Page 1 of 2 12 LastLast
Results 1 to 100 of 162
    Glad to Be Alive
    DVO SUSPENSION Emerald Review...
    Been riding mine for 2 weeks and this is what I have so far. Trails have been bumpy, rockgardens, and turns. No drops so far. Will have more reviews in a few more weeks. Plus two other rider reviews.
    Background:
    I like to set my fork up super soft. The only problem with that is the fork dives in the corners. If you make your fork stiff then you lose small bumb sensitivity. Fork will bounce through the chatter. It is hard to find a balance between brake dive and small bump sensitivity.
    The Emerald solves that problem. you set your fork a little stiff (at least for my riding..then they have this knob on the top left of fork (Called OTT=Off The Top) that you turn in...(This is important because I went wrong way in beginning). You think logically you would back off...but you tighten the OTT for more small bump sensitivity...and oh Nelly !!! this softens up the first few inches of travel...so you get the small bump sensitivity without brake dive into corners.
    What I have found so far. Is the fork tracks amazingly through the chatter. You don't feel the arm pump as much because the fork absorbs the bumps like crazy. Very nice feel in heavy rock gardens.
    Cornering is a new story for me. I am use to brake dive because the way I set up forks soft. So it took me a few runs to get use to it. (ok more then a few) because I was "springing out of the turn. First thing is when you trust the fork you can feel the momentum coming out of a bermed turn. So you actually ride faster because of this energy carries you to the straitaway.
    So far I love the fork. The cons are the price and the weight. The weight is 7.11 pounds, but honestly, you don't feel the difference of the added weight. I understand why DVO made the fork a little heavier then most forks. DVO can't make something very lite because if it failed then they would be out of business. The price is up there too, but I remember complaining buying a 500 dollar bike and now I buy over $5,000.00 dollar bikes. If you told me 13 years ago that I would be spending that kind of dough I would have laughed. Hopefully they can get a better pricepoint when more are available.
    Sidenote 1: compared to the Dorado. The Emerald is stiffer and more plush. Plus in 2 years of research the Emerald hasn't had one seal go bad - like some other forks
    Sidenote 2: I always compare things to a Shiver because they were so plush. I said things like it feels plush like a Shiver. This fork is better then a Shiver...way better. I found my home.
    Attached Thumbnails Attached Thumbnails DVO SUSPENSION Emerald Review...-bobv10.jpg
    Quote Originally Posted by SHIVER ME TIMBERS View Post
    Been riding mine for 2 weeks....
    ........ Plus in 2 years of research the Emerald hasn't had one seal go bad - like some other forks
    The fork just came out and you've only had it for 2 weeks, so how can you come up with that conclusion?
    Glad to Be Alive
    Quote Originally Posted by the-one1 View Post
    asked Ronnie at DVO.....that is why I wrote 2 years of research
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    Which other forks that fouled seals during their "two years of research" do you speak of?
    I'd rather have a bottle in front of me than a frontal lobotomy.
    Glad to Be Alive
    Quote Originally Posted by DHgnaR View Post
    boxxers, dorados
    Crank Brothers Kronolog also was perfect in its "years of research".
    Just saying during "research time, they won't disclose what went wrong. Everything is good and working
    bg.
    bg. is offline
    Reputation: bg.'s Avatar
    Ronnie at DVO knows his shit. If he says two year no failure than that's what it has been.
    bg.
    bg. is offline
    I'm looking at this fork or the Marz 380.
    Price isn't the problem, but the weight difference is. What I'm looking at is 3250g (Emerald with brace) vs. 2750g (380). That's a 1/2 kg difference (more than 1lbs).
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    The DVO uses almost identical seals as the Dorado does.
    Also, if you're worried about a pound on a DH fork, you got your priorities all out of whack.
    Reputation: ianjenn's Avatar
    Quote Originally Posted by Gemini2k05 View Post
    You would be surprised what Cat 1 Mid pack racers are worried about on their DH bikes. Forget the fact they wouldn't have stood a chance in Semi Pro but they can barely get a top 5 in what is Expert. but they are sure a 3LBS bike will make them better than NICO ever was.....
    Glad to Be Alive
    you don't notice on bike (at least I don't) feels the same as lighter forks (but it is hard to feel a 10 oz difference while riding - 888 ti vs DVO Emerald)
    Glad to Be Alive
    so what you are saying is not the same but almost identical???
    Glad to Be Alive
    Quote Originally Posted by ianjenn View Post
    true true...people are crazy about weight but won't train
    bg.
    bg. is offline
    I agree that weight isn't everything, but 500g isn't nothing either.
    I would probably notice the weight more than I would notice better suspension performance, when compared to a 380.
    Living the High Life
    Reputation: Ithnu's Avatar
    Feb 2007
    My Dorado feels lighter than the 888 and 40 I've had. They are pretty much all the same; 6.75 lbs or so. The invert gives less feed back/force/whatever on bumps as there is less weight bouncing around on the wheel side of the suspension.
    Too bad that DVO is so expensive. Looks like a great fork.
    You have just been mentally Rick Roll'd. Yup you're thinking about it right now aren't you? Don't fight it.
    Glad to Be Alive
    Quote Originally Posted by Ithnu View Post
    my 888 ti weighed 7 pounds 2 ounces with axle, and stem. The Emerald weighed 7 pounds 11 ounces
    agree on feed back...less unsprung weight
    I am selling my Fox 40 Float will replace with an Emerald and do a review of it while I have it. Going with a Black version for the baby blue G2.
    Uphill? What's that
    Reputation: Rob-Bob's Avatar
    Sweet looking ride you got there SMT. What handle bar is that.
    Glad to Be Alive
    Quote Originally Posted by Rob-Bob View Post
    Already have some different parts like a CCDB and Ti Spring for shock
    Those are Azonic Flow bars
    Azonic Flow 800mm 1" Rise Handlebar > Components > Handlebars and Stems > Mountain Bike Handlebars | Jenson USA Online Bike Shop
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    maybe it's the angle, but that looks like a whole lot more than a one inch rise...
    Reputation: dytrdr5's Avatar
    Mar 2006
    Thanks for the review, I should be getting mine later this week. On a side note about Dorados my friend's fork which is barely 6 months old is leaking oil bad from both legs. I also had a shiver back in the day and it will be nice to see how they compare to me.
    Uphill? What's that
    Quote Originally Posted by .WestCoastHucker. View Post
    That's why I asked about them , they look like they have 2" of rise in that picture.
    Pro Crastinator
    somehow i knew that "plush" would be pretty much the extent of your review. i have to admit, you are quite the wordsmith...
    Jun 2013
    Background:
    Disagree completely with that one. You can set a fork up to be stiff and have support while retaining its small bump, it may be harder to do with external adjusters for some people, but its possible and once you crack open the fork and adjust the shim stack its very possible.
    sounds good though, been keen to hear a long term review of it. More importantly if you still have the old forks do some back to back timed testing to see if it improves your times.
    The OTT is cool though essentially its a negative spring that it adjusted independently of the rest of the forks pressure.
    Good site with some quick explanations of the fork
    Video: Get Up Close With the DVO Emerald
    Reputation: Fix the Spade's Avatar
    Has any manufacturer ever gone 'Oh Hell we broke like a million of these things in testing,' when asked how their new product performed during development?
    Quality looks fantastic on the DVO fork, but to me '2 years of research and no failures,' should be read as '2 years of of inappropriate research,'
    Like the Challenger's SRB O Rings always passed the testing without failure. Not that DVO is anything like NASA, it's just the best example of research and development failing to reflect reality I can think of.
    Dorado owner here
    I can attest to the leaking seals. I love the feel and adjustability, the seals are junk though. Hayes Manitou customer service is Bad. They won't even return my calls.
    Great to hear you are loving the DVO, never hurts to have more quality players in the suspension game.
    Off the back...
    Reputation: pinkrobe's Avatar
    Wow, these things are tough to find north of the 49th. One Alberta dealer in Edmonton (eww), 2 (!) In all of BC. I'm going to have to smuggle one in from the US...
    @pinkrobeyyc
    #pinkrobeyyc
    Glad to Be Alive
    Quote Originally Posted by dytrdr5 View Post
    IMO ...Way better then the Shiver ...way better
    Glad to Be Alive
    Quote Originally Posted by Fix the Spade View Post
    They been testing the fork for over a year and a half....they could have released it, but wanted to make sure everythinbg was up to par as far as duralbilty and such. I can trust Ronnie...He told me a lot when 2 Marz 888's broke at Red Bull Rampage
    Ricky DH
    Reputation: rep_1969's Avatar
    Your last paragraph is what I was waiting for. I too, was a hard core Shiver fan, and nothing since that fork has felt as plush. I may have to look into one of these. Thanks for the review. Keep us posted as the season progresses.
    [QUOTE=SHIVER ME TIMBERS;10988825]Been riding mine for 2 weeks and this is what I have so far. Trails have been bumpy, rockgardens, and turns. No drops so far.
    Your homeowners association called. Your neighbors are complaining about your riding on the landscaping, and leaving skid marks on their lawns, and riding in the neighborhood after dark without reflectors...
    When are you going to take that thing out for real ride, put on a few scratches, and some dirt!
    The guy yo' momma "act" like she don't know!
    Feb 2007
    Quote Originally Posted by ringoesroadking View Post
    Dorado owner here
    Did you store the fork upside down? I did that for a few months and my seals went to poo. Sent it back to Hayes for the 1 year free service and it's fine now (as I store it the way the instructions say to).
    Reputation: mullen119's Avatar
    I literally laughed out loud when I read this. A few test forks didnt leak oil.... good to know. Lets wait and see how the seals perform in the field before statements like this are made.
    Side note, you cant store Dorados upside down(that means hanging too). Most people dont know this and the seals start leaking after 6 months. Properly taken care of, the seals last a few years.
    bg.
    bg. is offline
    Quote Originally Posted by mullen119 View Post
    We're all so used to crap seals.
    Back in the day a Shiver would go 2+ years on the same seals no problem.
    Quote Originally Posted by bg. View Post
    I have gone 4 years on a lyrik, 3 on a manitou minute, and am going on 3 on a revelation. Not a single drop has leaked out. Proper maintenance keeps forks alive for a long time.
    That was a good read. OP: Thank you for the review.
    Fast lookin' Slow movin'
    Pro Crastinator
    i ran a 2000 Monster T untill 2007 without a single issue. just changed the oil every summer. not a matter of "proper maintenance", marz forks are straight up 'set and forget' and we are all aware that it's the norm. their forks just last forever compared to any other offering out there. sure your forks may have lasted minute with all that maintenance you did on them, but marz owners never have to touch theirs and they still last longer...
    Glad to Be Alive
    yeah had a 2002 Shiver till 2006...just changed the oil every year...never did anything else....they just last without replacing seals or other stuff
    Pink bike blew a seal in their test........
    My point is that saying a fork that has been out for a few weeks has great seals is a ridiculous statement. Only time in the feild can determine this. Not a good start in the field when a seal blows during a test. They may turn out to be great, but we wont know for about a year of real world testing.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I just read that. What they wrote was that a seal had gotten folded over during assembly. It didn't blow.
    Quote Originally Posted by evasive View Post
    Doroados had a guy installing the oil seal upside down for a while making them go bad quicker. Thats life. Leaky seal is a leaky seal.
    What does that matter to the end user? They still have to jump through all the same hoops of bad seal. Seems like they're having QC issues with assembly already, on a test fork designated for an write-up lots of people will read none-the-less....
    Also, I'm not trying to bash DVO here, every company has their growing pains and seems like DVO has a strong first showing anyways. I just like messing with Bob and all his "super-informed reviews..."
    beater
    Feb 2005
    To that particular end user, it doesn't matter at all, obviously. But to the overall pool of end users, I think it makes a difference whether you're looking at an error in assembly versus a design flaw or a bad batch of seals.
    Never store the bike upside down. The only time the fork is upsidedown is when its hanging from a lift by the front wheel? I wonder if lift time could be causing the seal leak? Doubt it but you never know
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Well, that's just wrong. That will expose a leaky seal but won't cause one.
    Feb 2007
    Quote Originally Posted by whodaphuck View Post
    Actually it will cause a leaky seal. It says right in the Dorado instruction manual not to store it upside down.
    Pro Crastinator
    whodaphuck is correct. although a dorado stored upside-down will leak, it's because the ability to leak is inherent in the dorado's design no matter which way it's stored...
    This is correct. Dorado seals will dry out and get small cracks if not kept wet. Storing upside down for weeks at a time is big no no with them(as stated in the manual). Generally speaking, if kept right side up, the seals will last a reasonable amount of time.
    Hanging upside down for short periods of time is no big deal, the problem is only when stored upside down.
    Will write some thoughts in next few weeks.
    Pro Crastinator
    you got a stick in your rear triangle. might wanna have that looked at...
    Hey don't make fun of my ghetto stand. I just dumped 2 weeks pay on a bicycle fork!
    Pro Crastinator
    it was worth it. that bike is the hottest thing i've ever seen...
    Mar 2006
    Here is mine, loving it so far
    Glad to Be Alive
    sweet...how you liking it...pm me if you want set up tips
    Reputation: B-Mac's Avatar
    That's one sweet looking fork!! Really dig the black one on your setup SMT!!
    Check out my You Tube Channel
    Off the back...
    Any more reviews?
    @pinkrobeyyc
    #pinkrobeyyc
    RideDirt
    Reputation: aedubber's Avatar
    Forks look good guys , i sure did love my Dorado on my Demo 8 .. Was an amazing fork , wonder how this compares to it. I had the bad seal issue , they replaced them right away for me with no questions asked. Customer service was good , no complaints here.
    Dec 2004
    What I like in the initial post is the fact they didn't want to build it super light and risk parts failing. I like that a lot! More and more companies are trying to make things 'light' and disposable.
    And even then, most forks are in between 6 and 7lbs. You won't feel that extra half pound or so.
    Are you able to service things like bushings yourself?
    Intense 951 Evo and Intense Carbine 29
    nice
    ride.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    The way i read it is DOV has been testing it for over 2 years and haven't had any issues. Is this a correct statement?
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Glad to Be Alive
    Quote Originally Posted by 8664 View Post
    hey nice review and bike setup.. thanks.
    what is with the air volume for 95kg 85psi like manual or?
    Watch out for the air pumps...they tend to run a little high....that being said I am 205 pounds and run mine 78psi.....with turning IN (yes Turning in) my OTT 8. also high and low speed compression backed all the way off
    Glad to Be Alive
    Quote Originally Posted by shwinn8 View Post
    nothing except for Ronnie accidently folding seal for the vital test...
    Feb 2006
    Copy copy... I think some of the others replies were based off the thought it was only tested for 2 weeks with no blown seals. Sounds like a bad as fork, no funds for that kind of an upgrade just yet. Although only ridden about 5 times by me the boxxer race that came on my Jedi seems to be holding up. The previous owner I think had it serviced prior to selling it too. Time will tell the tail!
    '11 Jedi
    nice
    ride.
    Rollout done, 100% what i have expectet! Ride high in corners and steep gnar, super plush for chatter stuff, nice fork. Now i get same perfect suspension in front like i have in the rear! #dvosuspension #canfieldbrothers
    Attachment 895805
    My v.2014 is getting a Woodie resized from the v.2013/12/11. Fork will arrive some time next week... I'll update if the Avy is the magic carpet you'd want.
    Glad to Be Alive
    welcome to the club.....a lot of people make mistakes setting fork up...pm me if you want any set up questions
  67. #67
    My dvo emerald setup is
    97kg ride ready
    85psi
    Lsc3
    Hsc5
    Ott 13 turns clockwise
    Rb7
    All clockwise.
    ride.
  68. #68
    Glad to Be Alive
    97kg ride ready
    85psi
    Lsc3
    Hsc5
    Rb7
    All clockwise.
    I would try 80 PSI ....gives the fork a softer feel (more small pump sensitivity) ...that is if you are not bottoming out
  69. #69
    Yes, rigth.. Stay on the race track now and was going down to 85psi much better!
    ride.
  70. #70
    Glad to Be Alive
    try differnt pumps too...the pumps are not accurate
  71. #71
    if i messure all time with the dvo pump its ok...
    ride.
  72. #72
    nice
    ride.
  73. #73
    Aug 2010
    Haven't gotten a chance to ride mine but if it is half as good as the service I recieved from Ronnie at DVO then I will be more than pleased. Had an issue with my fork and they are taking full care of it with no hassle. So far I am a huge fan..
  74. #74
    Glad to Be Alive
    sweet..............
  75. #75
    Quote Originally Posted by meSSican View Post
    where you build in the dvo..? i seen on pinkbike that you sale the black green jedi frame?
    ride.
  76. #76
    Aug 2010
    Yes I do have the Jedi for sale on Pinkbike.
  77. #77
    nice
    ride.
  78. #78
    Aug 2010
    I bought a 2014 Jedi, but have not gotten a chance to ride the fork or the frame yet.
  79. #79
    nice
    ride.
  80. #80
    Off the back...
    Mine arrived today... at the wrong house! I was checking the package tracking online and just about shat myself when I saw that it had been delivered 30 minutes prior. Ran to the front door - no box. Checked the side gate - no box. Went one street over - thar she be, leaning up against the front door of somebody else's house. Checked the shipping label to make sure somebody else didn't order the exact same fork as me, but 'twas mine.
    Should be able to install this afternoon. Any pitfalls I should be looking to avoid whilst installing this magic boinger?
    @pinkrobeyyc
    #pinkrobeyyc
  81. #81
    lucky guy! :-)
    ride.
  82. #82
    Aug 2010
    Quote Originally Posted by pinkrobe View Post
    May wanna remove your trousers to install.....I blew the front outta mine when I saw that baby mounted up.
  83. #83
    Glad to Be Alive
    crazy......
  84. #84
    Tapered steer tube=RETARDED that's about it.
  85. #85
    CK i7 headset...
    ride.
  86. #86
    Off the back...
    Installation was a breeze. My Aurum has a tapered HT, but came with a spacer-thingy to work with the straight steerer on the stock boxxer. Dumped the spacer, dug out an old Cane Creek crown race, works fine with the FSA headset. 20mm spacers above and below the crown so I have room to raise/drop the bar if I want, but currently at stock height. Obligatory phone pic:
    Can't wait to get it out on the trails, which are presently soupy mud after three days of rain. Next week...
    @pinkrobeyyc
    #pinkrobeyyc
  87. #87
    nice.
    ride.
  88. #88
    Right, so first day on a '14 Jedi w/ an Emerald. I cannot even begin to describe how well this fork performed! I'm 197 kitted up and I've got 23% sag at 70 psi. I used an everything wide open base tune (manual called for no HSC or LSC as a starting point, and the rebound felt like there was really good control wide open also) paired to the Jedi's CCDB base tune. UNreal! The only time I managed to come to near bottoming was a front wheel landing off an ~8ft drop! If the fork had flex/twist, or the additional heft of the extra pound, I didn't notice it. It felt very balanced on the Jedi.
    Prob a saying that's been beaten to death, but the fork tracks like it's on rails! And SUPPLE! Once it bedded in...after the 2nd run...it feels better than a Pike! Never had a Shiver...my exp w/ USD forks has been a Hanebrick LT8 and a Mr Dirt Fat fork...but I wouldn't listen to the naysayers about the drawbacks of USD forks w/ this one.
    Get one! You'll have kittens how well it performs!
    Disclaimer: I'm not in any way tied to DVO. Oh, BTW, their customer service is spectacular! Thanks John Pelino for all your help!
  89. #89
    Glad to Be Alive
    sweet ride Paully !!!!....it is crazy what an amazing fork the Emerald is...
  90. #90
    nice
    ride.
  91. #91
    Off the back...
    Rate my Emerald tune:
    weight - 180 + gear
    skill - total hack
    i only ride - park [plus a little bit of gnar]
    am flustered by - drops, braking bumps
    air - 75 psi
    OTT - 6 turns
    rebound - 4 clicks
    HSC - 17 clicks
    LSC - 12 clicks
    @pinkrobeyyc
    #pinkrobeyyc
  92. #92
    weight - 180 + gear
    skill - total hack
    air - 75 psi
    OTT - 6 turns
    rebound - 4 clicks
    HSC - 17 clicks
    LSC - 12 clicks
    pinkrobe,
    Are you counting your clicks from open (maxed out CCW) or closed (maxed out CW)...?
    So, for Trestle which is mostly jumpy high speed flow trails:
    197 kitted up
    70psi = ~24% sag
    almost no OTT
    rebound - wide open, CCW maxed out
    HSC - 2 or 3 clicks in from wide open
    LSC - wide open (will add two clicks in for old skool DH chunder plowing)
    BUT, I'm on a Jedi and kinda ride a bit rear wheel biased on the jump trails.
    I'd like to change up the oil viscosity a bit to see if I can shift my settings to the middle of the dial detentes some...the fork feels juuuuuuust a touch overdamped for my hack-tacular skillz
  93. #93
    Glad to Be Alive
    weight - 180 + gear
    skill - total hack
    air - 75 psi
    OTT - 6 turns
    rebound - 4 clicks
    HSC - 17 clicks
    LSC - 12 clicks
    I like soft
    73 psi
    HS and Low speed compression...all the way open
    OTT 9 turns
    rebound 4 clicks
    really eats up the brake bumps and chop
  94. #94
    Off the back...
    Holy crap, looks like wide open is the new black!
    All my settings are from wide open. Looks like I should back off on the compression... I'm heading to Silver Star soon [mostly flow + jumps with lots of bumps]. I'll be there with my wife, so I should have a little time to mess with the settings at the end of each run.
    @pinkrobeyyc
    #pinkrobeyyc
  95. #95
    Have to correct my previous post. I had it at:
    HSC: 4
    LSC: 0
    LSR: 1
    OTT: 45/90 clicks
    75 PSI @ ~21% sag
    I was a touch divey when I was running old skool chunder DH. I'm gonna try to bump up my compressions a bit, and back off the OTT a hair.
    HSC: 5
    LSC: 5
    LSR: 1
    OTT: 35/90 clicks
    Still quite open...
  96. #96
    I change back to dorado, the dvo is to heavy for quick move or manuals and to much compression, even the HS -LS knobs are FULL OPEN...
    ride.
  97. #97
    Professional Troll
    Apr 2005
    Stock tunes are TERRIBLE on the DVO. Way too harsh. It's an easy fix though. Additionally the reduced offset on the DVO makes it significantly better for "quick moves" and turning, not harder. Sounds like you need to hit the gym if the fork is too heavy for you.
  98. #98
    Glad to Be Alive
    I change back to dorado, the dvo is to heavy for quick move or manuals a...
    I challenge anybody to feel the difference of a 3/4 of a pound when riding....seriosly it is all mental....you weigh on a scale and see difference but you can't tell on the trail at all....
    mental
  99. #99
    Yes, but hate gyms"..... No, its a good fork but there are also more playful forks out.. I test the dvo now with 80psi hsc1 lsc1 ott 10 turns... I am 210lb hope it works.. The rigid of the dvo is unbeatable !
    ride.
  100. #100
    Glad to Be Alive
    start with a little lower air pressure (70 to 75)...believe me that is the rick to get this fork to come alive...I weigh 210 also and wear full armour and huge back pack...probably in the 225 range and I run 73psi...believe me it is awesome
    hate the gym ??? ...me too...but I wish I would have started doing it earlier in my life....it really helps with bike riding and keeps you strong thoughout the day. You don't have to even lift that much...I workout and bench 125...that is it ...just trying to stay fit....I work on back, legs, chest, arms and grip...(grip is mostly looking at porn at night and etc)
  1. How you like me now....DVO Emerald
    By SHIVER ME TIMBERS in forum Downhill - Freeride
    Last Post: 01-22-2014, 08:39 AM
  2. Schwinn Rocket Comp Full Suspension Review
    By getagrip in forum Beginner's Corner
    Last Post: 07-31-2013, 04:56 PM
  3. Emerald Outback ride route
    By swoodbrn in forum North & South Carolina
    Last Post: 04-26-2013, 02:42 PM
  4. Emerald Outback Trail?
    By LBIkid in forum North & South Carolina
    Last Post: 09-28-2012, 06:58 AM
  5. Full Suspension 29er Tandem Review
    By ds2199 in forum Tandem Mountain Bikes
    Last Post: 08-21-2011, 01:25 PM
Members who have read this thread: 8
