------__o
----_`\<,_
---(_)/ (_)
Looks to be identical to the Traitor Crusade.
The only thing I see that is different is the head tube logo on the Crusade, which is way cooler.
Wow, even the color is the same as the Crusade. Nice looking bike though.
I had never heard of Traitor cycles until now, and I own two Transitions. Hmmm
They are all apart of the some company. The Crusade was launched under traitor but they felt that it would also do well under the transition brand and it's dealers. It is the same frame. I would still rather have Transition on the frame though.
------__o
----_`\<,_
---(_)/ (_)
I could care less about the name.. I want the sexy green transition color!!!
Thank god for the threaded BB.
Transition Rapture
I'm seriously considering this bike built up as a SS. This would be my first SS. Or first CX bike for that matter. Are the adjustable drop outs another way of tensioning the chain? Or would I need a tensioner like the surly one ??
This is all you need. They have about .86" adjustment so you can assume that you have to be within one link for the correct chain tension. Admittingly, this style dropout has less adjustment than horizontal sliders along with less chainstay length flexibility, the system still works all the same, and the setup learning curve with the brakes is very minimal because the top bolt is fixed so one extra bolt to adjust...minor inconvenience and performance won't be effected.
My only complaint with with this frameset, and the reason I haven't contacted Transition for a quote w/ the ENVE fork is the fact that there is only one set of bottle cage braze-ons located on the seat tube. Since I will be using this as a gravel grinder/road bike to ride to the trails and on the trails type of bike, the second cage is pretty important. I understand why it doesn't have two sets of braze-on's for shouldering purpose, and it is marketed as a CX racer.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Spech Tricross Expert
Raleigh RX 1.0
Thanks for the clarification. It never hurts to ask them.. or at the least letting them know.. they actually do listen to these customers so you might be the beginning of added added braze ons for next years frame..
And seriously.. how can you turn away from that beautiful color!?
Jkidd
You know, that's a very good point...and a problem around the forums (it appears) and you caught me @ in doing it. Instead of just dismissing a product because of one minor detail, and not even talking with the company about it isn't really fair because there is a good chance that they can "make right" in there or fix it for the next version.
As for the color, my fav. color is green, just not that green and I like the traditional tape retro style..so schemes of changing it to that were already being plotted.
So as per your advice, I will give them a ring and see what they have to say! I was just so caught up on the Civilian Vive Le Roi checking all my boxes and cheaper....that I keep forgetting that I would really like a higher quality steel.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Raleigh RX 1.0
No harm sir.. that civilian is truely a beautiful ride! That was the first non MTB that actually made me do a double take..
Any inside knowledge, review of sorts? Not to thread steal, you can send in a private message, but it would be a direct comparison outside of price.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Raleigh RX 1.0
I like this. I wonder how it compres (performance wise) to the Macho Man Disc......
Transition Rapture
They both look almost identical. Only difference I see is the adjustable drop outs for the SS on the transition.
I don't think you can go wrong with either.
I like it. I like the geo and the colors. The video won me over
Anybody know what the max tire clearance is?
This "catagory" of frames has me really intrigued. I'd love to see what people have done with "upgrades". I'm thinking Force with good wheels and a CF fork for myself.
35mm from what I can find
The Traitor Cycles website with the Crusader states:
SIZES: 48, 52, 55, 58
PAINT: Matte Black, Metallic Bright Green
FRAME MATERIAL: Founderland Seamless Race Double Butted Chromoly with ED rust proof coating inside and out.
FORK: Crusade Chromoly Disc Fork
1 1/8" Threadless w/160mm IS disc brake tabes (386 Axle to Crown)
WEIGHT: Frame (Size 55 without dropouts) 4.5 lbs | Fork 2.2 lbs (Uncut Steer Tube)
Complete Bike (As Pictured) 19 lbs
WARRANTY: 2 year defect warranty, lifetime crash replacement.
BUILD SPECS: 44mm Heatube, can run tapered or standard steer forks
27.2mm Seattube
Front Derailleur Clamp 28.6mm
135mm Rear Dropout Spacing
68mm Bottom Bracket Width
Max Tire Width 35c (With 6mm of clearance on each side)
6mm of clearance on each side indicate that you could likely fit something bigger depending on the rim combination. Wider rims will spread the tire more rather than bubble it, so you may be able to fit slightly more rubber, like 40-42ish.
After going back n forth from looking at the Civilian Le Roi Le Veut, Surly Straggler, Soma Double Cross, Volagi Viaje, Origin8 CX700, On-One Dirty Disco, and even Curlo Custom (very reasonably priced for custom) my needs so too specific, and I know if I don't get exactly what I am looking for, it'll be replaced in a year or so (or worse not ride it)...and I'm tired of buying bikes (not really, but significant other is)...
So I will most likely just save my pennies, and get a custom from Scott Quiring as I intended to do with my 29SS, and I've been wanting one of his bikes for a few years now..so I just might as well get it right and make myself and the nagging woman happy.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Raleigh RX 1.0
There are a couple threads o n these things floating around. Did anyone here end up getting one? Don't like this years colors quite as much but I'm really intrigued by the bike.
CX/road sizing is something I've never really dealt with. I'm 5'11" so I'm always a tweener size wise. Can anybody help me out? Show me some build pics!
Depending if you have long legs or a long torso, you could fit in the 52 or the 55. The 52 has a longish 545 ETT, but typically cross bikes run tall to give more room inside the main triangle for shouldering.
One thing to be concerned with though is that these frames only have one set of water bottle braze-ons, you'll have to figure something out for another set if you want two.
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Raleigh RX 1.0
I've just ordered a Med. I'm 5'9". I have a 53cm Ibis Hakkalugi too.
I'd take a Hakk over a Rapture any day of the century..whether it was going to be SS or not.....I still want a Hakk cani-brake!
Ibis Ripley LS
Intense Spider 29 C
Cervelo S2
Trek Boone 5 Disc
Raleigh RX 1.0
Yeah, send that lugi this a way....
How long did they say the wait time would be?
I've talked to my dealer a four times and they just keep saying they'll call transition and call me back. So either transition won't return their calls or the shop is dragging their feet. Wish I could just do consumer direct with them or traitor would re-stock their version.
I love the lugi but submerging the pressfit BB every other week at races isn't all that good for it. It's my gravel grinder/dry course bike now. The frame was shipped Monday and I hope to have it built up next week some time at the local shop. There might be more frames available to us Canucks because the sport is just taking off perhaps?
PFBB on CX bike is a dealbreaker for me.
enjoys skidding
Anyone else tried a wide tire on these? I was hoping it would be possible to shoehorn something monstercross onto it.
I am running a 40c Happy Mediums on Sung Ringle Black Flags on my Traitor Crusade, which is the same frame with a different badge. I have the rear adjustable dropouts about half way out and there are only a few mm of clearance on either side of the tire. Its pretty tight. There is plenty of room in the front and could go a little bigger.
The bike is awesome for playing on singletrack.
enjoys skidding
Sounds great! Any chance you have a photo?
If I came across one of these frame sets in my size, I don't think I could resist!! I have a 2010 Giant TCX 0 that I love, but I really want disc brakes, so I may get a new frame and fork, but finding one of these in my are is impossible as there aren't any dealers. Anyone know of a place that can get one (large) or has one, and will mail order it in the US?
Running it singlespeed might be an issue since you lose about 1/2 the rear adjustment to make the rear tire clear, but no issues so far running it geared.
The colour of the frame is so hot.
I'm going with the Traitor version of this frame in the new tropical blue color. If anyone is interested there is a green 55cm on ebay right now. I was going to get it but the green is the exact same color as my Canfield Yelli Screamy. Wanted to change it up.
Dunno if anyone is interested but I got my Crusade in "tropical blue". Looks very teal in person but I still like it. Paint has a satin finish and seems pretty consistent. The rust proof coating is smooth and black like automotive primer, nice touch. Very happy I don't have to mess with frame saver.
My size 55 frame weighed 4.7lbs and the fork 2.2lbs on my scale. It fit WTB nano 40c's with the dropouts half way out but I am building it up with ritchey shield 35c's with the dropouts all the way in.
Frame seems like a pretty good value as the quality seems quite nice and they have packed in a fair amount of useful features. Will post up some pics shortly if anyone cares to see them.
By flowbike in forum Transition Bikes
Last Post: 05-12-2016, 05:55 PM
By luke_ in forum Transition Bikes
Last Post: 11-11-2011, 02:44 PM
By JFryauff in forum Beer Forum
Last Post: 09-23-2011, 12:30 PM
By happy_ending in forum Arizona
Last Post: 05-23-2011, 04:47 PM
By Obi in forum California - Norcal
Last Post: 05-21-2011, 08:39 AM
Members who have read this thread: 7
- You may not post replies
- You may not edit your posts
Forum Rules
