Results 1 to 17 of 17
    Dec 2016
    160mm fork on release 3?
    Has anyone put a 160mm fork on a release? I think I saw a orange/black release on the thread with a 160, I could be wrong tho.
    In a month or two I want to put a fox float x2 in the back and a 160 fox 36 in the front.
    My release three came with a high stack, I think if I slammed the bars down and gave it a 160 that the bike would not change a whole lot.
    Do you guys think otherwise?
    Sep 2017
    I think you can also convert the Pike RTC3 that comes on the r3 to 160 so I'd be interested to hear about this as well.. from what I understand, the frame *should* be able to handle it, but this is what you're going to do:
    1. slacken the head angle
    2. raise the bb slightly
    3. shift your weight more onto the back tire
    4. slacken your seat tube as well I guess
    5. theoretically put more stress on the frame, mainly the head tube welds to the main triangle
    6. possibly un-balance the bike more because it will now be 160F/135R
    That being said those are mostly neutral or potentially bad things that could happen. If you're looking for more travel this might be your answer, and it might be a really fun bike! I know designers have things in mind when they carefully plan and design a bikes geometry, not sure if you'd be screwing with it or just giving the bike a different feel/specialty for a certain type of riding.
    Dec 2016
    Quote Originally Posted by seattleUpPartner View Post
    Very good thoughts, the only thing that I would care about it is the change in the seat tube. I'm running the seat right in the middle at the moment, meaning I still have the room to slide it forward and drop the nose if I need to.
    I'm going to look into raising the pike to 160
    Reputation: watermonkey's Avatar
    I would consider running the fattest tire that will fit in the back end if you go 160mm up front. That's a pretty big difference in travel, and the front with be writing checks the back can't cash. The extra rubber may help to offset that somewhat.
    I would advise not taking my advice.
    Sep 2017
    Quote Originally Posted by watermonkey View Post
    You've got a point but one could also argue that hard tails commonly have a mis-match of 120F/0R for their suspension.
    Dec 2016
    Yup, I'm not worried about 10mil.
    Dec 2016
    I really don't think the front will become a different animal that the back cant keep up with. I never get to the bottom and think about how my legs have been thrashed.
    But yes a bigger tire in the back will and does help, that why she already has a 2.6 out back
    Quote Originally Posted by JPinReno View Post
    What 2.6 are you running?
    Sent from my Pixel XL using Tapatalk
    Dec 2016
    Quote Originally Posted by avc8130 View Post
    Magic Mary
    Magic Mary
    Nice. Front and rear? Any review of the setup? Any pics?
    Dec 2016
    Yes front and rear, addix orange(soft) compound. The increased contact patch on the ground is very noticeable under braking, cornering and climbing technical features. The added air volume in the tire has really made the bike feel like it has 10mm more suspension. I actually don't have any pics of the set up and the frame is in many pieces at the moment or I would go snap one.
    I have only had the bike out in "hero dirt" situations since I mounted them. But I can already tell than I'm never going back to a 2.3. I will also say that I've spent a fair bit of time on the salsa pony rustler, and I don't like the plus size tire.
    Better review and thoughts in a month or two. I've been running the 2.6 for 3 weeks.
    Sep 2017
    if you had a chance could you post a picture of the rear clearance with the 2.6" MM? these HD's had a good run.
    Anyone think about a Rock Razor for the rear to go with an MM up front?
    Yeah, I'm that a$$hole.
    Reputation: Guy.Ford's Avatar
    Here is a large Release 5C with a 160 RS Pike RCT3.
    I will be purchasing a 5C this week, will be upgrading the Fox 36 to 160 and adding a Fox Dhx2.
    Sent from my SM-G935T using Tapatalk
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    May 2005
    I just modified my Pike fork to 160mm on my Release. This improved the bikes ability to descend quite a bit. The little extra travel really helped with hand fatigue on long rough sections and the bike felt a little more stable at high speed.
    I don't feel that it changed the bikes ability to climb much. I moved the seat forward slightly to stay over the pedals a little more and had no problems.
    Overall I have been very pleased with how this bike rides and will be keeping the fork at 160mm in the future.
    Agreed this bike deserves a 160mm fork, it's descending prowess is equal to the task. I'd say unless your strictly using your Release as an XC rig and not really pushing it, 150 is fine, but if you really want to push it 160 is #WINNING.
    #THELEGENDMTB
    2016 RSD Mayor
    May 2005
    With 150mm this is a fantastic all around bike. The geometry let's it do everything decently well. With the 160mm fork I was really able to turn it up a notch on the descents. This mod may keep me riding this bike for another year (currently on my 3rd season with this bike).
    For the $50 in parts and 45min of work took to change the forks travel I definitely think it was worth it.
  1. How difficult to transition from Shimano multi release to single release?
    By legitposter in forum Apparel and Protection
    Last Post: 10-17-2016, 07:46 PM
  2. Replies: 4
    Last Post: 07-14-2016, 12:53 PM
  3. Which 2016 Fork? 160mm Pike or 160mm Lyric for 650b
    By JNG in forum Shocks and Suspension
    Last Post: 09-07-2015, 11:36 AM
  4. Replies: 3
    Last Post: 04-28-2014, 01:20 PM
  5. Downsizing rotors from 185mm/160mm to 160mm/140mm
    By xterrafreak in forum Brake Time
    Last Post: 02-26-2013, 12:03 PM
Members who have read this thread: 36
