Results 1 to 7 of 7
    Reputation: fubuki's Avatar
    Apr 2005
    Anyone have a serious impact with 661 Full Bravo Carbon?
    I'm looking for a new helmet and not sure if I want to get a standard DH helmet like the Full Bravo Carbon or a DOT cert. helmet.
    Schmeow Productions
    Reputation: JBsoxB's Avatar
    Quote Originally Posted by fubuki
    if you got the money, TLD SE... lol
    depending on what type of riding you do, you could even got for the HJC's or something...
    Apr 2005
    The TLDs are a bit too expensive, but I don't want to be too cheap. I'll be riding Whistler quite a bit this summer, as well as the local spots here in Washington.
    Reputation: RobsterCraw's Avatar
    I wear the 661 FBC, good stuff I wore it all the way up my local trail and it wasn't too hot. bearing in mind that it wasnt a hot day. Never crashed with it so far. I was gonna get the troy lee D2 but the fit was a little odd plus it was 100 dollars extra. The DOT helmets are designed to withstand really hard impacts like with car bumbers. So they are really hard. This isn't necessarily a good thing though for mtbiking. Helmet shells are supposed to be soft enough to eat some of the force of the impact. A harder helmet will withstand harder hits but for the forces you would expect in a MTB crash they won't cushion the blow very much. Whereas a MTB specific FF helmet is going to be a little softer and is designed to specifically take the kind of hits you would normally worry about on the trails. For real DH riding it is possible that you may really want a Snell/DOT certified helmet because DH can take some really hard hits. I'm confident in my Full Bravo Carbon. I tried a couple of the DOT helmets and the added safety was at just too much of a cost in weight and comfort. Only the Fox Racing V3 is up to DOT and SnellM2000 standards and is still under 3 pounds. Under by half and ounce. If money is no object and you do want DOT, then the TLD SE is a good one to look at.
    Check out the June 2005 issue of Mountain Bike Action. It should be on the shelves right now. It has an indepth articla about helmets and also has a list of all kinds of helmets and their basic specs.
    Glad to Be Alive
    DFot is always better, but for summer heat and ventilation I ride the 661 Full Bravo. If you crash a lot then I would get the standard one...If you got some skillz then ride the carbon one
    Apr 2005
    Thanks guys. I don't really crash alot, so I feel a bit more comfortable getting the FBC.
    Can't get right...
    Reputation: dannymonky's Avatar
    Quote Originally Posted by SHIVER ME TIMBERS
    I too use a 661 Full Bravo Carbon. Seperated at birth?....
    I watch the O.C. cause it makes me happy...
    If misery was money i'd be the richest man on the planet.
  1. 661 Bravo XC helmet
    By derby in forum Apparel and Protection
    Last Post: 03-10-2005, 09:50 AM
  2. 661 Carbon Bravo helmet
    By SHIVER ME TIMBERS in forum Apparel and Protection
    Last Post: 03-09-2005, 09:39 PM
  3. Azonic AZX vs 661 Full Bravo 2
    By beoch in forum Downhill - Freeride
    Last Post: 09-05-2004, 06:06 AM
  4. Difference between 661 Full Comp and Full Bravo?
    By BanzaiRider in forum Downhill - Freeride
    Last Post: 04-20-2004, 08:37 AM
  5. 661 Comp full face and a fat head?
    By hedgehog in forum Downhill - Freeride
    Last Post: 02-29-2004, 05:21 PM
