Results 1 to 5 of 5
    Jan 2015
    Yeti ASR c vs Pivot Mach 429sl vs Devinci Atlas Carbon
    Based on what is available around and my style of riding I stopped my choice on these 3 bikes. But I will not be able to test them.
    The Devinci Atlas C is at 1000$ less than the 2 others.
    I intend to build it with Sram X01 .
    I'm 6'2" 210 pds.
    Rocky, rooty, tight, doing mostly technical XC- trail riding with a few races (50 to 80kms) each year.
    Any experience or suggestion
    Reputation: d365's Avatar
    all 3 are winners. you could throw darts to decide, or you could go ride them to find which you like best....
    The Atlas was at the top of my list, but has been bumped off by something Evil. The Atlas has a lot going for it though.
    Reputation: Colin+M's Avatar
    Evil Following owner here. Love it. It would be my number 1 pick. Of those you listed I'd probably choose the Pivot. However if you want the lightest one of the three the Yeti would be it. I would worry that at 210 lbs it wouldn't be stiff enough of a frame for you in those trail conditions.
    Quote Originally Posted by Colin+M View Post
    Ride em all, pick the one you like best.
    I really like my Atlas, never tried the other two. The Pivot is certainly popular, rode with one the other day, my buddy just got it, he seems to like it.
    I'm flogging the Atlas pretty hard, already bent the hanger bopping off a boulder, bent it back and all is good
    Reputation: AGarcia's Avatar
    Feb 2012
    I'm a bigger guy at 235lbs. I can't speak to the attributes of the Yeti or the Devinci, but I demoed the Rip 9 (with 120mm Pike), Jet 9 (with 140mm Pike), Intense Spider (with 130mm Revelation), Ibis Ripley (with 120 and 140 32mm Fox CTD) and Pivot Mach 429SL (with 120mm Fox CTD), each on trails I've ridden lots of times before buying.
    I ended up with the Pivot 429SL. I thought the Pivot was the most efficient climber of the bunch (with the Ripley right behind it). I also thought the Pivot descended quite well (although I thought the Intense was the best decsender). I found the Pivot to be the best blend of attributes for me.
  1. JET 9 RDO vs YETI ASRc vs Pivot 429SL??
    By SUB1647 in forum 29er Bikes
    Last Post: 01-23-2015, 08:58 AM
  2. 2015 JET 9 RDO vs Yeti ASRC vs Pivot mach 429sl??
    Last Post: 01-18-2015, 02:37 PM
  3. Replies: 0
    Last Post: 10-18-2013, 11:56 AM
  4. Mach 429 vs. Devinci Atlas
    By irishpitbull in forum Pivot Cycles
    Last Post: 03-14-2012, 09:27 AM
  5. DEvinci Atlas vs Mach 429
    By briandwyer in forum Devinci
    Last Post: 02-25-2012, 09:00 PM
