Page 1 of 3 123 LastLast
Results 1 to 25 of 51
    Dec 2011
    Best Cassette for DH
    What type of cassette is everyone using?
    Dark Horse Racing
    Reputation: Scrub's Avatar
    What kind of derr and shifter do you have? 9 or 10spd?
    I run Sram x9 with pg1070 10spd 11-23
    Dec 2011
    Quote Originally Posted by Scrub View Post
    Sram X0 9spd
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    I've been running my 9spd 12-25 Shimano DuraAce since early '09 and never had so much as a skip.
    On my 3rd KMC x9sl-Ti chain but the cassette is good as ever.
    I'd recommend a Shimano cassette over Sram.
    Ground Steeze
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    Same as Iggz. I've had the same Shimano Dura-Ace 11-23 on 3 different DH bikes since '07. Keep an eye on chain wear and it'll last for a very long time on a DH bike.
    I'd rather have a bottle in front of me than a frontal lobotomy.
    Reputation: jimarin's Avatar
    Mar 2005
    Dura-ace 11-23 9 speed
    Dec 2011
    Quote Originally Posted by jimarin View Post
    is there any advantage running a 11-23 over a 12-27?
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    Mines cobbled together. 1/2 SLX/Saint, 1/2 Dura-Ace. 11-27 9 speed (150g)
    11 in the back will give u a little higher gear. I run a 34 in the front with a 11 in the back, that actually gives slightly higher top gear than 36/12.
    I like having the 27 or 28 gear in the back for those times when you have to climb a little. On actual DH runs I'm only using highest 5 or 6 gears which is really all you need for DH. Heck some people only run like 6 gears.
    To me 11-23 you'll have too many higher gears to shift through on DH runs, and you have no low gear for the times you need to pedal uphill a bit to get to the start of the run.
    I'd recommend looking at the 11-28 SLX/Saint cassette.
    Reputation: mtbnozpikr's Avatar
    I've also got a Dura Ace 9-spd 11-23
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    2010 Glory custom FR
    Reputation: frango's Avatar
    I am with oldskoolbiker, I run regular 11-28 SLX/Saint 9sp cassette. It's the lightest Shimano MTB cassette - 231g and cheap It has aluminum spider for 3 biggest cogs and 3 another are bonded together with pins, so they won't ruin your aluminum freewheel body, in you have one.
    I wonder what will be the option for 2013 SLX Shadow+ (if some1's on a budget) and new Saint?
    pozdro
    frango
    Dec 2011
    Quote Originally Posted by frango View Post
    What type of chain would work well with Saint Crankset, X0 9 spd shifter/derailleur and SLX/ Saint cassette?
    I've got KMC X9SL and it works fine. I will switch to Yaban, as it's nearly the same chain, but cheaper. However, not the gold-bling
    On the other hand, how many times do you change gears on the track? I do it one or twice... not racing, though.
    pozdro
    frango
    Jun 2005
    Quote Originally Posted by Northender View Post
    I'm running SRAM 991 Cross Step. But any 9 speed chain should work fine. I like the SRAM's since they come with a quick link.
    I am using Shimano ultegra 11-23 and gradation is great for me.
    Look at some WC rigs 9 gear is even too much.
    Regards
    Reputation: B-Mac's Avatar
    Sram PG 970 11-23. Fine cassette & only about $40.
    Check out my You Tube Channel
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    best cassette? really? the answer is speculative at best. gear ratios are the important part...
    Dec 2011
    Quote Originally Posted by .WestCoastHucker. View Post
    No, the answers are subjective. If you have something to say about gear ratios then say it.
    dura ace... $25 used/near new at a bike swap
    been running it a few years, I clean my drivetrain damn near every ride and DH is so low on tooth wear I'm fine with it.
    I would like to experiment with running a 5 or 6sp setup.
    (Mtbr Site Manager) Administrator
    Reputation: gregg's Avatar
    Sep 2000
    Cool it with the flaming, thanks.
    Like us on Facebook - http://www.facebook.com/Mtbrcom
    Follow us on Twitter - twitter.com/Mtbr
    Mtbr YouTube Channel
    old school no.9
    Reputation: miqu's Avatar
    Best performance for money no doubt - Shimano Hg80 SLX/Saint 9sp cassette. I like the freewheel friendly alloy spider. Good corrosion/rust protection also. Haven't had any problems with hg80 11-28, Sram X9 derrailleur and KMC X9 light chain or Sram-Pc991 crosstep chain.
    It's monkey rage time !
    Mar 2012
    More posts = More curmudgeon
    Jun 2010
    36 tooth up front, 11-28 on the rear SRAM 9 speed.
    Gives me all the range i have ever needed, even managed to pedal up hill from the local trails (not much fun though!)
    Sheldon Brown's Bicycle Gear Calculator
    The link can be used to calculate speed from cadence, if you are racing at a decent level i guess changing gearing to suit the track would make sense, but im not that good and so ill stick with what i have got!
    Reputation: calialx1's Avatar
    Mar 2011
    I run a 11-34T sram pg990 and it's never let me down......i carry an 11-26 as a spare.
    Mar 2012
    Quote Originally Posted by calialx1 View Post
    You carry a spare cassette?
    Yeah, I usually carry a spare rear hub, spoke wrench, and truing stand in my Camelbak.
Hot Deals
Contests
Latest Mountain Bike Articles
