Results 1 to 13 of 13
    Jun 2010
    Direct Mount DH stem...
    I have giant Glory DH 2007 with 888 ATA WC 2009.
    I want to buy a new stem and Bars.
    I saw the Answer DH Direct Mount stem and Answer Pro Taper 780 DH Riser Bar.
    Will it fit my fork?
    Any other suggestions...
    What about headset?
    Thank you...
    Reputation: taylorb's Avatar
    No the answer stem will not fit your fork the 888 uses a different bolt pattern.
    The two direct mount answer stems will fit dorados,fox 40 and boxxers
    Reputation: gage's Avatar
    i'd look at twenty6 f1 stem.. i don't know if it fits 888 but it fits my fox 40 and it's sick //g
    My Current Stable:
    Yeti 303 RDH | Yeti 575 | Yeti dirtjumper
    Reputation: motobutane's Avatar
    What makes the direct mount stem so expensive? It should be cheaper.
    I have the Sunline 888 stem and I love it. The Azonic 888 stem is also cool, but its a bit on the heavy side.
    Reputation: ryan_daugherty's Avatar
    too bad the 888 doesn't use the boxxer/40 4-bolt pattern.
    Reputation: norbar's Avatar
    I think risse or some other company made 888 crowns with boxxer bolt patter. Chunked also makes a stem-crown for the 888. I'd look into that.
    www.totalbikes.pl - Bike Camps not only in Poland
    Reputation: daisycutter's Avatar
    Quote Originally Posted by motobutane
    Smaller market. You are comparing a DH stem which most all mountain bikes can use. To a direct mount which only an 888 fork user can use.
    Marrow Components. Super small company, limited stock but makes the dopest stuff out there.
    www.chainsmokeracing.com
    Elka Suspension
    Specialized Bikes
    Twenty6
    Schwalbe Tires
    Crank Brothers
    SixSixOne
    Jun 2010
    Da Bomb
    what about the "Da Bomb Crown Stem Marzocchi"?
    go for the twenty6. Strong and lighter than most!
    brake later, pedal sooner
    Reputation: ustemuf's Avatar
    twenty6 stem is a super frail design.. i would not advise. i've had two, and both of them broke in one crash each.
