Results 1 to 5 of 5
    外国人
    2007 marz 66 rc2x oil change help
    hi, was doing an oil change (first time for me) to my fork (i got it 2nd hand) but i can't seem to take out the bottom right leg nut i think its called the high speed compression. i made sure that the top screw was snug by using the lockring tool and i tried to unscrew this nut but i couldn't take it out.
    any tips?
    thanks in advance!
    ps. sorry for the cr@ppy pic, should take a better one later.
    ↑ ↑ ↓ ↓ ← → ← → B A Select Start
    push down on the fork to preload it while you are loosening. if that still doesn't work, an air ratchet or impact always works for me.
    Reputation: wormvine's Avatar
    sometimes the cartridge shaft can spin. Some use a small air or electric socket driver.
    I think I used a cordless drill on high speed with a socket driver.
    <iframe width="425" height="349" src="http://www.youtube.com/embed/XeNZr5dA4Q4" frameborder="0" allowfullscreen></iframe>
    外国人
    Thanks for the tips. Will try the push down on the fork thing as i dont have an electric socke driver. Watching blumpher's vid above i was wondering about the "quick bang with the hand". Does it mean i need some impact or tap it first to loosen it?
    Thanks for your patience guys
    外国人
    You guys are DA BOMB! Just did it using the push the fork down method. Oil change is a GO. Thanks again!!!
  1. 2007 marzhocchi 66 rc2x oil change
    By Metanoia in forum Downhill - Freeride
    Last Post: 04-04-2011, 08:01 PM
  2. Marzocchi 66 RC2X 2007 travel change
    By persing in forum Shocks and Suspension
    Last Post: 02-02-2008, 02:11 PM
  3. Can you lower a 2007 Marz 66 RC2X?
    By MaddSquirrel in forum Shocks and Suspension
    Last Post: 07-31-2007, 11:37 PM
  4. Marz. RC2X vs. RC2
    By Cozza in forum Downhill - Freeride
    Last Post: 05-01-2007, 12:46 PM
  5. Marz 06 RC2X - need help, please.
    By ran1974 in forum Shocks and Suspension
    Last Post: 01-07-2007, 04:46 AM
