    Mar 2011
    Bike mechanics...help with drivetrain on 2011 Overdrive
    I need a little guidance to get a new drivetrain on my 2011 Overdrive. I just bought a new chain, and it is skipping like crazy under load. On the stand, I can shift to all gears very easily. My deraileur hanger is not bent, but the crank and cassette teeth are visibly worn. I have the stock crankset on the bike, and have upgraded to Mavic wheels with Shimano disc hubs.
    I want to keep my 3x8 drivetrain, as I use most gears for different duties. Can someone point me in the right direction for a new cassette and cranks? I want to get the parts and the necessary tools to do this for less than $150 if possible. I know I need a chain whip, and a cassette lock ring tool...what else?
    Mar 2011
    Hello? Bueller?? Bueller?? Anyone have any insight??
    Did you want to do it yourself? I had a problem with a cassette skipping and took it to a local shop and $20 bucks later it was fixed with a new 13t cog they had extra and a tune up. It may just need a new cassette, the cranks are fine for a while. Take it to a shop, the least they can do is give you an estimate.
    If you are hell bent on doing it yourself, go on amazon, get an 8 speed cassette, avenir chain whip, and a cassette lock ring tool (total this could be about $40-50) and youtube the steps.
    Cheers.
    Mar 2011
    I did exactly as you said, but bought a new Sram crank, and Park brothers crank puller. I did the job myself, then took the bike to the LBS for a tune and going over. Next thing will be a new suspension fork...once I get the wife to ease up on the wallet.
  1. 2011 reign 2 overdrive or overdrive 2?
    By chef7734 in forum Giant
    Last Post: 01-12-2013, 11:12 AM
  2. any good bike mechanics / bike shops recommended west LA?
    By jasonjm in forum California - Socal
    Last Post: 10-01-2012, 07:03 PM
  3. Two bike mechanics change everything...
    By jeffgothro in forum General Discussion
    Last Post: 05-11-2012, 11:29 AM
  4. Bike Mechanics
    By mtbfyrefyter in forum General Discussion
    Last Post: 12-15-2011, 11:36 AM
  5. Mobile bike mechanics - should you tip them?
    By Sandiman in forum General Discussion
    Last Post: 03-10-2011, 09:24 PM
