Results 1 to 2 of 2
    Feb 2015
    New question here. 2014 Axis Pro - 27.5 Max Rim Size Supported
    Hello everyone!
    Iíve got a 2014 DB Axis Pro with the 27.5 SL-7 wheelset. Iím looking to upgrade the rims on my bike but am not sure how wide of a rim this bike supports.
    I measured the clearance between the chainstays (where the tire appears that it will rub up against first, near the bottom of the seat tube) to be 67mm. The current exterior width of the rim is 26.4mm and the full width of the inflated Racing Ralph tires (side wall width size marking of 2.25in) is 53.4mm.
    Does anyone know how I can calculate the maximum rim width that is safely possible for my bike using these measurements?
    Iím considering the Easton Arc wheelset, but am not sure which size rim width I can fit (including tire) on this frame.
    Feb 2015
    I decided to approach this question from the aspect of how the overall width of the tire changes by keeping the width of the tire fixed and increasing the width of the rim. After reading up on a couple of sources (on this site and others), I'm getting the impression that the overall width of the tire will not change as the rim width is increased. What will happen is that the tire will essentially stretch in the middle creating a larger contact patch on the ground among other affects. If anyone has confirmed this to be true, could you please chime in?
    One thing to keep in mind is that each rim width has an appropriate range of supported tire widths.
  1. Gimbals 2 axis vs 3 axis pros and cons
    By RojoRacing53 in forum Videos and POV Cameras
    Last Post: 06-20-2017, 05:02 AM
  2. 2014 Diamondback Axis Sport Bottom Bracket
    By DBKefir in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-01-2015, 03:04 PM
  3. OEM Stem size on 2014 Carbon Flash size Large?
    By nkingdon in forum Cannondale
    Last Post: 07-21-2014, 07:13 AM
  4. Thoughts On DB Axis Sport 2014
    By dhindo in forum 27.5
    Last Post: 04-11-2014, 05:13 AM
  5. 2014 Trans Am Bike Race (4,233 miles of self supported road racing)
    By Nathan Jones in forum Bikepacking and Bike Expedition
    Last Post: 11-22-2013, 09:11 PM
