Results 1 to 7 of 7
    83mm bb, 157mm rear hub, 65mm chainline, terrible idea?
    Hi, curious about whether someone here has experience with flipping a DM RaceFace chainring on an 83mm setup and 150/157 hub. That would produce a 65mm chainline, so I was wondering if shifting would be ok or suck. I am considering this setup to get enough tire clearance on a custom build I am planning but don't know if I should use a 170mm hub instead. I rather use 157mm if that chainline is not horrible. Any thoughts?
    Reputation: LarryFahn's Avatar
    What bike are you using that can possibly have a rear hub that varies from 150 to 170?
    Hubbard Bike Club
    It's a custom frame design, haven't decided on hub spacing yet, though would prefer 157mm
    157 it is. Why mess with Fat bike hubs or whatever a 170mm hub is from.
    Hubbard Bike Club
    It's all about chainline and clearance, the usual DH chainline is 55-56mm, whereas the one I am using, to get semi-fat clearance is 65mm, commonly recommended for 170mm hubs. I rather use 157mm so long as shifting is not horrible by the 10mm chainline displacement, especially if using a reduced 6-7 speed cassette with spacers in place of bigger cogs.
    MTB B'dos
    Reputation: LyNx's Avatar
    What the heck exactly are you building, intended usage and tyre size/width? I know of many `50/157 rear, 73mm BB custom builds that will run a 3" tyre, no problem, possibly a 4".
    Glad to Be Alive
    this is the perfect question...you need to give more details to get a great answer on chainlines
    type of riding (dh/xc,) rim size, tire size....
  1. 1-way road trip to Whistler? Good idea or terrible idea?
    By skyno in forum California - Norcal
    Last Post: 03-10-2014, 10:31 AM
  2. Convert Hope Pro 2 EVO 150mm rear hub to 157mm?
    By mdg3d in forum Wheels and Tires
    Last Post: 12-09-2013, 08:11 PM
  3. which 157mm rear hub for podium?
    By cfrench in forum Knolly
    Last Post: 11-09-2013, 12:22 PM
  4. Replies: 6
    Last Post: 02-12-2013, 05:07 PM
  5. TREK SESSION 9.9 REAR HUB 157mm ?
    By yeti-j in forum Trek
    Last Post: 02-25-2012, 08:34 PM
