Results 1 to 9 of 9
    Stokeless Asshat
    Reputation: jeff's Avatar
    Vintage build bar questions.
    For those that have been in the scene since the 90's...I need some help. I'm building up a mid 90's Bontrager CX that has been hanging for far too long. Shooting for era correct build, I've settled on most of the spec, with the exception of the bars. I lean towards 44-46 and short and shallow. I wasn't into the road or CX scene back then so I'm somewhat clueless as to what was available. If it's info you need, I'll be running Ultegra 6403 levers and 64 series 8 speed bar ends.
    Thanks..
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    There weren't too many cross specific bars then. Maybe WTB or Specialized, rebranded WTB, would do. Good luck
    A garage full of steel frames means happiness.
    little mad riding hood
    Quote Originally Posted by CS2 View Post
    ^^ this. 'cross pretty much hit its nadir in the mid 90's in this country. There were a few super niche weird things floating around but probably the MOST common 'cross specific mid-90s drop bar configuration I recall seeing was 8-speed twist shifters retrofitted onto a standard crit bend bar - you cut a few cm off the ends of the drops prior to installing the twist shifters to prevent the extra length interfering with your knees.
    Salsa Bell Laps would look period appropriate too if you don't want to go retro dorko with the twist shifter option.
    probably 60% of the guys I remember racing 'cross in those days, at least in local series, raced their old steel rigid flat bar 26" junkers. And courses were pretty much winter MTB races; here is where the term "jungle cross" originated from, actually. Guys racing imported drop bar Euro rigs were often at a distinct disadvantage, which is why so many rules about course configurations actually came into being, if you ever wondered.
    Eli Broccoli
    Reputation: 123elizxcvbnm's Avatar
    I have the Soma Highway One bar. Classic look with modern reach and drop. Heavy but looks nice!
    Stokeless Asshat
    I ended up with some 3TT Forma's. 44w-76r-152d. Ergo bend, cable grooves and mid 90's vintage from what I understand. Pretty modern looking actually.
    Want:
    CS2
    CS2 is offline
    Quote Originally Posted by jeff View Post
    Sounds like a good choice. Post some pictures as build progresses. Good luck
    Does your bike have a threaded headset and 25.4 handlebar clamp size? My first choice would be a Nitto, either the Noodle 177 or Dirtdrop RM 013 maybe the 105.
    Stokeless Asshat
    Stalled but coming soon. Just need to lace it up and wrap the bars.
    Want:
    Stokeless Asshat
    Threaded 1" 26.0.
    Quote Originally Posted by Saddle Up View Post
    Want:
  1. Vintage build thread (classic Yetis)
    By eayste in forum Yeti
    Last Post: 03-27-2017, 10:32 AM
  2. Vintage 650B build- GT Tachyon
    By djmuff in forum 27.5
    Last Post: 10-31-2016, 09:37 AM
  3. Replies: 7
    Last Post: 04-19-2014, 05:18 PM
  4. Vintage Build - El Chamuco
    By jbf in forum Ventana
    Last Post: 03-07-2012, 06:23 AM
  5. 1996 or 1997? Ventana El Habanero Vintage Build Day 1
    By aa240sx in forum Vintage, Retro, Classic
    Last Post: 12-15-2011, 04:18 PM
