Results 1 to 10 of 10
Thread: Tire Pressure?
    Aug 2013
    Tire Pressure?
    What tire pressure are you CX bike riders running on trail?
    Airing up for pavement?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Hey Tinman, that's a big question. 33mm or 35mm or more? Tubular or clincher? Fine tread or Knarly?
    I use Schwable 35mm Rocket Ron (front) & Racing Ralph (rear) on pavement and gravel @ 50psi and 55psi respectively. How you want to balance the Front/rear ratio makes a difference too.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Aug 2013
    Thanks Eric,
    That (50-55psi) gives me a good idea with out excessive detail. I see most those cx tires rate at 70-100. I have the hots for a cx bike but, besides cx I would like clearance for 45's (monster cross)............I will likely have to give somewhere
    Kilted Cyclist
    I don't bother airing up pavement
    Reputation: jkirkpatri's Avatar
    At 250lbs, I air my tires up to 60psi, but no higher. 2012 Jake the Snake stock setup.
    Reputation: AlexCuse's Avatar
    Trail 40 or 45
    Road/gravel 65ish
    Race courses 30-45
    Tires usually 32s, I weigh 225ish
    Yeah I only carry cans cause I'm a weight weenie.
    more skier than biker
    Nov 2006
    Tire Pressure?
    I weigh about 165 lbs, am running 35c clinchers, set up tubeless, and am around 28 psi front and rear. Sometimes 25 psi.
    Edit: Sorry just reread the OP. i use the above pressures for racing. For trail/training/singletrack i air up to 30-35 to minimize chance of burping or rim strikes on rocks since i'm usually farther away from help if needed.
    Kappius Components Ambassador - Ping me a note for a discount code
    Reputation: Poncharelli's Avatar
    Jan 2005
    I ran Clement PDX 32mm on a Ridley X-fire disk last year, with tubes filled with Stans.
    I weigh about 165 also and raced them 40 psi rear, 35 psi front (many of our race courses integrate trail). One course was high speed over rocks and I pumped them up 5 psi more. Didn't pinch flat but many others did.
    I'll pump them up to 50 psi or so if I'm bike commuting the CX on pavement only.
    Reputation: crossracer's Avatar
    Tire Pressure?
    I run conti 700x43mm tires, knobbies. About as large as my bike will fit. Off road I run maybe 65-70 . I'm about 210 so that's a balance between traction and snakebites
    Bill
    Oct 2011
    Quote Originally Posted by Tinman View Post
    Thanks Eric,
    I run 700x40 Schwalbe Mondials tubeless and run 28f/30r on and off pavement:
    - DSCF1445
    Originally I ran them with tubes and at even the lowest recommended pressure (50-85psi) they were too hard, eventually dropped to around 35 psi before going tubeless.
  1. Tire Pressure 101
    By RideStrong in forum XC Racing and Training
    Last Post: 08-23-2013, 09:28 AM
  2. Tire Pressure
    By gunner.989 in forum 27.5
    Last Post: 05-08-2013, 09:11 AM
  3. Tire Pressure
    By Bobcanride in forum Endurance XC Racing
    Last Post: 07-13-2011, 07:18 AM
  4. Tire Pressure
    By AllisonWunderland in forum Beginner's Corner
    Last Post: 06-20-2011, 05:49 AM
  5. tire pressure
    By tman152 in forum Beginner's Corner
    Last Post: 04-14-2011, 04:54 PM
