 Originally Posted by arkon11
Yeah, I usually carry a spare rear hub, spoke wrench, and truing stand in my Camelbak.
Nice, I like a rider who's prepared. I usually carry my headtube facing and reaming tool incase I ever need an emergency reaming.
I'd rather have a bottle in front of me than a frontal lobotomy.
 Originally Posted by calialx1
I run a 11-34T sram pg990 and it's never let me down......i carry an 11-26 as a spare.
+1 on pg990 11-34. Unfortunately my dh rig is the only bike I have so the 34 tooth sprocket helps with climbs.
Sent from my Nexus S 4G using Tapatalk
 Originally Posted by DhRoadStar
You carry a spare cassette?
not on my pack, just down wherever my car is..... but if i was going on a long ride... i might if I have room.
Slow Patrol
Ultegra 12-27, 36 ring up front.
Dura Ace 11-27, 36 front ring.
Professional Troll
Whatever I find in my boxes of random spare parts, preferably shimano. I have problems in the past with bending cogs on SRAM ones.
I ride an 11-32 9 speed Sram cassette. Just a midrange model, nothing flashy. Also to note, I ride a 42t chainring.
36 toof up front, sram pg 1070 12-25 10 speed
11-28 10 speed. I also use the bike for enduro riding...
Who needs a cassette!
When I ride local trails I run 11-34T & 34T up front for more climbing ability. For shuttle or lift assisted rides I run 11-26T & 36T up front.
"walking on water is only knowing where the stones are"
In Armor We Trust
I went with the PG980 since it was basically same weight as the 990 but a bit cheaper. Such a huge step up from the PG950 I ran previously. Went with 11-34 since I use the same bike for DH/FR.
DH/FR: Intense 951
FG: KHS Flite 100
My favorite cassette is Ted Nugent Weekend Warriors
Too Close To The Hill
If NOT racing, why have a narrow 11-2x instead of 11-3x?
Lacerations through intact armor are a mark of talent... or stupid... or both...
Special Lister
 Originally Posted by jimarin
Dura-ace 11-23 9 speed
Being new to DH can someone explain to me why go with an 11-23 or something simular rather the 11-32 or 34? I would think if I had to do some pedaling i would want that big ring in the back to make it easier. Again I am new to DH so go easy.
It's about getting speed, while going down a hill. The smaller spread is usually all you'd need. With a regular mountain cassette, the spread is too wide and gives you less working gears. That, plus weight.
I swap cassettes, depending on what I'm riding.
I ride a 34T up front and a DuraAce 11-23T out back, or an XT 11-32T.
send money to my paypal account And i WILLZ givez you thy answers.....what was the question again??
When I get all the parts I'll be running the shimano caprio cassette 9-26t on the Canfield micro drive hub. X0 cranks with a 32t MRP bling ring and MRP G2 SL Micro guide. Wide range of gears, crank and ring are silly light, micro guide is lighter and lower profile with a 32t gives you increased ground clearance as well. With a 13.8 bb height every bit counts.
i got the same exact ratio , 34t front , 11-23t. i cant pedal up, if i know a trial has climbs i switch to my 11-32.
i like to have the smaller 11-23 because the gears are close makes it easier to shift up and down while pedaling hard. also itd save you over 100 grams in compare to a 11-34 cassette
I have a question. I normally ride a 2012 specialized camber but am looking into a specialized status 1? i will be getting rid of my camber and am looking at riding the status for my main bike.. Would there be a gear or cassette combo that would still allow me to ride uphill pretty good?
With dh, most of the time you're doing just that, going down a hill, so there is no need for high gears. A freeride bike is a diff story, I always have 11-3X on my freeride bikes, but there is no need for high gearing on a dh bike, unless you want to ride back up the hill.
Anyone in here know any info on the Status 1? I have a couple questions.
- You may not post replies
- You may not edit your posts
Forum Rules
