Results 1 to 6 of 6
    Building Marin Quake 7.2
    Need suggestion on components......
    This is what im leanin towards so far
    Totem solo air fork
    Transition revoluton wheelset
    chris king headset
    Funn full throttle seat
    Race face next sl seatpost
    Easton DH composite bars
    Azonic shoty dluxe headset
    ODI rogue grips
    Crank brothers 50 XX pedal;s
    Truvavtiv holzfeller 2.2 RG crankset
    Like i said thats all i got right now, need sugestions on brakes set ups and shiftng components. Anone wanna throw some suggestions my way it will be greatly appreciated.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Get a Thomson post. Pass on the 50/50 pedals. Swap the Holzfellers for Saints.
    Brakes... depends. If you're looking for massive power, go for the Codes. If you want to keep things a bit lighter, check out the 2008 XTs. For shifting... SRAM x9.
    which is better the regulat codes or the code 5's?
    Meh.
    Regular Codes are better. Code 5 uses a Juicy 5 lever. Both share the same caliper. The Code lever is cam actuated and pivots on sealed cartridge bearings though. The Code also uses aluminum backed pads where as the Code 5 uses steel backed pads.
    what he said. theres a gagillion choices out there. you could probably be really happy with all of them. but I'd robably just stick with what he said, since he picked out some great choices that aren't finicky.
    Freetard.
    Reputation: Nut!'s Avatar
    Nov 2007
    What shock are you running? I'm assuming you have a DHX Air...
    Quote Originally Posted by Khemical
    Those cables on the Socom look flexy
