DVO Suspension
Printable View
  • 12-25-2012
    ianjenn
    Interested to try one hope it handles the chop as well as the dorado and has its same reliability.
  • 12-25-2012
    Gemini2k05
    I've heard the chasis on the DVO is stronger and stiffer, more material all over. Additionally I think they are using essentially the same seals. So chassis reliability should be as good or better all around.
  • 12-25-2012
    SHIVER ME TIMBERS
    I am not 100% but I would say the stanctions are bigger then the dorado
  • 12-26-2012
    Gemini2k05
    Possibly, but that's not what I had in mine. things like taper on the upper legs, wall thicknesses, bushing overlap, etc. Those are all gonna be a bit bigger on the DVO than the Dorado I believe.
  • 12-26-2012
    saturnine
    i would've liked to see the gap between the two arches filled in so it acts as a built in fender. wouldn't add much weight and could prove to be pretty useful. and if not done to all, then at least done as an option.
  • 12-30-2012
    SHIVER ME TIMBERS
    I will pass that on:thumbsup:
  • 12-30-2012
    rep_1969
    Yeah, that would probably also make the brace even stronger, and easier to manufacture. I'd also hope they make an natural silver option as well as the green and black.
  • 12-30-2012
    csermonet
    the silver would be a good addition to the green and black. in a perfect world, they would offer custom color anodizing on the silver cnc'd parts. decals to match whatever color combo you choose.
  • 01-01-2013
    BigHit-Maniac
    I cannot wait to see what they wind up coming out with in the 180mm Single Crown category eventually.
    More forks need to be PLUSH. Fox's feel so full of stiction it's ridiculous.
  • 01-02-2013
    raman503
    is that the brake hose guide? pretty trick.....
  • 01-02-2013
    SHIVER ME TIMBERS
    nah...that hasn't been addressed on first forks...they are trying them out to see where it is best for brake line
  • 01-02-2013
    Jumpcaser
    agreed! with the zoke 66 not available in the future I'm hoping they fill that segment. Not sure if USD design is the ticket for a 7 inch single crown...
  • 01-02-2013
    SHIVER ME TIMBERS
    wait to Sea Otter ....
  • 01-02-2013
    csermonet
    My 40 has very little stiction, if you keep your foam rings soaked in oil and pack the void with slick honey, and have the new skf seals, it's a drastic improvement.
  • 01-02-2013
    BigHit-Maniac
    Ride a Fox fork in a desert environment for any length of time, and you'll know what I mean. LOL.
    The Zochi I had on my Versus that I just sold not too long ago was the plushest thing ever. My Fox on my Specialized has been rebuilt twice, and still feels like a sticky pile of poop after only a few months on a fresh rebuild. (32 Float on my XC bike).
    Short travel or long travel, Fox's never feel as plush and small bump compliant as older Zochi's. Never have, and probably never will. I had an old 888 on my Demo and that was leaps and bounds more plush than my Fox is.
  • 01-02-2013
    csermonet
    No experience on older marz, I hear that's really the best stuff made though. My 40 is the best performing fork I've felt, that's all relative though as everyone's suspension tastes are very individual. I've ridden old boxxers, new boxxers, and an 08 888 rc3. The marz was my least favorite, then new boxxer, then old, with the 40 being my favorite. During the summer our trails get pretty dusty so doing oil changes more often than recommended is a must no matter what you run. As long as i stay on top of it I never notice any stiction issues.
  • 01-02-2013
    DHgnaR
    It rains like 10 days a YEAR where I live, the definition of a desert, and my 40 feels amazing, as do most of the other Fox's with the SKF seals. Who's rebuilding your fork? :skep:
    FWIW, one 40 I worked on always had stiction, no matter what. It was the only Fox I'd ever felt with that though and I lay my hands on a lot of Fox forks (at least 4 or 5 a day). My 40 already has less stiction than that one and it's only been ridden about an hour or so. So maybe you're experiencing some weird binding issues with either the bushings or your mechanic isn't properly lubing the seals, etc...
    Either way, your Fox shouldn't be feeling like a "sticky pile of poop."
  • 01-02-2013
    G-AIR
    Coil vs. Air
    The air forks are never going to be as plush as coil, especially on the initial compression.
    Regardless, I agree, Fox has a lot of room for improvement if they want to be the best.
  • 01-03-2013
    raman503
    you know that silver, metal spring/ring on the outside of the fork wipers? there is also one on the inside of the wiper. removing the internal spring/ring will improve the feel of your fork and reduce stiction substantially. on the downside service intervals are increased as the seal is not as effective at keeping out debris, but since Fox recommends weekly service ;) it's no big deal. give it a try.
  • 01-03-2013
    SHIVER ME TIMBERS
    another advantage of an inverted fork
  • 01-03-2013
    DHgnaR
    How is a sarcastic remark about Fox's service intervals an advantage for all inverted forks?
  • 01-03-2013
    SV11
    Fox have never recommended weekly service, nor would they....where do you get you're info from? It's certainly not from fox.
  • 01-03-2013
    .WestCoastHucker.
    so, you point out his flaw in this post, but you let the other 41,000 slide by?
  • 01-03-2013
    raman503
    it's true, i was being sarcastic or exagerating, which didn't escape everybody, but to be honest i'm not that far off: change oil in lowers and inspect bushings "every 30 hours". so service your fork every 2 weeks and service your damper "every 100 hours" or every 6 weeks. I believe i read at one point that Fox recommends these services are done more frequently if you live in a crappy environment, such as Oregon, where i live. so, yeah, Fox recommends i service my fork every 1-2 weeks. with that being said, Fox makes a terrific product.
    i'm don't comment enough to include a link, but if you go to ridefox dot com, click service/bike and scroll down, you too will see their recommended service intervals.
  • 01-03-2013
    SV11
    I"m aware of Fox's guidelines for servicing.
    Do you own a pair of 40's?
    I do, I haven't serviced them in 6 yrs. It's working brilliant, no issues, it's still like buttter which I"m pretty amazed at, no slop in bushings, structually stiff. I want it to deteriorate so I can get it checked out, but it's still going strong since day one. The seals are in very good condition, I think looking after my gear is paying off massively.
    I also owned a pair of 888s, which didn't see a service for 3-4 years. When I finally broke down and serviced it, it made no difference whatsoever on how the fork rode.
  • 01-03-2013
    raman503
    I did, however, find this quote on the Fox sevice website: Tip: If you tend to ride in extreme conditions frequently (dry and dusty, wet and muddy, downhill racing, winter riding, etc.), correspondingly the service procedure items should be done more frequently.
    I certainly got my information from Fox......
  • 01-03-2013
    Gemini2k05
    Either you don't ever ride your 40, or it must feel like absolute poop. I'll bet you $1 BILLION on that.
  • 01-03-2013
    SV11
    Wrong on both accounts, I'm just seeing how far I can push it. Pushing the service interval to infinity is nothing new for me, like i said i did the same with my 888s, my WB DH3's, RS Psylo SL.. I don't want a fork that needs to be babied.
  • 01-03-2013
    raman503
    shoot SV11, i'm not here to argue but if you are "aware of Fox's guidelines for servicing" why did you act like i was crazy when i commented with a slight
    exaggeration regarding said service intervals? Also, if you are aware of there service recommendations why would you ignore them? thats a pretty high dollar item you have there.
    if you think your fork is "like butter" then i would contend that we have different ideas of 'butter'.
    Finally, if you have not serviced your 40 in 6 years then the oil in the lowers is now mud (fact), your wipers are completely dried out (fact) and the finish on your stanchions is very likely worn (not fact, but likely). it's either that or you don't ride frequently, which i doubt. Maintenance is not just about performance but reliability and longevity too. not to mention resale.
  • 01-03-2013
    300hp
    I'm betting on Ti springs (2 of em) twin tube independent HS/LS dampening, and an improved version of ETA mechanical travel adjust to drop it down for climbs.
    Mmmmmmmm. I built an rc3 ETA 55 Ti before, and I have a feeling they're gonna knock it out of the park.
    What I REALLY want to see is what they come up with for an air shock. Their Jade should be pretty damn awesome, but there are good coil shocks on the market now, with plenty of custom options.
    The air shock equiv. of the Jade would be all time lust for me.
  • 01-03-2013
    SV11
    raman503, mainly to see how realiable they are when pushed beyond the service guidelines. The lowers could use a clean, im guessing the oil is pretty rancid. The wipers suprisingly aren't dry...yet. In fact, it's the only part of the fork I'm anal about, the wipers. The forks stanchions have no wear marks, im not surprised due to the condition of the wipers. I've used the forks 2-3 times a wk, except for the last 4-5 months where the bike has been out of action.
    I think it's time we got back to the thread at hand.
    Aplogies to the OP for going OT.
  • 01-03-2013
    mullen119
    I yelled at my computer when I read this^
  • 01-03-2013
    SV11
    Not for the faint hearted.
    Now I gotta get myself an Emerald to abuse, with heavier springs.
    Uploaded with ImageShack.us
  • 01-03-2013
    SHIVER ME TIMBERS
    inverted forks don't have seals where the dirt just sits on them...gravity naturally helps keep them clean
  • 01-03-2013
    SHIVER ME TIMBERS
    no service in 6 years??? pretty weird...because every fork I have changed the oil on felt bran new but plusher
  • 01-03-2013
    SV11
    Yeah, I haven't gone this long without a service for any fork, it's not something I would repeat or recommend. The service for the 888 made no real difference, im guessing I had the wrong spring in it and heavier wt oil, and the fork was plush as is before and after the service.
    I will get the 40 serviced soon, I proved to myself what I needed to, so no point doing damage that's irreparable.
    Bring on the Emerald, in silver.
  • 01-04-2013
    DHgnaR
    Originally Posted by .WestCoastHucker. View Post
    so, you point out his flaw in this post, but you let the other 41,00 slide by?
    Slide by? Nah, I just ridicule him in person.
    You have 15 hours of actual ride time a week? Holy shlt that's a lot! That means, if we were to assume you a do 5 min run every run, that every 12 runs you do would be 1 hour of riding, so if you really ride 15 hours a week, that means you're doing 180 runs a week!!! Damn I wish I had your life!
  • 01-04-2013
    .WestCoastHucker.
    some of us ride trails that are significantly longer than 5 minutes...
    still plenty of actual saddle time though. my guess is that he is calculating the entire time he is out and about...
  • 01-04-2013
    raman503
    I don't necessarily do 'runs' as much as i do hours. I get on my bike and ride it up and over and around and down and probably again and 4-5 hours later i'm done riding. I only ride lifts a few times a year when i'm in whistler or winter park or park city and if i do shuttle runs its generally after the aforementioned ride. so i don't get in 180 runs a week, but i do spend significant time in the saddle.
  • 01-04-2013
    Gemini2k05
    Then they are not getting rebuilt right. Even best case scenario for the 888, the grease on the oil seals will dry up after a year, maximum, if you are actually riding it. There is no question about that. And that makes a BIG difference in feel. So either
    A. No new grease was applied so it still feels like poop, or sh*tty grease was applied
    B. There was never any grease, and still no grease so it always did and still feels like poop
    C. It was never ridden, probably unlikely
    D. You can't tell the difference, which is REALLY unlikely, even the greenest bigger can feel the difference
    Not to mention that the oil just breaks down, starts getting all foamy, gets dirty, etc. Yes even in a 888 in socal the oil will get dirty. Even if you just replace that it makes a difference in the damping.
    Don't even get me started on the fox stuff. Those forks didn't even use to have oil seals. Dirt gets in there and negatively impacts the lubrication oil. Those dampers are sealed so the damping might stay more consistent. But no way that you aren't having to replace the damper condom once in a while if it is actually being ridden
  • 01-04-2013
    Ithnu
    Must spread rep...
  • 01-04-2013
    SV11
    Dude, you are wrong on a lot of accounts.
    A....New grease was used, I was the one who serviced the 888
    B I never said the fork felt like poop, you did...the fork was plush before and after the service, its just that the service made no huge difference because i used heavier wt oil and spring, I have mentioned it before.
    C Come on, it was used regularly, 3 times a week minimum.
    D, like i said, there was no huge diff after the service
    Don't get me started, I have no thing to lie about. The fox was purchased in 2006, todate it has not had a service. I understand you have a hard time believing that forks can go for yonks without service, providing you keep up with the maintenance. As I said before, this isn't the first time I haven't serviced a particular fork in years.
  • 01-05-2013
    _rich_
    Do you guys think twisting will be an issue with this fork??
    That factor and weight is what turned most people off of the Avalanche fork:(
    By twisting I mean when you crash..you have to loosen the crowns and align averything back up..
    I do understand when people gripe about that if you're a hardcore DH'er..
    For me, I just freeride, and weight doesn't bother me at all(my bike weighs 51lbs)
    but, if you're looking for the most durable fork(or shock for that matter) then you'd be hard pressed to find anything better than the avalanche :)
    my entire group ride Avy forks and shocks:D and I can honestly tell you NONE of us has even had any problems at all ,not even a seal leak, in the past 10 years:thumbsup:
    we ride hard too:cool:
    so does the brace thing prevent twisting during crashes?? or does it just make the fork stiffer??
    oh, i'm also not sold on the air fork yet..I know they have come along way, but for now i'm sticking with my buttery smooth Avalanche coil....
  • 01-05-2013
    SV11
    Yes it will be an issue, as it is with inverted forks. I don't see anything in the form of a fork brace, the cf arch is meant to reduce flex.
    Installing a fork brace will reduce fork twist about 70% making the stock forks about 80% as efficient as inverted forks in reducing fork twist but, retaining the front to back flex.
  • 01-05-2013
    Gemini2k05
    w..t..f..?
  • 01-05-2013
    SV11
    w..t..f..?
    Fork Twist...go do some research
  • 01-05-2013
    General Mayhem
    Wow.....just wow.....I'm 67.5% more educated about inverted forks now.....
  • 01-05-2013
    shwinn8
    3-4 years... 6 years.. DAMN! and how often do you change the oil in your vehicle?
  • 01-05-2013
    shwinn8
    pretty cool. I never thought of it that way
  • 01-06-2013
    Gemini2k05
    Trust me, I understand the individual words and terms you used, but no one can comprehend the "sentences" you put them into.
