    Sep 2013
    2010 Mission headset damage
    OK so UPS dropped off my new to me 2010 mission, and they had kindly crushed a corner of the bike box. At first I thought all was ok, but then realized the top headset bearing would not set into the top cup. That is when I realized the top cup was dented. Thankfully the head tube itself is OK. It's an FSA Gravity Pro SX headset, which I believe came stock from the factory. Can anyone steer me in the right direction to find a replacement top cup??2010 Mission headset damage-img_20131110_160238_223.jpg2010 Mission headset damage-img_20131108_173802_619.jpg2010 Mission headset damage-img_20131110_160543_226.jpg
    Sep 2013
    Ok, so no replies so far....
    FSA does not sell/have in stock just the top cup race.
    I have thought of two options for repair, order an entire new FSA headset, exact factory spec replacement.
    Or, I can pick up a Cane Creek 40 series top end locally, leave the stock lower as is, and just use the CC top set.
    I don't think it would cause any issue to have the mismatched top and bottom...
    Any opinions good or bad to these two options?
    Jan 2005
    I would probably replace the whole thing. Might not totally be necessary but its 3 years old so its probably time to replace the bearings anyway. That way when your done you know it will be 100%. If money is tight as long as the bottom bearing feels fine you won't have any issues using the cane creek 40.
    Sep 2013
    Yeah, I ended up ordering a whole new headset. Only reason I thought of using the CC top end was because I could get it local. But I'm still dealing with UPS so I can wait for the new FSA to be shipped.
  1. What size headset for 2008 mission
    By Professional in forum Diamondback
    Last Post: 08-12-2012, 09:07 AM
  2. Steerer damage + headset adjustment
    By B.BL in forum Tooltime
    Last Post: 05-08-2012, 04:49 AM
  3. 2009 Mission 2 Headset Help
    By mtbks in forum Diamondback
    Last Post: 11-27-2011, 01:03 AM
  4. Diamondback Mission headset specs
    By gschacht in forum Diamondback
    Last Post: 10-28-2011, 06:53 AM
  5. Mission Headset Question
    By airtym in forum Diamondback
    Last Post: 10-06-2011, 02:53 AM
