Results 1 to 6 of 6
    Reputation: sanjosedre's Avatar
    anything change for 2014 36 float?
    I heard about the new damping for the 34 lineup & of course the new 40's but was anything updated on the 36 lineup?
    Dre
    Reputation: jimarin's Avatar
    Mar 2005
    I'm hoping it will have the same spring setup as the new 40.
    RideDirt
    Reputation: aedubber's Avatar
    It now comes with vaseline so it doesn't suck so bad when you get screwed over.
    FLOAT Air Spring Curves | Bike Technology | FOX
    Smarter Travel
    Our ultimate goal with the FLOAT air spring is to mimic the linear curve of a coil spring. The secret to achieving near-perfect linear spring curves, while maintaining bottom-out resistance in each travel setting, is focusing on both ends of the fork's travel path. The result:
    Less initial breakaway force
    Longer negative spring and reduced air spring compression ratio for a more linear feel
    Optimized use of overall travel
    More travel with less ramping at the end
    Funny I put a spacer in my rear shock just to make it more progressive
    Would be cool if they made the 36 Float adjustable too...some of us like the air progressiveness.
    adamant
    Quote Originally Posted by canuck_tacoma View Post
    st
    same here. Float shock too linear (2011 MY RP3 w BV). Looks like same issue w 34mm 160mm forks. Glad to read Fox is increasing the curve at the end of the stroke. Kinda like the....Lyrik DH
  1. 2014 Fox 40 Float RC2 & DHX RC4
    By daisycutter in forum Downhill - Freeride
    Last Post: 03-29-2013, 09:13 AM
  2. SC Specific Fox Float 32, change travel?
    By the Swede in forum Santa Cruz
    Last Post: 01-15-2013, 11:56 AM
  3. Fox Float 32 RL oil change now won't rebound
    By wepaddle in forum Shocks and Suspension
    Last Post: 02-08-2011, 06:50 PM
  4. Fox 36 Float RC2 Oil Change (2008)
    By Benjie1966 in forum Shocks and Suspension
    Last Post: 02-03-2011, 04:52 PM
  5. Fox Float Oil Change
    Last Post: 01-07-2011, 01:11 PM
