Results 1 to 7 of 7
    Jan 2014
    What's better to upgrade first? Wheels or brakes?
    I posted before about building up a new wheelset, but I think I will just use my old 29er wheelset for single track riding and keep my current set for road and cx training, but am not totally sure.
    I will have about $500 saved up for my purchase. I can either go for a new wheelset with better hub and rims, buy better rims for my current hubs (tubeless ready rims - probably Stans Iron Cross or ZTR Crest) or go for a new set of brakes. The brakes would be TRP Hy/Rds.
    Since you already have disc.... why upgrade the calipers immediately?
    It's not like you have canti's and desire more braking versus the non-existent braking power of cantis.
    So, imo, I would go with a new wheelset first.
    what brakes do you have? ya if you already have discs get wheels. I'd get the iron cross as long as you never need to run more than 40 psi.
    Aug 2010
    Quote Originally Posted by EastPhilly View Post
    Sounds good. Spend the $500 on riding more.
    Fat & Single
    Reputation: ozzybmx's Avatar
    Get a set of the Light-bicycle or similar XC carbon rims for approx $300, 21mm inside width, weight 370g and good for 70psi, then build them up on your old hubs.
    I have a set built up on my CX and they are bulletproof.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Clueless Bastard
    Reputation: WA-CO's Avatar
    Nov 2013
    Quote Originally Posted by ozzybmx View Post
    Crazy, but I've been stewing on an IBIS Hakkalugi, with a mid range Campy drivetrain, TRP brakes, and building a set China hoops with WhiteInd centerlock hubs.....Wish that frame had fendermounts for the sloppy days.
    Fat & Single
    They are great wheels, nice and stiff.... and way over built for CX, but the weight and width really give you the proper tyre diameter. A 33c is at least 33mm wide on them.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  1. Should I upgrade wheels? What makes the upgrade worth it?
    By stygz1 in forum Wheels and Tires
    Last Post: 11-04-2013, 10:34 AM
  2. brakes upgrade
    By vichila in forum Downhill - Freeride
    Last Post: 11-20-2012, 02:13 PM
  3. Replies: 6
    Last Post: 04-09-2012, 01:13 PM
  4. Replies: 22
    Last Post: 07-01-2011, 01:08 PM
  5. Replies: 8
    Last Post: 04-03-2011, 04:07 AM
