Results 1 to 2 of 2
    Dirt Jam Pro == Dirt Jumper III?
    Seeing lots of these Dirt Jam Pros on new jumping hardtails and wondering if anyone has the full scoop on what they actually compare to? I'm thinking it's pretty much the same fork (internals and crown/stanchions) as a Drop-Off or Dirtjumper JIII with only a single SSV? I have one on a jump/4x hardtail and am wondering how it will hold up. Long-term plan is to replace it with either a Pike or a Flick.
    Any informed thoughts?
    Here's the specs from Marz WWW....
    2005 Dirt Jam Pro
    TARGET WEIGHT (without steer tube) 2470 g.
    DAMPING SYSTEM
    * One side: Open Bath SSV System w/Air
    * One side: Long Coil
    ADJUSTABILITY
    * PL
    * One side: External Air Preload
    SPRING TYPE
    * One side: Long Coil Spring
    * One side: Air
    TRAVEL 100mm
    STANCHIONS
    (inner legs)
    * 32mm CR-MO Steel
    * Nitrite Black
    STEER TUBE Reinforced Steel
    DISC BRAKE MOUNT XC INTL STD 6" Rotor Setup
    DROP-OUT TYPE Standard
    2005 Dirt Jumper III
    TARGET WEIGHT (without steer tube) 2280 g.
    DAMPING SYSTEM Dual SSVF System
    ADJUSTABILITY
    * PL
    * External Air Preload w/o Adapter
    SPRING TYPE Coil springs
    TRAVEL 100mm
    STANCHIONS
    (inner legs) 32mm Steel
    STEER TUBE
    * Reinforced Steel
    * No integrated fender
    DISC BRAKE MOUNT INTL STD
    DROP-OUT TYPE NEW 20mm Drop-outs
    2005 Drop-Off OEM
    TARGET WEIGHT
    (without steer tube) 2400 g.
    DAMPING SYSTEM Open Bath dual SSV System
    ADJUSTABILITY
    * PL
    * Dual External Air Preload Adjuster
    SPRING TYPE
    * One side: Coil
    * One side: Air
    TRAVEL 110mm, 130mm, 150mm
    STANCHIONS
    (inner legs) 32mm Alloy
    STEER TUBE Steel
    pwn3rator
    Reputation: scabrider's Avatar
    my friend has one on his scrap. it feels okay but i'm a little too heavy for it so the travel goes away fairly qulivly, besides that it is a reasonablky good quality fork.
    SOCAL UNION REPREZENT
    Quote Originally Posted by JBsoxB
    does it still qualify as a mountainbike?
    Quote Originally Posted by kidwoo
    I've beat beer cans on my limp pee pee.
  1. Marzocchi MZ Comp 100mm vs Dirt Jumper III
    By londonlad in forum Shocks and Suspension
    Last Post: 10-19-2004, 10:03 AM
  2. '03 marzocchi dirt jumper III's
    By bentimby in forum Downhill - Freeride
    Last Post: 09-15-2004, 06:35 AM
  3. Dirt Jumper III
    By flowmaster in forum Downhill - Freeride
    Last Post: 08-18-2004, 11:46 AM
  4. Marzocchi Dirt Jumper III question
    By mtnbiker662 in forum Downhill - Freeride
    Last Post: 07-24-2004, 05:08 PM
  5. Converting Marzocchi Dirt Jumper III to 110mm. need help.
    By Ganze in forum Shocks and Suspension
    Last Post: 03-03-2004, 12:43 PM
