Poll: Do you think 27.5+ has a future in DH?
Results 1 to 23 of 23
    Jun 2016
    Do you think there is a place for plus size tyres in DH?
    More and more plus size bikes are hitting the scenes, not to mention that Maxxis have just released a Minion DHF and DHR2 27.5x2.8.
    There are also many 'inexaustive' tests on 27.5 vs 27.5+ vs 29er and usually the conclusion is that 29er and 27.5+ roll better and faster and with less resistance although questions are raised over weight & control..
    see GMBN's tests e.g. on 27.5 vs 27.5+ and 27.5+ vs 29er which indicate that 27.5+ may in fact be the leader in this field when measuring sheer speed..
    There aren't many DH specific tyres out there in plus size but has Maxxis started the trend with the new Minion?
    Whats your opinion?
    This is my Demo8 fitted with 27.5x2.8 Nobby Nic Apex which have a strengthened sidewall and are under 1kg. Maybe they won't stand the test nor have the grip for DH but I take it freeriding and it's a lot of fun..
    I'm keen to try the Minion 2.8..
    Reputation: LarryFahn's Avatar
    Maxxis tires always run small.
    "Plus size" existed in DH before it was cool.
    Gazzalodi's will make a comeback!
    As will 26" wheels. With plus size tires we'll have "the strength of a 26" wheel, with the rolling diameter of a 27.5" as per The Industry™.
    The new Gazzalodi will be named "Twenty-seven HIGH5, by Three-point-ohhh"
    What's old will be new again.
    Hubbard Bike Club
    oh Jolina!!!
    Reputation: Xaero's Avatar
    Mar 2006
    I rode and liked 2.7 tires from Maxxis before.
    I didn't even know they were gone.
    BikeRader did a video riding eMTBs to mt snowdon and their Maxxis plus tires keep getting punctures on the rough stuff.
    I don't think you can get away with fat tires on non DH casings for downhill or rocky sections with speed.
    Light plus tires will probably be too weak for DH. They'll probably work on groomed bikepark stuff.
    Reputation: cookieMonster's Avatar
    I used to run Intense 2.7s and Michelin 2.8s. Thought they were awesome at the time. Then I tried a proper 2.5" tire with proper pressure (i.e. -- more than 14 psi) and I stopped bouncing all over the place and actually rode my bike fast.
    I remain skeptical about "+" tires.
    Dear U.S. Forest Service: Please ban all wilderness in my riding areas.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    I have personal preferences as to different classes for 26" , 27.5 and 29 for racing so there's no wheel size disadvantage ..Wide size tires? Don't care. Different conditions determine tire selection
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    A wider contact patch is great. Get more square inches on the dirt per bike+rider lb, and you've got more traction, more control, can carry higher speeds, brake harder and later, and corner harder and exit faster. Assuming things don't get all squirmy on you.
    However, I think the super high volume tires run at low pressure are silly at high speeds. You have a soft, linear, undamped air spring between the ground and each wheel, responding to dynamic terrain inputs faster than the (well-controlled) suspension possibly can.
    For all its other faults, Procore is really onto something by making the tire act as a more progressive spring by reducing the (low pressure) volume. Stout sidewalls + low tire pressure + progressive air spring can get you a lot of traction without feeling like you're on squirmy plus-size noodle tires. If only wheels didn't keep exploding.
    I'm extremely skeptical of anything 2.8" and up, but I could see true 2.6" and 2.7" not-really-plus DH tires being the norm.
    Jun 2016
    Great response!
    Feb 2006
    Early 2000's someone had 3" mud tires. Can't remember the manufacturer though
    '11 Jedi
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I had michelin 2.8s. Fantastic sticky tire, but slower than a 2.5 minion due to the rotational mass. Buddy ran Gazzi 3.0s at the time. Same issue. He could run them with stupid low pressure, but at the end of the day they were quite slow, like any + sized tire that I've tried or used.
    I have a fatbike with very "+" sized tires, but the point is the extra mass and diameter slows you down, creates more gyroscopic force, makes you slow more for turns, etc. You may not notice it much unless racing skinnier/lighter tire bikes, but this has been my experience. Just leaving the maxxis 2.5 DH tires on my 29er made a huge difference that I could tell, as opposed to my trail 2.3 tires. IME, there is a fairly optimal tire size for downhill, if a really big tire is necessary, it's likely the speed isn't all that fast anyway.
    Generally, DH racers have went down in tire size, from 2.7 or so to 2.3-2.5, not bigger.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    2.5" DH Magic Mary's I run are pretty darn plump already. My gut says you'd be seeing diminishing returns beyond that.
    Also, while they seemed a fair amount bigger than the 2.5" Maxxis I ran, can't say they feel much better.
    Intense used to make a 3.0, and Sun used to make a "double wide" rim that was something like 2" wide. I had a set of these but they're only good for a tank...
    Too much tire becomes a negative as it increases drag. Yes it will increase traction, but as with everything, there is a balance... too much tire = too much drag, too skinny of a tire = no traction. Somewhere in the 2.3-2.7 range is where we have settled is the sweet spot for traction vs drag.
    I'm all about experimenting, but I doubt a 3.0 or larger tire will make it's way, effectively, into the DH scene. More of a niche market for specific riding types and styles.
    Jun 2016
    See below...
    nvphatty
    Guest
    Quote Originally Posted by Patu View Post
    I'm trying running the 2.8 NN Apex at 32psi to see if that proves to improve things. Bear in mind that the NN 2.8 is actually more like a 2.6.
    internal rim width will effect sizing. my NN's on i35 rims are 68mm knob-knob.
    Feb 2006
    I had a double wide once on my old 2000 straight 8. It did a good job!
    '11 Jedi
    I have Flat Pedal shame.
    I think you could get away with riding a 2.8 in the front and a 2.5-2.6 in the rear.
    We don't ride to add days to our life, we ride to add life to the days we have left here.
    Quote Originally Posted by Miker J View Post
    I have a Vredstien 2.4 that I run up front that people are always asking me if it's "+", funny, edge to edge it measures slightly smaller than my Hans Dampf, but the casing looks huge.
    I have a feeling that if the rumoured move to 29er wheels in DH proves to be a winning success all other wheels sizes will die out .
    People said 26 would stay for DH but it's almost impossible to buy a 26 DH bike now .
    27.5 could die as quickly as 26 did if the results prove 29er is faster . Apart from riding on snow / sand which requires a fat bike , why would anyone need a 27.5 plus bike over a 29er x 2.8 ? It would make commercial sense for the manufacturers to streamline production to only one size . However choice does create sales and people like to feel they've made a choice .
    nvphatty
    Guest
    ^^ not gonna happen.....variety is the key and manuf know this.......wagon wheels for DH?? not buyin that either.
    Jun 2016
    Well here it is...my Demo8 with 2.8 Minions.. Running 18/20PSi
    Personally love it...
    ...also...interestingly Schwalbe have just announced their new DH specific Addix ultrasoft 2.6 Magic Mary...I'd say...it's coming...
    https://www.schwalbe.com/en/offroad-...agic-mary.html
    Carving the Path of Life
    Quote Originally Posted by nvphatty View Post
    And then what do you know...
    https://www.santacruzbicycles.com/en...te-29-inch-v10
    Glad to Be Alive
    it's nice to have the traction, but for rolling and quick turning it has no use...but for messing around - sure
    Glad to Be Alive
    tech tip : put the white minion writing next to the air valve....so you find it faster
    Quote Originally Posted by cookieMonster View Post
    Yup. We went through the plus size fad already in the late 90s to early 2000s. They were heavy, slow, and sucked. Modern plus tires are lighter & faster but they get trashed really quickly if you actually ride them hard. There's a reason that DH tires have settled in around the 2.5" size, it's the best trade-off of weight, speed, durability, and traction for riding down a mountain at tunnel vision speeds.
  1. stand for plus size tyres
    By Hakka in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-13-2016, 12:48 AM
  2. Replies: 6
    Last Post: 06-03-2014, 07:36 AM
  3. BB size...not sure if this is right place or not
    By blue_biker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2012, 09:07 PM
  4. Replies: 7
    Last Post: 12-23-2011, 09:14 PM
  5. Commuting Tyres question, size?
    By therollex in forum Commuting
    Last Post: 07-07-2011, 01:47 PM
Members who have read this thread: 14
