Results 1 to 9 of 9
    Reputation: nojoke's Avatar
    2011 boxxer r2c2 feedback?
    Just ordered one. Any issues or feedback? Not sure if the out of the box springs are ok for me. Im 190-195 geared up.
    Reputation: V.P.'s Avatar
    Its very good, controlled and adjustable.
    indeed. very good for me as well. I had a 2010 as well and this feels like the 2010 boxxers should have felt.
    new forks come with 3 springs, so it shouldn't be a problem to tune it, but I'm about the same weight and the stock (red) spring works well with 2 preload spacers.
    when you get it, check the bath oil. lots of them are low or dry (mine was way low). other than that, it should be butter.
    Dec 2004
    cant wait to ride my r2c2 Boxxer heard they are stellar..we will C !
    mine is 6 months old
    very plush easy to dial
    you must check the bath oil its geting dry during the rides and clean the seals from mud and dust without Lots of water...
    Why is MTBR the "justify my previous purchase" forum?
    Just wanted to give a feedback on the fork so far. I have about 10 hours on it, and its broken it now.
    Low/high speed adjustments work very well and respond to input. The stock out of the box "red" spring works well for me, im 190 geared up, spring calls for max 180. Seeing about 25-28% sag on the fork. Been using abot 7" on average each run.
    I have found that the 2010 Tuning guide works somewhat well. Havent found much info for the 2011 tuning guide if RockShox even made one. The rebound settings are off though, although I've heard the 11's vs the 10's had some different rebound characteristics.
    Been running 14 clicks on beginning/ending stroke rebound and 3 clicks on low speed compression, 5 on high speed compression, and 2.5 turns on bottom out. Seems to cover about everything I need right now. I make some adjustments when its wet and muddy and keep it more glued.
    No complaints so far
    Moose Member
    Reputation: Moosey's Avatar
    May 2010
    Quote Originally Posted by Vertr View Post
    bloody hell you're totally right...
    NWS
    NWS is offline
    Jun 2010
    The 2010 R2D2 model is much better.
    It beeps at you a lot, like the copilot from... what's that movie... it's on the tip of my tongue...
  1. 2011 Boxxer R2C2 vs Boxxer RC?
    By madridg in forum Shocks and Suspension
    Last Post: 05-05-2011, 12:25 PM
  2. 2011 Boxxer R2C2 vs Boxxer RC?
    By madridg in forum Downhill - Freeride
    Last Post: 05-05-2011, 03:45 AM
  3. 2011 Boxxer R2C2 rebound problem.
    By SlickShoe671 in forum Shocks and Suspension
    Last Post: 04-28-2011, 03:01 PM
  4. 2010 boxxer wc or 2011 boxxer r2c2?
    By jeffte in forum Shocks and Suspension
    Last Post: 04-10-2011, 12:58 PM
  5. 2010 boxxer team vs. 2011 R2C2
    By MTB DUDE in forum Downhill - Freeride
    Last Post: 02-18-2011, 07:29 AM
