Results 1 to 11 of 11
    Reputation: classrc's Avatar
    Velocity a23 or ZTR Alpha 400?
    Looking for a strong, light-ish rim for my commutor/gravel/occasional CX bike... Needs to be rim brake and tubeless compatible...
    Ready... Discuss.
    Reputation: AlexCuse's Avatar
    Re: Velocity a23 or ZTR Alpha 400?
    Either will build a fine wheel. I like stans on my mountain bike so thought I would try them there and haven't been disappointed (except with tubeless tire selection). Because the setup is so much more finicky than on a MTB I find I just keep tubes in so I can air up high for road rides except during cross season where the grip at low pressures is too good to pass up. Would like to eventually have dedicated cross and road wheelsets with appropriate tubeless tires but not in the cards for now, and I cant seem to find one tire that excels for both but I'm pretty heavy (220lbs).
    If you're on a budget get the cheaper one and put the difference into the nicest rear hub you can get IMO
    Yeah I only carry cans cause I'm a weight weenie.
    Thanks for the reply... I'm about 215 lbs at the moment, but on a steady glide slope down...
    I like the idea that the Velocity rims are made in Florida and they are headquartered in Grand Rapids, MI (I'm in Michigan)... I've had absolutely no issues with my 3yr old Flow rims, always tubeless..
    I plan on running Clement X'Plor USH tires tubeless... X'PLOR USH | Clement Cycling, Cyclocross Tires, Adventure Tires, Mountain Bike Tires, Road Bike Tires
    Jul 2013
    my .02$ is that the velocity will build a stiffer wheel and the stans will be a lighter more lively wheel.
    ive built wheels to both, well the velocity was a major tom which is nearly the same just tubular. the stans extrusion seems softer and at tension has a nervous look to the spinning wheel. the Velocity (as is the case with almost all of them i have built) is much stiffer feeling with a distinct high spot likely from the manufacturing process where the extrusion is formed into a hoop. the high spot can be massaged out but takes patience.
    Another option would be the new Ardennes Plus wheelset which comes tubeless ready. HED Cycling Ardennes¬*PLUS
    Quote Originally Posted by Stoney.Sanders View Post
    My old Voodoo Wazoo takes a 135mm rear hub...
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    The Stans 400s are a PITA for tubeless setup. Dont understand why they couldnt make the bead channel the same depth as their MTB rims. Instead, its deeper and harder to air up the tires.
    But once set up, my alpha 400s are super stiff and strong. I did blow a michelin mud 2 off the rim though, which is pretty scary. Fortunately, it was the rear and I was moving slowly.
    I think you would be best suited with "tubeless ready" tires.
    Never tried the A23s!
    Raised in a Chicken-Coop by Chickens
    Definitely go with tubeless ready (there are only a couple of options out there now). The folding beads on cross tires aren't really up to the challenge of even moderate pressures on the road, and I'm not sure how well the wire beads would stay attached to the rest of the tire. I had a continental that wasn't tubeless ready tear off the front rim on a very slow, sharp turn at around 45 psi. Also had a tubeless ready vittoria blow off the rim at about 75 psi (to be fair it was a hot day and I was climbing back up after a scorching downhill on rough pavement - the heat could have pretty easily taken it past the 90 psi limit). I was *much* more confident in the tubeless ready tires up until that point though.
    I too find the alpha 400's really stiff. Haven't ridden an a23 in a while but the 400's feel stiffer than I remember them - don't know the build details of the a23 set I tried though (my 400's are ultegra/supercomp). Looking at the cross-sections of both I guess I'm not surprised. And tubeless setup is a challenge but once they go on they're pretty secure. If you do go with the a23's I'd love to know how easily you get them set up tubeless
    IMO you have picked 2 rims that give a good bang for your buck, and you've already gotten it right even if you flip a coin. According to this the a23 is a tiny bit wider so they might open up big tires a bit better: NoTubes Alpha, Velocity A23, Mavic Open Pro rims internal measurements | Just Riding Along - the blog
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Ive been on the 32H A23's with tubed X'Plor USH laced 3x to DT 350 hubs for a while. I've had um set up with BB7s and v-brakes, SS and fully geared. You cant go wrong. YMMV
    Now about 95% sure I'll be getting the a23's. I'll run them tubed for now. But will experiment with tubeless in a while... Thanks all!
    Reputation: Nater's Avatar
    Another option is the Pacenti SL23. Says tubeless friendly design.
    BikeLugs.com
  1. Wingnut MPS Alpha review
    By eightballrj in forum General Discussion
    Last Post: 12-09-2012, 12:17 AM
  2. anyone knows sth about the Shamann alpha tubing?
    By hansghost in forum Custom Builders & Other Manufacturers
    Last Post: 10-25-2012, 06:31 AM
  3. Velocity P35 vs. Velocity Blunt rims?
    By danwerle in forum 29er Bikes
    Last Post: 09-03-2011, 01:49 PM
  4. PVD Gemini (Alpha)
    By pvd in forum Frame Building
    Last Post: 06-03-2011, 12:53 PM
  5. Alpha Trek 4300
    By mykg0713 in forum Where are the Best Deals?
    Last Post: 04-13-2011, 07:45 PM
