Page 5 of 5 FirstFirst 12345
Results 201 to 214 of 214
  1. #201
    Jun 2015
    Hey guys, I have a 2013 (I think) response xe 26" and I'm looking to upgrade my fork. I am thinking of looking into the suntour Epicon.
    Should I be looking for a non tapered tube? Also, it looks like some of you are running much longer travel forks, have you had any concern with frame damage at all because of the increased travel?
    Put a rigid 29er fork and 29er front wheel on for a 96er Response. Head angle change was minimal and I really like the way it rides!
    Attached Thumbnails Attached Thumbnails Upgraded DB Response! Post your pics!-my-96er.jpg
  3. #203
    Quote Originally Posted by Intronaut View Post
    You need to get the same kind of steerer that your old fork has. I looked at a photo of a 2013 and it looks like a straight 1 and 1/8. If that's the case, that's the only sized steerer you can use.
  4. #204
    Jun 2015
    Thanks for the clarification!
  5. #205
    Reputation: elliott436's Avatar
    Jul 2014
    I have the same bike mine is 2014 model it'sa straight tube 1 1/8!
  6. #206
    Jun 2014
    I dont remember if I posted this yet
    Here's my 2012 DB Response XE.
    Attachment 1001867
    2012 Diamondback Response
    Avid BB7 disc brakes with SP7 levers
    Shimano Alivio 8sp Shifters
    Shimano Alivio 9 Speed 22/32 crank with Raceface bashguard
    Shimano Deore FD
    Shimano Deore 9 Speed RD
    7sp freewheel
    Raceface Ride 90mm Stem
    Raceface Ride seatpost
    Forte 630mm Flat Bar
    Suntour Epicon set to 120mm
    Stock wheels and Hubs
    WTB Velociraptor 2.1 front tire (soon to be 2.4 Maxxis Ardents)
    Maxxis Ignitor 2.1 rear tire
    Shimano clipless pedals
    32lbs when I bought it, now 28lbs ( I plan to change more components and get a lighter wheelset to get it down to 26lbs when $$ permits)
    I might have missed something but I forgot
  7. #207
    Why a 7 speed freewheel (cassette)? with 8 speed shifters and 9 speed derailleur? That all shifts ok toegther?
  8. #208
    Jun 2014
    Quote Originally Posted by smilinsteve View Post
    I got all the 9 speed stuff for when I change to a new wheelset with a freehub. Until then it shifts OK. I set the limit screws so it won't shift 8 gears. It works well for now. It'll work better when I have a 9 speed cassette and freehub wheelset. Oh and you can't use 9 speed shifters with 7 speed. The indexing is different. It's not ideal right now but I broke the rear derailleur the third time out. I ride black diamond trails so I'd rather have something that can take abuse and has future upgrade potential than get another crappy rear derailleur.
  9. #209
    Quote Originally Posted by blackitout View Post
    You said you have the stock wheels. Don't they have a freehub?
  10. #210
    Jun 2014
    Not the Dick's version. The normal response does. Mine is 2012. Maybe they switched after that I don't know.
  11. #211
    Nov 2013
    on my response the bearings in the back wheel blew out and im replacing the rim and casset and hub because we threw out the whole rim it was junk so what would you guys recomend for a rim hub and cassets?
  12. #212
    Jun 2014
    Quote Originally Posted by ReconBikes View Post
    That's a difficult question to answer. Depending if you want it to be 8, 9, Or 10 speed you'll have to upgrade your entire drivetrain to match. Crank, shifters, front derailleur, rear derailleur, chain. Once you figure out what speed you want the rear to be then start finding a rear wheel to match that has that speed.
  13. #213
    Mar 2015
    Upgraded 2014 Response XE
    It's nothing special to most but I've done almost all the work myself except for building the wheels, I had those done at a lbs.
    Mavic rims/XT Hubs
    Sunpeed handlebars and stem
    RaceFace Sniper grips
    Cane Creek 40 headset
    Rockshox 30 Gold fork
    Saint Pedals
    11-32 8 speed cassette
    I imagine it's under 30 pounds now, haven't weighed it.
    Attached Thumbnails Attached Thumbnails Upgraded DB Response! Post your pics!-20150915_125009.jpg
  14. #214
    Dec 2015
    I recently got one off a Facebook group for 150$ I can't post pics yet but I will when I can.
