Results 1 to 9 of 9
    Reputation: mrjustin007's Avatar
    Stans Alpha 340 Disc & clydesdales
    Are there any clydes out there using Stans Alpha 340 Disc wheelset? Stans say these have a weight limit of 200lbs. I'm 225 w/o gear. Should I just go for the Alpha 400s?
    WTB: Bontrager Comp Fork & Syncros metal top cap
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Stan's along with all Manufacturers, give weight limits as a guide to cover safety margins within the products intended end use. In this case, rough work over rocks, roots and whatever. If you intend to use them solely for road work on a mirror smooth surface, Yes. Otherwise, if you are a genuine smooth, light on your feet sort of rider, OK. But otherwise, heed the restriction. I have repaired or replaced many wheels over the years for riders who simply go over sensible limits. If you're big, you need heavier duty, so go 400s and save yourself the grief, 340s are for fly-weights.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Thanks Eric - I'm definately not light on my feet . . .
    Go for the 400
    Think of it as a 340 EX
    Like the Arch EX, Flow EX, etc
    Sent from my iPhone. There may be horrible grammar and misspelling involved
    Reputation: Ooklathemok's Avatar
    Dec 2011
    I'm 235 and have the 340's/32 hole/non disc on my road bike, geared cx bike and ss cx bike. 2 years on road, gravel, crushed limestone and mtb trails no issues.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Which Alpha 340's? The three models each have a different weight limit. 190 for the Pro's, 230 for the Team and 250 for the Comp.
    I'm a mountain bike guide in southwest Utah
    Dec 2011
    Teams on the road and cx bike. Handbuilt w/Paul ss hubs on the ss cx bike.
    jct
    jct is offline
    Reputation: jct's Avatar
    i was considering stan's rims for CX this season. the weight limits made me switch to the new easton set. only downside is that a lot of the tires i want to ride are unproven on the eastons. i'll be most likely running captains.
    Quote Originally Posted by Silentfoe View Post
    They were the 24/28 spoke 340 Disc, but I've gotten rid of them and am using my MTB wheelset for the time being.
  1. How to tell Stans 355 Disc rim from v-brake rim?
    By Baulz in forum Weight Weenies
    Last Post: 12 Hours Ago, 12:09 AM
  2. Replies: 10
    Last Post: 09-05-2013, 06:28 PM
  3. Blown road tires running Stans on Alpha 340's
    By macace8 in forum Wheels and Tires
    Last Post: 11-11-2012, 08:15 PM
  4. Replies: 18
    Last Post: 03-07-2012, 11:07 AM
  5. Stans ZTR SS rear disc hub?
    By The_Mickstar in forum Singlespeed
    Last Post: 01-19-2011, 09:09 AM
