Results 1 to 6 of 6
    Banned
    DT FR600 and UST tires
    Hello,
    I have FR600 rims and was hoping to pick up a pair of Maxxis UST Ardent tires to put on. Does anyone have experience with this combo, or FR600 rims and any UST tires?
    I planned on picking up a Stan's kit to do it, but I appreciate input first.
    adamant
    No need to limit yourself to UST tires.
    Ghetto tubeless or a tape system (Stans, Specialized, DT, etc) works fine.
    I believe FR600 rims are drilled for schrader valve(1). if so, Ghetto tubeless is probably the easiest conversion. Or invest time and fine a motorcycle tubeless valve.
    If i was converting these rims to tubeless, i'd go ghetto (using 20 inch tube) and 2-3 scoops of Stans (or other sealant) w my favorite tire. Good luck & let us know what you end up doing
    (1) DT says 8.5mm schrader DT Swiss - FR 600
    Old N Slow
    Reputation: Hound's Avatar
    Dec 2012
    You'll need Stans free ride kit on the Fr600, If that's the way you want to go.
    No personal experience, but I've been told to stay away from UST designated tires. Minions, I'm told, tear on the sidewalls pretty easy.
    I have Mavic UST rims and I use Spec Butchers with a shot of stans, they make a superb seal with a ride or 2.
    Jun 2005
    I got the FR600's with ghetto system, not ust tires though, no problem!
    Reputation: charging_rhinos's Avatar
    I just built up a set of non ust minion dhf exo tires to some fr600 rims last night. I tried the gorilla tape only method, but the tires wouldn't seal up against the rim, even with a compressor. I redid it, leaving the tape on to cover the large spoke holes, and used the bmx schrader tube method. It worked perfectly, and they filled up with no trouble at all.
    Regarding the use of ust tires with that rim, I bet it wouldn't work all that well. The ust bead is not going to conform to the hooked shape of the fr600.
    Lastly, the minions have excellent sidewall protection if you get either the exo or the double ply.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
  1. DT Swiss FR600 rims, Hope Pro2 Evo hubs, and screwy spoke lengths
    By charging_rhinos in forum Downhill - Freeride
    Last Post: 07-27-2013, 07:46 AM
  2. Replies: 5
    Last Post: 03-04-2013, 08:07 AM
  3. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  4. dt swith fr600 inside rim width and 600 vs. 630
    By ak pura vida in forum Downhill - Freeride
    Last Post: 07-29-2011, 01:58 PM
  5. Tubeless ready work w/ DT Swiss FR2050/FR600?
    By Verns22 in forum Wheels and Tires
    Last Post: 04-26-2011, 10:22 AM
