Results 1 to 11 of 11
    Reputation: mudtoy1986's Avatar
    Dec 2008
    04 kona stinky question
    hey guys its been a wile since i posted
    i just purchased an 04 kona stinky and i am wondering if they make custom lower swing arms
    ive seen some stinkys what looks like bolt on drop outs and 12mm thru axles i would like to eliminate the 10mm axle if i can
    "look mom no hands"
    Reputation: keepbalanced's Avatar
    Dec 2012
    not sure about that but I also have a stinky and I love it. Congrats on your new ride!
    Jan 2011
    Quote Originally Posted by mudtoy1986 View Post
    Yeah I have that setup on my 07. Try contacting kona for a newer model lower, if it's compatible with an 04.
    Dec 2008
    thanks for the replies guys ill be posting pics real soon the bikes real ugly due to the fact that the jack hole who owned it before me stripped off the paint then rattle caned it i plan on powder coating it
    "look mom no hands"
    Dec 2008
    "look mom no hands"
    I wouldn't be so worried about upgrading the lower link to a 12mm axel. If you get a thru-bolt hub it should be plenty stiff for you.
    I don't know much about stinky's, but if possible I'd recommend getting a works headset to slack the front end out a little bit. It'll give the bike a little more modern geometry.
    10mm axle plenty strong. I suggest the Hadley axle 10x135
    Check this link for the 12x135 drop out for your ride
    D.O.P.E Dropouts - Kona USA Web Store
    Also, 99.9% certain, that your head tube/steer tube (ID) is not large enough to accommodate a WORKS Headset.
    Good luck and congrats on the new ride.
    I think that even with a 1 1/8 steerer (and headtube), works has a headset that will slack it out 1 degree.
    looks like some Dangerboy rocker plates on there too
    they also raise the bottom bracket and steepen the headtube angle even more?
    I ran a similar set up years ago and I used a 24 inch rear wheel to compensate for this...
    I have a nice set of wheels that would go nice on that bike if you're interested??
    Transition Revolution 32's black in nice shape(coupls small scratches)
    They already have the 10mm thru hub and come with a 10mm QR axle !!!
    the 10mm QR will make a huge difference on your stinky..It will totally stiffen the rrear of the bike up....
    Back when i had my Stinky, I ran a 12mm hub with a step down to 10mm axle
    the 10mm stiffened up the rear of the bike BIGTIME !!!!
    send me a pm if you're interested...I'm in CT.
    Dec 2008
    i have a cris king head set and atomlab wheel set 20mm front hub 12mm 10mm stepdown rear hub and yes those are danger boy rocker plates
    im installing my raceface evolv e dh 22 32 bash as soon as my front der comes in i would def be interested in the wheels if i wassnt paying off the bike through my local bike shop i payed 400$ for the bike as it sits
    "look mom no hands"
    Dec 2008
    oh and how do the dope drop outs fit do i need to cut my chain stays and drill the mounting holes or do i need to buy different chain stays
    "look mom no hands"
Hot Deals
Contests
Latest Mountain Bike Articles
