Results 1 to 8 of 8
    May 2013
    We the people ... Can I install a Bashguard?
    I have some how managed to destroy two front sprockets on my DH bike. I want to install a bashguard but i only have the one sprocket in the front, so i cant simply replace my largest sprocket. How do i do this, and what do i need to do it?
    Rolling Tire
    Reputation: DHGallot's Avatar
    May 2013
    You CAN install a bashguard theres no doubt about it because any bike will take one, dont know much about installing them but i do know you can also get a chainring with a built-in bash guard.
    May 2013
    ok cool, do i need to get longer bolts for my sprocket?
    Reputation: cerebroside's Avatar
    Hope do the Integrated Bash Ring. What are you running in terms of a chainguide?
    May 2013
    Quote Originally Posted by cerebroside View Post
    i don't think that I have one, just the 38 tooth sprocket
    Rolling Tire
    May 2013
    The easiest way for us to help is if you give us some more info and post a pic, otherwise you can take your bike to your local bike shop, a mechanic will tell you everything you need to know
    Jan 2009
    more info please... what frame, what year, what crank.
    there are various types of devices/ bash guards. you can get the ring type ones. not really sure about then as i have never really used them.
    you can get bb fit ones. these fit on your bb cup instead of a spacer. i had one on my knolly dt for a short while before throwing a hammerschmidt on it. it was ok and served it's purpose but did have a tendancy to move when stuck hard.
    the more modern day one are iscg fit. depending how old your frame is. the most recent is iscg05, 03 is the older version.
    these iscg tabs are better as your chain device will fit securly gving your chain rings protection and keeping your chain tight.
    search google for iscg tabs and chain devices
    Rolling Tire
    May 2013
    Expanding on what delirian said, if you don't have an ISCG mount you can still get a ISCG bash, you just need a BB adapter
  1. Truvativ Bashguard/Install
    By 06OutlanderAWD in forum Beginner's Corner
    Last Post: 11-05-2012, 06:49 PM
  2. Replies: 6
    Last Post: 04-26-2012, 04:23 AM
  3. derailleur adjustment after bashguard install
    By sigurd02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2012, 11:50 AM
  4. bashguard...what do I need to know?
    By Limey Johnson in forum 29er Bikes
    Last Post: 08-25-2011, 03:50 PM
  5. Bonehead Bashguard install???
    By socalMX in forum All Mountain
    Last Post: 07-16-2011, 08:17 PM
