Results 1 to 2 of 2
    Reputation: buddiesconfusion's Avatar
    Troy with Cane Creek Shock
    I'm looking into a used Troy frame that needs a complete shock overhaul. I'm considering ordering up a CC DBinline or CC DBcoil iL for the troy. I'm looking to hear from some Troy owners who have upgraded to a CC. Are you happy with your CC upgrade compared to the stock RS?
    May 2010
    I emailed them recently about putting it on my carbon troy. Here's what they said:
    The Troy is a progressive frame so it would work pretty well with a Coil IL. However the problem you may run into is the stroke length of the bike. Since the Troy has such a short stroke length (50mm) you will have to run a pretty heavily rated spring. At 195lbs you would need a 550 to 600lb spring.
    We have our new Valt spring in only a 500lb x 2.0 but our standard spring is available in a 550lb x 2.0.
    Let us know if you have any questions.
  1. Cane Creek AD-10 / AD-12 shock
    By bad mechanic in forum Shocks and Suspension
    Last Post: 08-29-2016, 05:41 PM
  2. Clydes and the Cane Creek DB Air shock
    By reamer41 in forum Clydesdales/Tall Riders
    Last Post: 03-14-2015, 12:41 AM
  3. Replies: 18
    Last Post: 12-24-2014, 04:28 PM
  4. Cane Creek Inline on Troy
    By Bikerbob.com in forum Devinci
    Last Post: 09-04-2014, 09:18 AM
