Results 1 to 2 of 2
    Reputation: ttimpe's Avatar
    Nov 2015
    2014 Troy frame with 29er 140mm fork
    Has anyone ran a 29er fork on the Troy frame? It's a 27.5 frame but I have a 29er fork. Also will 2.5 tires fit?
    As the Troy is being ridden with a 160 fork by some riders, going to a 29'er fork in a 140 setup should not be too off on the a2c side. The Troy can take a 2.35 tire on a 35mm insidewidth rim in the rear, and I bet you could go for a 27,5 in a 2,8 width in the front
  1. Frame says 140mm travel fork. Can I use a 100mm fork instead?
    By Flydyl in forum Bike and Frame discussion
    Last Post: 09-15-2015, 10:06 PM
  2. Can a 2014 Fox 34 Evolution 120mm fork be converted to 140mm?
    By keithrad in forum Shocks and Suspension
    Last Post: 08-21-2014, 09:22 AM
  3. 140mm Fork for 2014 Trek Fuel EX 5
    By Cheesecakeslash in forum 29er Components
    Last Post: 05-02-2014, 09:41 AM
  4. White Brother 140mm Loop 29er vs Manitou TOWER PRO 140MM 29er
    By hang10jeff in forum Shocks and Suspension
    Last Post: 09-13-2013, 11:32 PM
  5. 140mm 29er fork help!!!
    By Judders in forum Shocks and Suspension
    Last Post: 03-21-2013, 03:38 PM
