Results 1 to 14 of 14
    Reputation: rarroyo's Avatar
    Astrix Huckster what fork to use?
    Wanted to see if I could get some suggestions from Huckster owners or anyone who could suggest a great fork for this frame. I had a RockShox Domain with 180mm with a 565 axel to crown and it made my head angle 64.5 and as you can imagine it handled like crap...
    Rafael
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
    http://www.titusti.com/2010/
    http://www.corsairbikes.com/
    64,5 isn't that bad IMO. But if you don't mind the weight and want it steeper, the 7" 2006 boxxer ride will be all you need except for X-up ability. I wouldn't mind using a 8" boxxer either, but hey that's just me.
    Living the High Life
    Reputation: Ithnu's Avatar
    Feb 2007
    With a dual crown you could adjust the head angle more.
    I currently have a 2002 Monster T on there with a 67 head angle, which handles great but not sure about the weight. In regards to the Boxxer Ride I read that the damping kinda sucked in that fork...thanks for the suggestion though.
    Rafael
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
    Quote Originally Posted by rarroyo
    Rafael
    It has the same damping as the WC for 2006. are you sure it sucks? i actually owned one.
    ...well that is just based on a review I read on NSMB I think one of the editors, and my buddy said it compared to the Monster the Monster had better damping. I guess its just preference at the end.
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
    The cool thing about Motion Controlled Boxxers is you can absolutely tune them to your liking, of course if you don't mind playing with the shims in the compression damper and learning how the damper and its adjusters work. But don't worry, the fork's damping works fine even stock. If you can find one cheap, I would choose the 06 Ride. If you find out later that you want full 8" travel, all you need to do is buy a spring kit, new comp rod and you're done.
    Sweet thanks!
    Rafael
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
    Any more thoughts on which fork to get...
    Rafael
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
    Feb 2007
    I had a Boxxer Team on my Huckster but now I have a Kowa and I am leaning more toward air springs. My Kowa has a coil in one side and an air spring in the other, tons of tunability and you don't have to take it apart to do it.
    They're coming out with a 180mm single crown next spring.
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    I saw a picture of one with a lyrik on it, it looked ok
    HARDTAIL PRIDE- 09 Kona Five-0
    Oct 2007
    Mine has the 66 VF2 and rides nice with that set up.
    Flying Goat
    Reputation: mrpercussive's Avatar
    06 Boxxer Ride or Manitou Nixon PLatinum Intrisinc or Fox 36
    Thanks for all the suggestions guys!
    Anyone down to ride today JMP 4:30pm!
    -R
    -R
    Oakland
    2010 Titus El Guapo
    2011 Corsair Crown
