Results 1 to 8 of 8
    May 2013
    Fitting Halo Sas wheels to Transition TR450
    Iv resently bought a Transition TR450 frame, it takes a 150 x 12 rear axle wheel? and im wanting to fit my halo spin doctor hub that is currently setup for quick release.
    Anyone know what i need to do to convert it or if i just need to buy a new hub?
    Reputation: Fix the Spade's Avatar
    New hub (or new wheel).
    The SAS wheels you've got is 135mm wide, if you get a 12mm converter it will still not fit the frame.
    Halo do a 150mm width SAS wheel, more or less the same wheel save for being 150mm.
    May 2013
    Yes that's the hub.
    May 2013
    That hub is 36H, my wheel is 48h. I cant find a 48h version
    Reputation: juanbeegas's Avatar
    Oct 2007
    In this day and age... Even a 36H wheel is pretty much overkill. I'd really suggest just buying a whole new 32H wheel. Look around the classifieds here, or on Pinkbike if money's an issue.
    i didn't even know they made 48h. youd be best buying a set of used Outlaws off pbike for $200. can be found for less if youre diligent
    May 2013
    Found a complete new wheel for 130. I should stick with SAS as they have lasted a few years now and are still perfectly straight
  1. transition tr450
    By invol2ver in forum Downhill - Freeride
    Last Post: 08-02-2013, 06:42 PM
  2. new transition tr450
    By rzalewski6 in forum Transition Bikes
    Last Post: 07-30-2012, 10:12 PM
  3. Transition TR450, what's the scoop?
    By Johnny No.5 in forum Downhill - Freeride
    Last Post: 03-07-2012, 06:08 PM
  4. Custom 2012 TRANSITION TR450
    By Villas in forum Transition Bikes
    Last Post: 01-24-2012, 10:01 PM
  5. TR450/Raceface Atlas/E13 SRS+ fitting
    By scarlet in forum Transition Bikes
    Last Post: 07-31-2011, 05:49 AM
