Results 1 to 5 of 5
    Daniel the Dog
    Steven's Vapor with TRP brakes
    I'm considering a SRAM equpped Steven's Vapor with SRAM, Stan's cyclocross wheels, and TRP mechanical to hydraulic brakes. Any opinion this bike? It is alloy. Rough riding?
    Thanks guys.
    Dec 2009
    Embrocation Cycling Journal: Stevens Vapor
    It's not a test ride, but looks like a nice bike. Alu frames will be harsher than steel or carbon, not that you'll notice if you just use it for racing. Would feel it if you're a gravel grinder, tho.
    What's Steve asking for it? (lame joke)
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Thats one sexy
    Bike.
    The oversized headtube and carbon fork/steerer will help smooth it out a bit. On my Crosby, ive found that running a shallow amount of seat-bar drop, wide bar, generous amount of bar tape and 35c (r) and either 40c or 35c (f) tires helps. i dont race and have the bike set up for trails, gravel and just plain messing around.YMMV
    Quote Originally Posted by jrm View Post
    Bike.
    Im not an engineer *yet* but I fail to see how an oversized headtube will help "smooth" out the ride whatsoever.
    A tapered steertube is designed to be stiffer. The headtube is oversized to fit the larger and stiffer steertube.
    The only thing on a cross bike that will ease a "rough ride" is fat tires like you said at the end.
    Hammerheadbikes.com
    jrm
    jrm is offline
    I didn't stay @ a Holiday Inn Express last night
    but from my understanding of it its the combination of the dimensions of the tapered HT combined with the material of a CF fork with a CF steerer that dampen the ride better then the same alu set up.
