Results 1 to 5 of 5
    Commencal bicycles specifications
    Commencal bicycles specifications for DH/freeride
    I would like commencal autocad drawings with measures and specifications.
    Where can I find the most technical about Commencal.
    With specifications about thickness of the bottom bracket shell.
    Autocad or solidworks, or similar.
    Best Regards
    I have found the tech specifications from Commencal, but don't see the bb shell thickness....
    TECH SUPPORT
    autocadd plans and dimensional info is something manufacturer will protect not just publish on the internet. Best bet is to email them and ask for the shell thickness
    2011 Canfield ONE 200mm DH 35 pounds
    2010 Specialized Pitch 100% non stock 29 lbs
    Wife: 2009 Canfield ONE also 29 lbs
    I ask the thickness of that piece by email and by phone.
    Until the moment (two weeks) I have not response.
    Best Regards
    I ask again fot the bottom shell thickness and aluminium alloy and heat treatment for the models
    Commençal Supreme DH 2010
    Commençal Supreme Racing (mini DH) 2010
    Commençal Furious 2010
    and obtain this answer
    a) aprox. thickness of the bottom bracket shell tube
    3,5 mm for all bike models
    b) Aluminium Alloy used in those models
    DH y MiniDH 7005
    Furious 6061
    c) Heat Treatment type in those models
    All models T4/T6 Sand Blasted
    and finally received answer via email
    I expected more thickness in millimeters because I measured in a workshop other frames of unknown manufacturer.
    I obtain 4 mm in most of them and one of 5 mm.
    Best Regards
Hot Deals
Contests
Latest Mountain Bike Articles
