Results 1 to 7 of 7
    Transition Blindside v5
    Reputation: PiroChu's Avatar
    New question here. BB shell/spindle size & chainline for '08 Response (SM) ?
    Hi all,
    Just picked up an used '08(-ish?) Response (16"/SM) that's set up as a singlespeed dirtjumper rig, and need to replace its BB. Does anyone know the BB size / chainline?
    Simply measuring the frame, the shell width is 73mm, but I don't know if I need x113mm or x118mm spindle length (in case of ISIS-type BB). (If I can't figure it out, I guess I'll just go with an external BB crankset.)
    Thanks for your info in advance,
    - PiroChu
    __________________
    - PiroChu
    '11 Transition Blindside (v5)
    Northern California (Bay Area)
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    YeaH its a 73, just get a EXO BB, works on anything, and so much lighter than that lower end stuff.
    ~~~~~~Singletrack Slayer~~~~~~~
    Quote Originally Posted by DavidNeiles
    Does anyone know the chainline for Response?
    Yeah, true, <a href="http://www.bike-components.de/bedienungsanleitungen/fsa/gravity/mega_exo_and_bottom_bracket.pdf
    ">EXO-type BB</B> is much simpler (as I already have one on my other/main bike). But I was curious, just in case of ISIS-type.
    __________________
    - PiroChu
    Singletrack Slayer
    I am sure it is a 113 spindle for bb, as for chain line, what are you refering to! Chainline is just more either a SS setup as in your "chainline" should be straight on; or geared bike where crossgearing is bad for the "chainline", Not sure what numbers you need dude!
    This is "chainline"...
    http://www.sheldonbrown.com/chainline.html
    So, the number I'm looking for is like "48.5mm" or "51mm", etc.
    See some example figures in a chart on the left-bottom corner on this...
    http://www.sram.com/_media/techdocs/...-4arm-e-r2.pdf
    (and http://www.fullspeedahead.com/downlo...nstruction.pdf)
    If you're absolutely sure about "113mm" (spindle length), then I know it's "48.5mm" (chainline), or vise-versa. Either way, I need a "confirmation". (If not, then EXO.)
    __________________
    - PiroChu
    Singletrack Slayer
    Yeah I see what your gettting at, I never have had to think about the numbers there, just use what works! Pretty standard stuff there and common sense it seems to a degree. That is very anal , never had to deal with measuring a chainline in 13 yrs. And I am anal lol
    Well, I'm anal and cheap, LOL!
    Anyway, I just called Diamondback (253-395-1100), and a very helpful person helped me out. The '08~ models need 73mmx113mm BB, while ~'07 models need odd 68mmx108mm(!?) BB (and that's probably why <a href="http://www.bikeforums.net/showthread.php?370042-need-correct-Shimano-BB-model..">this guy</a> had a prob with his '07).
    So, your recollection of x113mm was indeed correct/confirmed, thanks.
    - PiroChu
    __________________
    - PiroChu
