Which Overdrive should I get?
Diamondback Adult Overdrive V 29er Mountain Bike 2012
FEATURES:
Frame: Overdrive 29" butted 6061-T6 aluminum with formed top/down tube, machined headtube, forged drop outs with replaceable hanger, disc only
Fork: SR Suntour XCT 100mm travel, 28.6mm stanchions
Rear shock: N/A
Cranks: SR Suntour XCT 22/32/42t
Bottom bracket: Sealed cartridge
Front derailleur: Shimano TX50 dual pull, top swing, 34.9
Rear derailleur: Shimano Altus
Shifter: Shimano EF-51 shifter 7-speed
Brake levers: Shimano EZ-Fire
Brakes: Tektro linear pull
Cog set: Shimano HG-20 12-32t cassette
Rims: 32h Weinmann SL-7 doublewall
Tires: WTB Wolverine comp 29" x 2.2"
Pedals: Wellgo alloy forged, CNC MTB
Handlebar: DB Lazer series 31.8mm low rise
Stem: DB AL6061 ahead 7° 31.8mm
Seatpost: DB Lazer series micro adjust 30.9mm
Seat: DB race saddle
Headset: Integrated FSA drop-in ACB upper, zero stack lower internal cup and cartridge bearing, 1 1/8"
Chain: KMC-Z51
Hub set: (F) 32h SL-7 alloy, (R): 32h SL-7 alloy cassette
Spokes: Black 14g stainless steel
Grips: DB4L 135mm Kraton
Extras: DB key chain, owner's manual, H20 bottle mounts, chainstay protector, clear coat, 3 extra inches of wheel diameter
Model: 02-12-9014
$399 + Tax at local Dicks Sporting Goods so, Total with Tax, local pickup. = $428
OR
Diamondback Adult Overdrive 29er Mountain Bike 2012
FEATURES:
Butted 6061-T6 aluminum overdrive 29r frame
SR Suntour XCT 29" 100mm fork
Sram X-4 rear derailleur with X-4 8-speed trigger shifters
SL-7 double wall rims
Tektro Novela mechanical disc brakes
KEY SPECS:
Fork: SR Suntour XCT MLO 100mm travel, 28.6mm stanchions
Rear shock: N/A
Rear derailleur: SRAM X-4 8-speed
Shifter: SRAM X-4 trigger 8-speed
Brake levers: Tektro alloy with reach adjust
Brakes: Tektro Novela disc with 6" rotors
Cog set: SRAM PG-820 8-speed cassette (11-32t)
Tires: WTB Wolverine Comp 29x2.2
Chain: KMC-Z82
Hub set: (F) 32h SL-7 alloy with CNC disc mount, (R) 32h SL-7 alloy cassette with CNC disc mount
Model: 02-12-2012
$440 delivered from another site online.
Im going to ASSuME that the one with the SRAM components, Disc brakes and the fork with the MLO (Manual Lock Out?) is the better deal. Mostly gonna be on paved bike trail for fitness with the occasional light off-road.
I personally went with the Overdrive because it has disk brakes. Although I'm only a trail rider it does the purpose.
My question is that my model has a glossy black finish with what looks to be matte "Diamondback" frame logos. Can those be removed?
FEATURES:
Rear shock: N/A
Chain: KMC-Z51
Model: 02-12-9014
OR
FEATURES:
KEY SPECS:
Rear shock: N/A
Chain: KMC-Z82
Model: 02-12-2012
- You may not post replies
- You may not edit your posts
Forum Rules
