Results 1 to 10 of 10
    May 2013
    what's wrong with long pull v-brakes for CX?
    My gravel/cross bike has Avid Single Digit (Mountain bike) brakes with the appropriate long pull road levers (Tektro R540, bike is a SS so no shifter issues). Works fine.
    What is the disadvantage of this vs cross-specific mini-v brakes (TRP)? The weight difference is VERY small, so I'm inclinded just to keep 'em and enjoy the greater clearance with the mountain brakes, but didn't know if this put me at aome mechanical disadvantage or if there was some other drawback to this setup that I'm missing.
    I think you answered your own question: The shorter CX brakes are made to work with the leverage of the road levers found on CX bikes.
    May 2013
    Thanks... that's what I thought... as the levers in use are designed for long pull (atypical for road levers), It looks like I'm not at any disadvantage w this setup.
    Reputation: AlexCuse's Avatar
    Re: what's wrong with long pull v-brakes for CX?
    Probably at an advantage on more technical terrain
    Yeah I only carry cans cause I'm a weight weenie.
    Aug 2013
    I installed TRP 8.4cx brakes on my cx bike at the weekend. *Much* better braking power than my Avid Shorty Ultimate Cantis, but a total pain to set up - my wheels are *slightly* out of true, and I can't seem to set up the brakes without slight pad rubbing ( I spent a day on this at the weekend).
    My wheels are only ~6 weeks old and have taken very little punishment, so I have no clue what I'll do when they are really bad and properly warped... I'd say that this is possibly a big mechanical issue to come.
    Roll on my next cx bike, which *will* have disk brakes (I can't believe that I was convinced against this last time around) :s.
    2018 Cube Reaction Hybrid Race 500
    2016 Radon Slide 130 10.0 HD
    2014 Scott Aspect 740
    two things why they aren't used (much):
    as mentioned.... Cable pull. You'll see some people use the "travel agent" to overcome this.
    secondly - mud clearance. This is why canti's have remained the general spec on non-disc rides.
    Aug 2013
    Quote Originally Posted by Walt Disney's Frozen Head View Post
    I do wonder about this reason in reality. (Not a criticism of your post, just a general thought!)
    I always do wonder how many people with CX bikes actually ride 'real' CX, or even get them muddy. I know that I use my bike mainly for long rides where there are different surfaces (eg ride starts on river path, then up in the hills, singletrack section, then a road blast home), fast commuting and generally as a 'bike for all conditions' - I have never done a real CX race.
    For all of my riding (except maybe deep midwinter, but then I take my mountain bikes), the TRP mini-v have been a much better solution than Cantis.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Thats what im using on my pompino and they're more than enough brake. Only place they come up short is on long descends where youre constantly dragging the brake in order to check speed. I have mine set up with digit levers and a mary bar. fun as ****
    Mar 2014
    Quote Originally Posted by Marc2211 View Post
    In that case, there's no reason at all not to use full-size V-brakes if you have the levers to do so.
    Beyond that, even for those who do race in the mud, this reason is marginal. Mini-V's with short pull levers have exactly the same mud clearance issue as full-size V's with long pull levers, and I know a number of people who use mini-V's in the notoriously muddy Cross Crusade series.
    Here's a picture of my bike after a particularly muddy race:
    If you look close you'll see that's a traditional cantilever brake under there. The mud clumped on the brake was definitely slowing me down. A V-brake would have had less mud clearance, but I'm not sure it would have accumulated any more mud. Disc brakes might have helped if the pads survived the race.
    My thinking is that with the kind of mud that clumps on your brakes the difference between 2mm clearance and 7mm clearance might not matter.
    carlo russo
    work very well ..
    but a total pain to set up - my wheels are *just slightly* out of true, and I can't seem to set up the brakes without slight pad rubbing..
    and i needed a cable stop to use trp's on the swiss cross
  1. What's wrong w/ my new brakes?
    By tealboy1 in forum Brake Time
    Last Post: 03-30-2014, 06:44 AM
  2. What's wrong with my SLX brakes?
    By AK47 in forum Shimano
    Last Post: 07-30-2013, 07:40 PM
  3. XTR brakes are wrong way around
    By BigwheelsRbest in forum Brake Time
    Last Post: 10-25-2012, 06:01 PM
  4. long pull or short pull levers for mech. disc brakes?
    By westcoaster in forum Brake Time
    Last Post: 12-23-2011, 02:32 AM
  5. V-Brake back to Center-pull Cantilever Brakes
    By hellraiser_trailblazer in forum Brake Time
    Last Post: 06-13-2011, 11:47 PM
