Results 1 to 5 of 5
    Reputation: nummbr7's Avatar
    Aug 2013
    2014 dixon carbon 150mm or 160mm pike?
    Just got a good deal on a dixon carbon frame, going to pick up a pike soloair, trying to decide if I should get a 150 or a 160. I live and ride in VT, and there's lots of climbing in the green mountain state. But I love the DH and want to make sure its slack enough/confidence inspiring for gnarly descents
    I'm coming off a 2010 specialized pitch with a 2011 150mm fox 32
    I also had a 2012 Turner 5 spot with a 2013 fox 34 160mm
    I never had any problems climbing with either on the trails I ride
    I also had a 2011 Trek Scratch Air 9 that I thought climbed fairly well for what it was, without using the horrible talas.
    The really short chain stay just has me a little concerned it will be a wheelie machine on climbs with too much fork
    May 2010
    I'm in the same boat, grabbed a Dixon carbon frame a few weeks ago. After reading here and some at The Devinci Dixon - my build and review. - Pinkbike Forum I settled on 150mm. I can adjust the fork I chose internally easy enough through so I intend to go 160 if I feel it's lacking. I highly doubt I'll feel that way though since I'm coming from a 100mm XC setup and don't intend to change the terrain I'm on much.
    Aug 2013
    I went with the 160, it feels great and actually seems to have less head angle than my pitch using a angle app, my pitch is 67.02 and the dixon is 67.25. The bb does feel a little high but it climbs great, and really confidence inspiring when pointed down
    Your probably safe with the 150 coming from a xc bike, just keep in mind you can't change the travel on a pike like other rockshox forks, tou need a new air shaft
    May 2010
    Awesome info man, thanks for the heads up. Where abouts do you ride if it's already dry enough in VT to get out?!
    Aug 2013
    its not really dry enough, they opened pine hill park in Rutland just for this weekend, there's also a place not to far from my house in Middlebury, called chipman hill , seems to dry out before other places
  1. making a 150mm pike a 160mm
    By geinsteder in forum Santa Cruz
    Last Post: 09-13-2015, 10:03 PM
  2. Rockshox Pike 150mm to 160mm?
    By PARMAGEDDON! in forum Shocks and Suspension
    Last Post: 07-07-2014, 07:42 AM
  3. 2014 Pike 160mm Air Spring compatible with a 160mm Lyrik?
    By hafnz in forum Shocks and Suspension
    Last Post: 05-05-2014, 10:55 AM
  4. Replies: 0
    Last Post: 10-09-2013, 11:21 AM
  5. Pike 150mm vs 160mm
    By dutchct in forum Shocks and Suspension
    Last Post: 06-14-2013, 12:36 PM
