    Feb 2012
    Installing a Monarch Plus RC3 on a Mission 27.5
    I'm replacing the Fox Float that came with my Mission 2 27.5 with a Monarch Plus RC3, since the Float's seals blew out and won't hold pressure after one ride. The bolt used on the lower eyelet is too large for the Monarch. Anyone else run into the same problem or know where to get a smaller bolt or remove the bushings?
    Attached Thumbnails Attached Thumbnails Installing a Monarch Plus RC3 on a Mission 27.5-img_0654.jpg
    Apr 2013
    Quote Originally Posted by eric.andrew50 View Post
    I think you are supposed to remove the bushings. There are no bushings on the lower eyelet of my fox shock because the bolt is designed to fit in there. I only have bushings on the top eyelet.
    Apr 2013
    Here is the blowout chart from there tech page. They only have the old mission on there but all the stuff is pretty much the same.
    http://www.diamondback.com/Data/Site..._view_revb.pdf
    Apr 2013
    Did you ever get it installed? If so how is it and what did you have to do?
  1. Replies: 35
    Last Post: 06-17-2013, 01:13 PM
  2. Yes I know... Monarch RC3 vs Monarch Pluc RC3 vs Vivid air on a NomadC
    By sir_crackien in forum Shocks and Suspension
    Last Post: 02-05-2013, 08:50 AM
  3. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
  4. Replies: 10
    Last Post: 09-07-2011, 02:30 AM
  5. Trying to decide between '10 mission 1 and mission 2
    By Jakeowens in forum Diamondback
    Last Post: 05-07-2011, 07:40 AM
