Results 1 to 8 of 8
    New question here. 1999 DBR XR-4 Suspension/Frame Bushings?
    I'm looking for parts for a frame... specifically the bushings for the rear suspension links on a 1999 DBR XR-4... any ideas if these are still made at all? and if so, where to get them? I was thinking of attempting to call diamondback but I don't know if they'd even have a source for them... Anyone?
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    YOu can buy bearings from an LBS; they have access to companies like QBP, Hawley, J&B; who have bearings in there catalogs.. press out old ones and measure them, you should be able to find a new set. Measure OD IN and thickness And take the old ones in to them to make double sure...
    ~~~~~~Singletrack Slayer~~~~~~~
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    That frame uses bushings not bearings......
    You can call Diamondback, but don't get your hopes up as last time i looked for replacements for mine(8 years ago) they were clueless & helpless. If you really need to rebuild it i would look locally at some industrial supply houses & see if they can get you a generic replacement. Yes,take the bushings with you
    SPD pedals are an absolute menace to the well-being of the world, and ought be banned immediately.
    Alright, some good suggestions. I'll see what they say if I call haha
    Did you have any success? Im facing the same problem with my 2000 X6.
    Quote Originally Posted by bengxe View Post
    No dice... haven't found anything yet.
    I have a 98 Vlink 3.2 and in the same boat....
    This did nothing but cause confusion when I emailed to my local bearing shop, but I will attach it anyway.
    Your best bet is to take the bushings in and let them get as close as they can.
    Let me know if you find any I need them for my 2000 x link!.
    Attached Thumbnails Attached Thumbnails 1999 DBR XR-4 Suspension/Frame Bushings?-diamondback-schematic.jpg
