Results 1 to 9 of 9
    03 Jr.T or 05 Manitou Sherman Firefly Plus
    Hey i got a 03 giant Ac2, i do mostly dirtjump with some freeriding and i was looking to go for a 6'' Sc instead of a 7'' Dc. Do you think it would be a good choice to have the manitou to better suit my riding style?Is it even worth it to do the switch?Well if so how much could i sell my Jr.t for its in MINT conidition with direct mount stem. Thanks for the help
    Cheers,
    Mitch
    Florida Rider
    Reputation: atomrcrkhsbiker's Avatar
    Get the firefly
    The sherman flick I have is great and very similar to the firefly, you will like the firefly a lot better than the Junior T
    Meh.
    Reputation: XSL_WiLL's Avatar
    If the Firefly comes with SPV, you'll hate it. Both forks will have spikey feelings, both can be fixed without too much work. SPV can be devolved by removing a spring in the SPV unit, and SSV in the Jr. T can be made so that fluid flow is improved and it's less spikey. I know how to do both, don't hesitate to ask. The Firefly will probably be a better option for DJ and lite FR. Be sure to keep the SPV at 30psi, running at the minimum will make it more compliant. Shermans are notoriously undersprung. You MAY need to upgrade to the x-firm. You may be ok at the stock if you use SPV for bottom out control. If you can get a TPC+ Firefly, that's the way to go.
    Samsonite Tester
    Reputation: Evel Knievel's Avatar
    What he said .
    Yeah I gotta question. You got any excuses tonight Roy ? -Antonio Tarver
    There is room for it all, just ride what you like to on what you like to...that's freeriding. -rbn14
    Meh.
    Well, it'll only feel spikey over closely spaced bumps at a rapid pace. For DJ and straight hucking, it probably won't be so bad.
    Glad to Be Alive
    you should be saying Hello Jr.
    Manipou sucks
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    FireFly all the way. Marzsucki
    pin it to win it
    gett the sherman, i own two and have a friend with a new flick, no problems with them at all.
    Giant STP 06
    Reputation: KonaStinky05's Avatar
    Dec 2004
    Could you maybe PM me with the Jr. T thing?
