If you think you can
2009/10 Marzocchi internals in 2007 forks?
Does anyone know if this will work? Seems like it would be a cheap way to get better and more adjustments out of my 2007 888.
maker of trail
the stanchion diameter changed from 35 to 38mm for 08 so its not likely to work.
Since the stanchion is larger in the new forks it stands to reason the internals grew as well, so they probably wont fit into the 07 fork.
however the 07 chassis is one of the best they have made recently, and with teh RC2X damper, hard to beat on anything but weight!
eat your porridge jordie
It will indeed work... I have a 2006 RC2 Light that I replaced the damper cartridge in. I used an RC3 cartridge for the newer 66 forks. The part will cost you about $80 to get from a shop. You will need to swap out the top caps and remove an aluminum footnut spacer on the bottom. Other than that it is a direct swap, and made my fork behave MUCH better, especially on repeated big hits.
"If you want to do something ordinary people can't, you have to be willing to do what ordinary people won't"
take the fork into marz and get a crash re[lacement
kneecap
 Originally Posted by jimmydean012
It will indeed work... I have a 2006 RC2 Light that I replaced the damper cartridge in. I used an RC3 cartridge for the newer 66 forks. The part cost me about $68 direct from Marzocchi, but this is with a dealer account and you may have to pay a slight shop markup. You will need to swap out the top caps and remove an aluminum footnut spacer on the bottom. Other than that it is a direct swap, and made my fork behave MUCH better, especially on repeated big hits.
That's interesting, do you feel the rc-3 is a significantly better cartridge than the rc-2?
I had zoke install an rc-2 in my 07 am-1just a few weeks back, but I'm always interested in quality dampening, & I recall someone there told me the rc-3 wouldn't go in my fork, now I'm kinda bummed.
Can I use the top & bottom caps that they used for my rc-2 retrofit for the rc-3?
I am the originator of this mod, retro fitting the RC3 damper into an older 06/07 66, and i can tell you that the RC3 cart feels MUCH better than the RC2, much more controlled and when you increase the compression it doesnt stiffen the entire stroke
If your interested in the mod, see the link in my signature below, its worth it!
maker of trail
sweet! would it work on 888's?
Ive wondered about this, and i reckon it would work as long as you can swap over the Volume Adjust plunger and mechanism. If you can install the VA system onto the RC3 Shaft, it should work fine, most marzocchi parts are very inter changeable
Bless their lazy Engineers
Nick do you know if the springs will fit? I would love to have a TI spring in my 06.
 Originally Posted by phyco ref
Good looking kit, but $299 plus $89 for the fork adapter kit.............
Would love to hear from someone that has a season riding on one of these though.
If you are refering to a 2010 Ti spring, then no they wont fit, as the OD of them is larger than the ID of the stanchions.
- You may not post replies
- You may not edit your posts
Forum Rules
