Results 1 to 12 of 12
    Oct 2013
    New to Cyclocross and MTB forum-Building first CX help.
    I'm currently gathering components for my first CX bike-
    I will be using Straight MTBars with Avid Elixir Hydraulic disc brakes.
    I plan on using Shimano XTR M980 2x10 shifters
    Question:
    Will the Shimano XTR FD-M985 be ok for the 34/50 front chainrings.
    and the Shimano XTR-RD-M980 Long Cage be ok for the rear Casette?
    Thanks in advance-
    Doug
    Mountain UNI is the bomb-
    Nimbus Unicycles
    Jun 2012
    on long cage - should be good to go, I was using it 1x10 (XT long) with no problems.
    Maybe this will help
    Long cage vs. med cage on 2x10? Does it matter?
    I stay in my small ring (34t) on cross bike w 25/12. I am a strong cat 4 (maybe? - should be Cat 3)
    Quote Originally Posted by scottz123 View Post
    If this bike is for racing, I'd say two things.
    1-get rid of the 50 up front, you'll never use it
    2-a long cage "may" help with chain slap but on a lower bb'd bike, it's also more likely to catch something on the ground and ruin your day
    Depending on your cassette, a long cage might be overkill. For reference, I run the same crank and often a 11-28 cassette with a small cage on my roadie.
    Feb 2013
    Agreed on the 50t, you will not ever use it. I run a 39x11-32 and I'm very happy with it, a 36 would be fine too I think. For a 2x10 a 42 and 28 would be good in front. if You're using a 'compact' crankset, you should be able to get a 36, but your 34 should be fine 95% of the time. A 44 or 46t big ring would be usable once in a while, that would be a better choice. With the 34 you should be able to climb most anything with a 28 as your biggest in the rear.
    Jun 2012
    Quote Originally Posted by Walt Disney's Frozen Head View Post
    Wouldn't a long cage be more prone to chain slap, That was what came stock with my 3x10 mtb setup
    Somewhere on mtbr is a chart explaining front ring/cassette (biggest ring?) combination for mid/long cage
    Reputation: stevland's Avatar
    In terms of der options, the rule I've always followed has been related to how many chainrings I'm running.
    3x - long cage
    2x - med cage
    1x - short cage
    ...2-a long cage "may" help with chain slap but on a lower bb'd bike, it's also more likely to catch something on the ground and ruin your day...
    A long cage will be more prone to chainslap. Also, BB drop has nothing to do with the rear derailleur height.
    Oct 2013
    Thanks for the information- Pictures soon- Powder coating frame and fork this week.
    Will the Shimano XTR-980 shifters work fine with the Cx-70 front deraillure as far as the indexing goes?
    Thanks in advance-
    Doug
    Feb 2013
    One more observation re gearing, as mentioned above my cx bike has a 38 in front (I mistakenly thought I had a 39), I raced my 29er mtb at a cx race over the weekend with my best finish (4th) in my cat3 age group since I was in my 20s, which was a long time ago.
    I did the entire race in the middle ring, a 32, with an 11-32 rear, and did not get dropped while drafting on the paved flats. IMO, a 32 front is big enough for cx, - just your 34 will be fine. I used the 32 in the rear a lot more than the tinier gears. If I were to build a new drivetrain for cx I think I'd go 1x with a 32 or 34 in front.
    so jimPac, i've got a 175mm crank w/34T ring that i pulled off of another SS build and would like to use for a CX build. are you saying that if i matched that crank up with an 11-32 cassette, i should be in darn good shape for most any CX race? if so then would you recommend i use any sort of chain guide or is that not a concern in CX?
    (to explain my ignorance, i'm coming from a nearly exclusive mtb history, the bulk of which has been SS. i have a road bike but only ride it on pavement a few times a year and on rollers in my basement when the trails are too soaked to ride.)
    thanks!
    Feb 2013
    Yes, in my experience the 34 x 11-32 would be fine 98% of the time, and if you start to spin-out on a paved descent, just take a short rest. When you encounter some climbing, you'll really be happy to have the low gear. I'm still running 9 speed, and I use an older xtr rear derailleur, an m952. I had a 9speed xt, the common silver one from the mid 2000s, my friend is using it with his 10sp setup. I believe that the bolt pattern on most of the compact cranks is the same as older mtb, which is 110mm if it's 5 bolt, and it's easy to find older 36t chainrings for relatively cheap. I need to look at a gear ratio chart, but I would be tempted to try a 34 x 11-28/11-27, my 38 x 11-32 might be pretty similar for the lowest gear. The cassette would be lighter and I could use a short cage derailleur.
    Of course it also depends on how strong you are in the short sharp climbs.
    Yes, you will want to run a chain guide, I'll look up the one I have a bit later today. I dropped my chain twice last season w/o a chain guide, no drops this year.
    Feb 2013
    I was using a cheaper 'third eye' chain guide, but I got this one instead and I think it's better:
    N Gear Jump Stop 31 8mm 1 1 4" Jump Stop Chain Deflector | eBay
    I had to use a longer bolt since my frame has a pretty fat seat tube. I also use an outer ring chain guide.
    Since you're a SS guy, and are probably used to pushing a pretty large gear, you might be fine with the 34 x 11-27/28. For added perspective, on my old mtb 26er I used 24/36/48 x 11-28 forever, and I stayed in the middle ring most of the time, except for the long sustained climbs and sustained fire road descents, both of which are not usually found in cx.
  1. Frame Building Forum FAQ
    By Walt in forum Frame Building
    Last Post: 03-01-2013, 07:57 AM
  2. Replies: 4
    Last Post: 11-10-2012, 07:00 AM
  3. Replies: 0
    Last Post: 11-30-2011, 07:31 PM
  4. Replies: 4
    Last Post: 11-24-2011, 11:47 AM
  5. make my firts XML triple! [extreme+noob eletrical]
    By reff in forum Lights DIY - Do It Yourself
    Last Post: 09-05-2011, 03:52 PM
