6'2"-ish folks with 6-7" bikes, what size frame / fork / stem are you rockin'?
I'm looking at getting a new-to-me AM/FR bike and at 6'2" I'm torn between being cramped on a medium vs losing tight turning with a large. There may not be much difference with only 1" TT difference and 2" seatpost difference between the sizes I'm lookin' at, but I figured I'd see what other people have experienced.
My last bike (5" travel) was a large with a 24" effective TT and 19.5" seat tube with a 80mm stem and 25mm setback post, and the large I'm looking at is 24" effective TT and taller 20.5" seat tube, but is a bit more raked @ the HT than my last frame and will be run with a 160-170mm instead of 150 fork. I plan to go wider on bars from the 620mm I was used to, to something more like 680 or so, and run a stem around 60mm on this bike, which should hopefully balance out at the elbows. I'm a little worried about how much wheelbase I will gain over my last frame and fork setup and how low I can get my seat with a setback post if I go with a large. What kind of difference does an inch or so between wheelbases really make in tight turn ability?
The medium i'm considering (18.5 seattube 23" effective TT) is only really attractive to me for the shorter wheelbase / tighter turning and lower seat height, but I worry about being scrunched up over the bike or forced into a longer than ideal stem or a crazy setback post. This is for sure gonna be the case if I already run my seat waay back on a 24" toptube frame and 80mm stem, right??
For the tightest switchbacks, the med. would be better/faster I'm sure, but for stability and center of gravity purposes, being stretched a little more over a larger frame would, I assume, be better. For crazy steeps, I assume the longer bike will be slightly more endo resistant, with all else the same. For jumping, I'm not sure there'd be much difference at all.
So I'm lookin' for a census of people about my height (6'2") on 6-7" bikes to post up their specs (your height, TT, seat tube, fork length, stem length, bar width, rise or no rise bars, setback or not post, and wheelbase & standover if you know it). Also, where is your seat height in relation to your bars when you're bombing down?
Thanks in advance.
Thanks in advance.
