Results 1 to 7 of 7
    01 marzocchi monster t bombers
    Does anyone know if you can buy a replacement arch for more tire clearence. My gazza 3.0's wont fit.
    Reputation: dowst's Avatar
    You don't need a Gazza 3.0
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    seriously, are you doing bender sized hucks or what??
    HARDTAIL PRIDE- 09 Kona Five-0
    Reputation: ianjenn's Avatar
    Quote Originally Posted by flyinhawaiiandher
    It should fit fine? The 2002 kona,s had 3.0 GAZZ on the front? The arches are about 300-400 new. At least when MARZ had them....
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Was it just an arch, or did the monster require spacers to keep the tire from bottoming on th crown? In any case if you need an arch, you can probably have a machine shop make one out of aluminum. I don't know if a michelin comp32 will fit (a 2.8), but it's a far better tire than any nokian 3.0.
    ...for I am a raindog too
    Reputation: RaindogT's Avatar
    I agree with what was said before-- you don't need Gazza 3.0s, I run a 1.9 Kenda Small Block 8 on my monsters and they fit just right-- not too wide, plus they are super badasscore tires.
    If you are lonely when you're alone, you are in bad company
    Reputation: wantadhbike's Avatar
    Dont waste the money on a machined arch just give the money you would waste to me for my bike just go for a tire a tad smaller, my huffy with 1.95's rules the trail jk.
