Results 1 to 3 of 3
    Feb 2014
    Overdrive Comp vs Carbon
    Hi, could someone help me understand the differences between the Diamondback Overdrive Comp and the Diamondback Overdrive Carbon (standard)? Aside from the carbon frame, how do the components compare? Is there any area in which the Comp would have an advantage?
    I am an intermediate in terms of trail time, with limited knowledge of bikes and brands who has been riding the same bike for a dozen years and is in desperate need of a new one!
    Overdrive Comp Overdrive Carbon
    Fork Rock Shox XC 30, TK-29" w/turn key lockout, 100mm travel, ext. rebound, compression adj. FOX 32 float CTD 29" E-S, 100mm travel, CTD, O/C, 15mm QR thru axel, 1.5" alloy taper steerer, 32mm alloy stanchions
    Cranks SRAM S800 for 10spd, 44/32/22t, w/ replaceable rings SRAM X5 10spd, 44/33/22T, for PF30
    Derailleurs (F) Shimano Deore 10spd, Low clamp, dual pull, 34.9<br />(R) Shimano Deore 10spd Shadow type (F) X5 High clamp, 3X10, 34.9, dual pull<br />(R) SRAM X7, Long cage, 10spd
    Shifter Shimano Deore 10spd Rapidfire SRAM X5, 3x10 shifters
    Brakes Shimano BR-M445 Hydraulic Disc, 180mm frt / 160mm rear Rotors AVID ELIXIR 1 Hydraulic Disc, 180mm frt / 160mm rear Rotors, black
    Cassette Shimano HG62 10spd Cassette (11-36t) SRAM PG-1030 10spd Cassette (11-36t)
    Chain Shimano HG54 10spd SRAM PC-1031 10spd
    Hubset (F) 32h SL-7 Alloy w/ CNC Disc Mount<br />(R) 32h SL-7 Alloy Cassette w/ CNC Disc mount (F) 32h 15QR Alloy Sealed Bearing Disc w/ 15mm Thru Axle<br />(R) 32h 142x12 sealed cartridge bearing, 12mm thru axle, Cassette w/ CNC Disc mount, w/ Shimano E-Thru QR Axle
    Reputation: TheDocTx's Avatar
    Apr 2013
    The fork and the thru axles are the two things that are much better on the carbon bike. Not a huge difference in the two drive trains, different brands, roughly the same level. I have the Shimano BR-M445 brakes on my Sortie and absolutely love them. I am not sure how they compare to the Avids.
    Oct 2013
    The frame... The Carbon is lighter and stiffer(also thru axles front & back as mentioned).
    The fork... The Fox is an air fork, the XC30 is a coil spring.
    Components are pretty close.
    To answer your specific question. The only advantage the Comp has over the Carbon is price...
    Bike Doctor
  1. DB Overdrive Comp vs. GT Karakoram 2.0
    By m34z in forum 29er Bikes
    Last Post: 06-16-2013, 07:25 PM
  2. DB Overdrive Comp vs. GT Karakoram 2.0
    Last Post: 06-16-2013, 12:27 PM
  3. looking into overdrive comp
    By oifla in forum Diamondback
    Last Post: 08-30-2012, 10:40 AM
  4. New bike! '12 Overdrive Comp
    By stop619 in forum Diamondback
    Last Post: 04-16-2012, 03:03 PM
  5. Diamondback Overdrive Comp Questions
    By nelsonccc in forum Diamondback
    Last Post: 01-11-2011, 08:52 PM
