies
- You may not edit your posts
Forum Rules
