Results 1 to 2 of 2
    Apr 2013
    Question on brakes
    I have a Masi steel frame road/touring bike that I really like and want to use for gravel/trails/roads, only gap I see is the brakes. The levers and callipers are tecktro and the brakes don't work well on gnarly descents. Are there different brakes I could use to improve braking? FYI I have downtube shifters on the bike. Also, would be nice if the callipers can accommodate larger tires (32mm on there right now).
    Reputation: joeinchi's Avatar
    Jun 2010
    Pics would be really helpful.
    Does this bike use road bike calipers? What brake pads are on there and when were they last replaced? Have you cleaned the rim braking surface lately? Are the brake cables/housing new? A little maintenance can dramatically improve their performance.
    As to alternatives, is your bike equipped with dual post mounts, i.e. can you install individual cantilever or v-brake arms to the frame and fork? If not, then you probably want to search the forums at for long reach calipers. Canti's and mini v-brakes will fit larger tires but you may want to check the clearance between the tire and chainstays, first, to see if going bigger is even an option.
    Chicago, IL
  1. New XT brakes question - other rotors
    By AlexRandall in forum Brake Time
    Last Post: 04-10-2013, 04:45 AM
  2. New here and have a question about what brakes to buy..
    By aquito in forum Beginner's Corner
    Last Post: 10-16-2012, 08:50 AM
  3. V Brakes question
    By JerB in forum General Discussion
    Last Post: 08-19-2012, 02:44 PM
  4. Rim Brakes that squeak question
    By hunter99507 in forum Brake Time
    Last Post: 04-15-2012, 11:53 AM
  5. Just bout my first MTB! Question about brakes..
    By Stoutbeard in forum Beginner's Corner
    Last Post: 03-08-2011, 04:59 PM
