Results 1 to 34 of 34
    Reputation: bullcrew's Avatar
    Jan 2005
    FED EX delivered today! TIRES!!!! UST/DH/FR
    Although it was a battle I won, i traded the gremlin a box for the goods!
    UST 26x2.4 big bettys, dh and fr casing muddy marys!
    They have a big profile probably that like a kenda, a 2.35 sizes to a 2.5 maxxis! fr casings are light and a good sidewall as well as the ust is a good cross between fr version and DH casing.
    look forward to rocking them (after snow melts again )
    gremlin
    gremlin and his loot
    muddy mary left big betty right
    mounted
    ust BB and dh MM
    muddy mary close
    Weights pics incldue a minion and a nevegal for referrence of weight:
    Muddy mary 26X2.5 triple nano DH casing 1245g
    Maxxis minion 26x2.5 DHF 3C 1402g (mind you this is 1/4 worn off as well)
    Kenda nevegal 26x2.5 StickE DH 1495g
    Big Betty 26x2.4 UST 946g
    Muddy Mary FR 26x2.35 855g (this 2.35 is a smidgen heavier than a single ply Kenda or maxxis 2.5 but also a bit thicker sidewalls so its more durable as well)
    The last 2 Ill post pics when server isnt busy!
    MUD UPDATE!
    I took them out as the snow 6"+ melted overnight making for some super slick thick gooey clay mud! Walking on any sort of incline is damn near impossible as your foot sinks 2-3" in and squirms towards and decline! However riding was WAY BETTER than I initially thought!
    When i first rode the muddy mary in some mud i had a almighty on the rear (low profile pedaling.brake tire) and it hooked but not stellar! I have however rode my minions in this brown POO before and they worked better than the nevegals which made me happy! Yes the minions slid and were back and forth on the trail as well as when cornering the bike would start to pack and wash out making you slow and gett rid of any lean you have to keep the weight vertical to the ground!
    The Muddy Marys hooked up, now in this stuff Id have prefered a black shark 2.1 mud tire specifically but the Muddy mary did WAY BETTER than my past tire choices in this stuff! In corners I could actually start to lean and lay the bike more horizontal on a flatter muddy corner as well as I had to pop the rear sideways to get it to slide out and even at that it still hooked up right off the bat! I did not do any drifting, I did some sliding and they were throwing so much mud on corners and straights cleaning themselves it was as if it was full traction all the time. I found that when I slowed to take a pic that over 3/4's of the tread still shed mud even at lower speeds!
    I did not ride are courses just the single tracks coming off the hills for speed and corners, I did pedal up and they were fine. ALOT less rolling resistance in the rear and when I hit the parking lot I was laying the bike over hard to see if i got any outer lug folding or washing and none that I could tell. On pavement they rode great, there was less rolling resistance or sticking to the ground then the kenda StickEs or 3c minions had and they felt easier to pedal even with a bigger profile!
    Conclusion: Even with this tire being out of its element in this thick and nasty of mud it performed above expectations and held lines really well. Had little to no side to side washy feeling and it shed the mud right off the bat! So I can say without a doubt that they perform on mud really well, there are better tire choices for this (mud/goo) but they are MUD specific tires!
    Start of ride out by gate, mud is thin but slick and packing.
    Gumbo mud, almost wiped out several times gtting off the bike here didnt realize it was that slick. The bike was hooking up so well I figured it couldnt be that bad! Wrong it was nasty slick and thick!
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
    Bottlerockin'
    Reputation: coiler8's Avatar
    Could you weigh them for us weight weenies? They look great!
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    Whoah you won a kid on eBay? Isn't that illegal?
    Northstar 2008 Riding Crew
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    Quote Originally Posted by Raptordude
    Not if the manufacturer "accidentally" sends it to you...
    ...and not if it's wearing a hat.
    Meh.
    GAME ON!
    nice stuff. were they freebies? also, if you don't end up using some tires, let me know! wouldn't mind a fr casing to replace my dh casing
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    EastBaySteez
    Reputation: Freerydejunky's Avatar
    Those tires look very slow rolling.
    Huge flat edges.
    Gamut
    Team Evil
    Formerly: motormonkeyr6
    GAME ON!
    Quote Originally Posted by motormonkeyr6
    Huge flat edges.
    you're slow rolling
    RIP Adam Yauch
    EastBaySteez
    Quote Originally Posted by saturnine
    you're slow rolling
    Only on tuesdays
    Gamut
    Team Evil
    Reputation: MTB_prodigy's Avatar
    big betty, muddy mary?
    wierd names
    Jan 2005
    Weights are up!
    Kenda had Hamsters this season, Maxxis was cats and schwalbe was little kids. I opted for the free kid!
    They are one of my sponsors!
    My Sponsor House
    which of the tires would you recommend for a front? would be replacing a tubed 2.5 nevegal (would run it ghetto tubeless)
    Bottlerockin'
    Thanks for the weights bullcrew -- I hope I'm not the only one who found that useful...The UST casing is sturdier than single-ply, but not quite as hardcore as the dual-ply you say?
    Jan 2005
    Quote Originally Posted by coiler8
    No ? about it! Its beefy but lighter than DH stuff and heavier than single ply! Its 100g heavier than fr version (mainly sidewalls tread is beefy) so its a perfect set up!
    Im doing Big Betty rear and Muddy mary front for loose over hard pack Socal stuff and probably big bettys front rear for sea otter!
    The triple is great for the rear and a gooey gluey front!
    I have my Muddy Mary done stans right now and the UST big betty is also stans (rim strips front and rear as well as sealant).
    They work just fine this way, I rode teh MM for a few days and Hammered it HARD, no burping! It stuck like it was on rails in loose over hard!
    Wet/mussy or dry and semi loose over hard Muddy mary front rear
    dry bone dry and no real sand but rocks then Big betty rear MM front possibly 2 big bettys!
    Either way they are both great tires and I know first hand the Muddy mary hooks up and rode with my buddy bobby root he had big bettys on and slayed idyl wild! Loose over hard, sand pebbly washed out tons of off camber roots with dust and rocks! Super beat down trail and I was having issues with maxxis minion DHFs on it and he wasnt!
    My Sponsor House
    where can i get schwalbe tires on-line?
    is the 2.5 wayyy too big? and the 2.35 is about right? kinda what i have gathered from reading some threads..
    moaaar shimz
    Reputation: tacubaya's Avatar
    Chad at Red Barn Bicycles
    Glad to Be Alive
    nice swag
    weight makes them very interesting
    Jan 2005
    Quote Originally Posted by SHIVER ME TIMBERS
    nice swag
    1st Hope all is well B!
    Yeah the best part is my kid, he digs anything bike related! The tires are pretty damn slick, Im riding tomorrow in the mud/slush and snow to see how well they hook up! The Minions were CR@P last week in the soft and mud, rear was all over and spinning when pedalling! Granted its not a mud tire but I wouldnt use that thing in wet conditions, doesnt shed at all!
    Thw weights are great, love the fact they have burly sidewalls, stiff and square edge profile! Its a bonus on the weight, I can clearly without a scale hold my minion in one hand and my MM in the other and feel a good difference!
    My initial thoughts though are that for my riding style a square edge profile is better in most cases as long as its not XC, Maxxis has been doing square for a long time and schwalbe does it as well. I can feel the difference between maxxis and nevegals in the loose and corners. Then the schwalbe against the minion and there was a boost of confidence with the schwalbe. My assumtion is the square profile matched with the volume made for a better cornering tire with better grip! + its lighter than a 2.5 minion so theres no penalty in weight just a bigger square version tire!
    My Sponsor House
    Jan 2009
    800 od grams for a Big Betty FR? pair of those would drop at least 1lb off the session, and ive been meaning to try these Schwalbes for a while now! think ive decided on my tyres for the '09 Season! will pick some up when i get back from america i think.
    Jan 2005
    Quote Originally Posted by Muttely
    Yeah Im anxious to see how much the bike weighs when I go down to fr set up for certian courses! The jedi weighs 38.6 with maxxis DH casings and the 66rc3 or 888wcata (same weight).
    I could shave 1lb in fork by going boxxer wc and another 2.5lbs off from minions to fr muddy marys putting the jedi in at 35.1lbs. Hadnt put those #s together yet, thats a sea otter rig right there!
    Im definently building the Chumba Evo with muddy mary (fr gueyglooey) front and big betty (fr triple nano) rear.
    They are thicker in the sidewalls then the kendas are in single ply, the snakeskin keeps the sides from tearing with the cross weave pattern!
    Hope your getting some riding in while you are over here!
    My Sponsor House
    Jan 2009
    Will be Ski'ing in Tahoe so no riding to be done, one can wish though! god by the time i get to summer this sessions going to be filthy weights. and all im doing is ditching the bonty! hah
    Jan 2005
    Yeah rotational amss is huge. 1lb feels like a whole new bike. Pedals easier accelerates faster cornering and braking too!
    Pics when you get back!
    Have fun skiing and tear it up!
    My Sponsor House
    Woah that's gnarly to think that i live 30 minutes away from tahoe and never get near it except for skiing yet people come from completely other countries just to check see it!
    "Ride Life Ride Giant"
    Carb free mofo
    Cool, the UST option sounds pretty good. Do you have to keep checking USTs to make sure they are running okay? I've never run them as it seems like hard work.
    I don't suppose anyone knows the weight of the specialized chunder 2.35?
    In the future, there is only war.
    Jan 2005
    Went and rode in gumbo mud today, to put it lightly it was easier to ride then walk!!!! It was brown POO!!!!!!! Tires hooked up great, shed the mud way better than I though. I have a pick Ill post of half the tire shed and some still stuck and thats coming to a stop so no cectrifical force to spray it off just good ol lug placement and no place for mud to hang on!
    My Sponsor House
    7MGTE
    Reputation: supramk388's Avatar
    Quote Originally Posted by bullcrew
    I have been using the BBs on my Canfiled One. How is your clearance on the Jedi?
    Jan 2005
    Quote Originally Posted by supramk388
    Really close, Im running the 2.35 Muddy mary rear and its right there with a minion DHF 2.5.
    I couldnt get any bigger than a 2.5 maxxis and the schwalbe/Kenda sizes are 2.35.
    My Sponsor House
    Jan 2005
    Mud update from today up on bottom of first post!
    My Sponsor House
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    At $80 a tire the better be the best tires in the world......
    Curious to try them out, but not at cost.
    I'd rather have a bottle in front of me than a frontal lobotomy.
    How do 2.35 muddy marys compare to 2.5 nevegals?
    Go BIG or Go HOME
    moaaar shimz
    Quote Originally Posted by DHGnaR
    Red Barn Bicycles dawg.....
    Jan 2005
    Quote Originally Posted by CountryBoy
    A 2.35 schwalbe to a 2.35 kenda = almost the same, the schwalbe is a hair under. So little its easier to say they are the same size or real close. The 2.5 schwalbe and the 2.5 kenda same thing size for size they are rpetty spot on!
    Thats the only similarity though, the Schwalbe hands down corners better, hooks up better sheds mud better and is lighter than the kendas. I like Kenda raced and rode them for a couple of years. The Schwalbes are in a different league then Kenda BGs or Nevegals and they are lighter as well with true anti rim slip on bead. Asthetics are better, quality is phenominal and they ride great!
    I still have a bunch of KEndas that Im presently selling off and sticking on the kids bike!
    My Sponsor House
    Thanks bullcrew. I have access to schwalbe for a great price and was thinking of trying the muddy marys. I want to run 2.5 front and 2.35 rear. So I was thinking of getting the 2.5 single ply and 2.35 UST but not sure on the durablity. How well do they seal up tubeless?
    Go BIG or Go HOME
    Jan 2005
    Just fine, I have the big bettys UST on my Chumba Evo ghetto tubeless on the rim side of things and I have the Muddy Mary fr/DH version on the Canfield Jedi also set up Stans tubeless kit with the stans sealant as well.
    Works perfect!
    My Sponsor House
    hey bullcrew, i give a tray to this beast's!! 1x 2.5 1x 2.35 !!
    ride.
